Home » Eclipse Projects » Virgo » Virgo doesn't start if installed in a path containing a space(Virgo doesn't start if installed in a path containing a space)
Virgo doesn't start if installed in a path containing a space [message #1697576] Fri, 05 June 2015 02:22 Go to next message
Virgo Nano server doesn't start if installed in a path containing a space. It throws following exception,
Error: Could not find or load main class folder\VIRGO_NANO\work\tmp
Is this a bug ?
Chandru
Re: Virgo doesn't start if installed in a path containing a space [message #1697595 is a reply to message #1697576] Fri, 05 June 2015 05:01 Go to previous message
Yes, this is a known limitation:
[1] 364448 - Virgo will not start if installed in a path containing a space
[2] 408811 - Server fails to start when installed into a directory with a path containing white space
florian
[Updated on: Fri, 05 June 2015 05:02] by Moderator
Previous Topic:Admin Console for Nano Web?
Next Topic:Jaas login module service
Current Time: Wed Jun 04 08:52:35 EDT 2025
Powered by FUDForum. Page generated in 0.05515 seconds
