Home » Modeling » TMF (Xtext) » Bad version number in .class file(xtext)
Bad version number in .class file [message #1697453] Thu, 04 June 2015 01:44 Go to next message
I am using an older version of Eclipse, and Xtend IDE and I am trying to update to the latest version of Eclipse.
Old Eclipse version: Juno Version 4.2.0
Build id: I20120608-1400
Xtext: 2.3.1.v201208210947
Xtend IDE: 2.3.1.v201208210947
Using J2SE-1.5
New Eclipse version: Luna Version 4.4.2
Build Id: 20150219-0600
Xtext: 2.8.3.v201506010551
Xtend IDE: 2.8.3.v201506010551
Using J2SE-1.5
After I migrated my code, I tried to generate the Xtext Artifacts but I am getting the error:
Could not load class: org.eclipse.core.runtime.OperationCanceledException
Add org.eclipse.equinox.common to the class path.
I added this in my MANIFEST.MF -> Dependencies -> Required Plugins
I am using org.eclipse.equinox.common (3.6.200).
I tried to execute "Generate Xtext Artifacts" again, but this time another error comes up.
0    [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher  - Bad version number in .class file
java.lang.UnsupportedClassVersionError: Bad version number in .class file
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClass(Unknown Source)
	at java.security.SecureClassLoader.defineClass(Unknown Source)
	at java.net.URLClassLoader.defineClass(Unknown Source)
	at java.net.URLClassLoader.access$100(Unknown Source)
	at java.net.URLClassLoader$1.run(Unknown Source)
	at java.net.URLClassLoader.findClass(Unknown Source)
	at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
	at java.lang.ClassLoader.loadClassInternal(Unknown Source)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:75)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:36)
I have checked my MANIFEST.MF, and it said: Bundle-RequiredExecutionEnvironment: J2SE-1.5
My Java Build Path -> Libraries also has JRE System Library [J2SE-1.5].
In Java Compiler, I ticked Enable project specific settings and Use compliance from execution environment 'J2SE-1.5' on the 'Java Build Path'
I have also configured my Preferences -> Java -> Installed JREs -> Execution Environments -> J2SE-1.5 and ticked the compatible JREs.
There is only one perfect match which is the jre1.5.0_22 [perfect match].
I have also compared the settings to my old Eclipse setup and everything is already the same.
Is there something I am missing? Do I need to set the Java version somewhere?
[Updated on: Thu, 04 June 2015 01:45] by Moderator
Re: Bad version number in .class file [message #1697454 is a reply to message #1697453] Thu, 04 June 2015 01:59 Go to previous messageGo to next message
org.eclipse.core.runtime.OperationCanceledException => Add org.eclipse.core.runtime.
i am not sure if xtext still works with Java 5 in all places
Re: Bad version number in .class file [message #1697455 is a reply to message #1697454] Thu, 04 June 2015 02:06 Go to previous messageGo to next message
btw can you see from the trace which .class file is affected?
Re: Bad version number in .class file [message #1697456 is a reply to message #1697455] Thu, 04 June 2015 02:16 Go to previous messageGo to next message
From the Release Notes:
Important Changes
All Xtext plug-ins now require JavaSE-1.6 as execution environment. Furthermore, the Java code generated by Xtext uses @Override annotations for methods overriding or implementing other declared methods, so the plug-ins into which this code is generated must use at least JavaSE-1.6 as execution environment. If your plug-ins are set to J2SE-1.5 and you run the Xtext 2.8 code generator, you will probably get compiler errors like The method 'm' of type 'T' must override a superclass method; eliminate them by switching to a higher Java version.
but that does not explain why the generator does not run
[Updated on: Thu, 04 June 2015 02:16] by Moderator
Re: Bad version number in .class file [message #1697458 is a reply to message #1697455] Thu, 04 June 2015 02:31 Go to previous messageGo to next message
I updated the dependency and add org.eclipse.core.runtime instead, but the error is still the same.
The error I pasted above is the one I displayed in the console log. How can I get the trace to see which .class file is affected?
Re: Bad version number in .class file [message #1697461 is a reply to message #1697458] Thu, 04 June 2015 02:55 Go to previous messageGo to next message
Please switch to java 6
Re: Bad version number in .class file [message #1697470 is a reply to message #1697458] Thu, 04 June 2015 04:47 Go to previous messageGo to next message
HI
You can have to work quite hard to change thoroughly between Java
versions if you have used one version pervasively..
You must do a Clean build after ensuring that either you have no Java 5
installed, or all your relevant projects have had their BREE changed to
Java 6 and that their classpath has been updated, most easily fromn the
manifest overview. THe Package Explorer shows the actual Java version
after each "JRE System Library".
Then make sure that your launch configuration does not allow Java 5.
REgards
Ed Willink
> the error is still the same. The error I pasted above is the one I
Re: Bad version number in .class file [message #1697478 is a reply to message #1697470] Thu, 04 June 2015 05:35 Go to previous messageGo to next message
I have updated to Java 6 already. And I am able to get past the 'Bad version' error.
The problem now is that I have .antlr-generator-3.2.0.jar in my root directory, which is in the same location when I am using the old Xtext version.
When I try to execute Generate Xtext Artifacts, it showed me this error:
*ATTENTION*
It is recommended to use the ANTLR 3 parser generator (BSD licence - http://www.antlr.org/license.html).
Do you agree to download it (size 1MB) from 'http://download.itemis.com/antlr-generator-3.2.0-patch.jar'?
I downloaded it manually, and placed the .antlr-generator-3.2.0-patch.jar in my root directory, but it still gives me the same error.
Where should I put the antlr so that eclipse can detect it?
[Updated on: Thu, 04 June 2015 05:36] by Moderator
Re: Bad version number in .class file [message #1697485 is a reply to message #1697478] Thu, 04 June 2015 06:20 Go to previous message
simply answer with yes or install it (antlr sdk) via the update site http://download.itemis.com/updates/.
Previous Topic:How is XText terminals match its previous terminal?
Next Topic:Replacing XText expressions with external Java (or other language) code?
Current Time: Mon Jul 28 16:37:21 EDT 2025
Powered by FUDForum. Page generated in 0.08247 seconds
