Home » Modeling » Papyrus » Error during oomph Papyrus installation.(installation error.)
Error during oomph Papyrus installation. [message #1697052] Mon, 01 June 2015 04:55 Go to next message
Hi.
I'm making Papyrus Development Environment using oomph.
I selected 'Eclipse Modeling Tools' in the first screen titled with 'Product',
then selected 'Papyrus' folder in the second screen titled with 'Projects' of oomph,
then specified the installation location and workspace location, target platform 'Luna',
then clicked 'Next'.
After it finished the Bootstrap tasks, it produces error like below while Executing startup tasks.
I repeated three times, but it produces the same error.
ERROR: org.eclipse.equinox.p2.metadata.repository code=1000 No repository found at http://download.eclipse.org/modeling/gmp/gmf-runtime/updates/milestones/S201502040533.
  at org.eclipse.oomph.targlets.internal.core.TargletContainer.forceUpdate(TargletContainer.java:661)
  at org.eclipse.oomph.setup.targlets.impl.TargletTaskImpl$4.run(TargletTaskImpl.java:994)
  at org.eclipse.oomph.util.pde.TargetPlatformUtil.runWithTargetPlatformService(TargetPlatformUtil.java:125)
  at org.eclipse.oomph.setup.targlets.impl.TargletTaskImpl.perform(TargletTaskImpl.java:912)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:2904)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:2863)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:3948)
  at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2313)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:3942)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:3940)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:2854)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:2829)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:2760)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:539)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:624)
  at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
How can I fix this error and succeed in getting clean Papyrus Development Environment?
Re: Error during oomph Papyrus installation. [message #1697073 is a reply to message #1697052] Mon, 01 June 2015 08:25 Go to previous messageGo to next message
I was just updating the Oomph setup for Mars and noticed that the Luna setups includes some Mars Milestone update sites... Which seems highly suspicious.
I will update the setup, which should solve the issue, but this will also downgrade some of the versions (From Mars to Luna), so this may have some impacts on update scenarios... Which is still less severe than update sites not found, I suppose
Camille
Re: Error during oomph Papyrus installation. [message #1697075 is a reply to message #1697073] Mon, 01 June 2015 08:29 Go to previous messageGo to next message
I have re-updated the Oomph setup for Luna to pick the Luna SR2 update sites, rather than Mars milestones. This should hopefully solve the issue. Can you please try again?
Camille
Re: Error during oomph Papyrus installation. [message #1697170 is a reply to message #1697075] Tue, 02 June 2015 03:22 Go to previous messageGo to next message
Thank you for the quick reply.
I tried again and it worked!!
But after importing Papyrus Projects, I got build errors like below.
index.php/fa/22021/0/
Errors count is about 13,700.
I tried to start resolving these build errors by manually installing 'QVT Operational SDK'.
But after installing QVT Operational SDK, the errors count increased to over 814,000.
I installed EMF Facet SDK, MoDisco SDK, WST XML Core, XText complete SDK, OCL examples and Editors SDK, Acceleo, Acceleo Core SDK to reslove the build errors, but the errors count was even increased a little bit, not decreased.
How can I resolve all those build errors?
I try to find answers from the documents of Papyrus site, but I couldn't.
Please help me out.
[Updated on: Tue, 02 June 2015 03:23] by Moderator
Re: Error during oomph Papyrus installation. [message #1697183 is a reply to message #1697170] Tue, 02 June 2015 04:11 Go to previous message
Eclipse's incremental build is often good, but not always.
I find that a major GIT commit change often fools it.
Refresh all projects; this will often trigger rebuilds
Clean All; if the above didn't work
Restart; if the above didn't work
Your additional installs should not be needed, so you risk making
matters worse but installing a wrong. REvert o your configuration before
those installs and let Eclipse Restart and sort it all out.
Ed Willink
> Errors count is over 13,700.
> Please help me out.
Previous Topic:Clicking "New Papyrus Project" does nothing
Next Topic:SysML diagram lost.
Current Time: Sat Jul 26 19:25:20 EDT 2025
Powered by FUDForum. Page generated in 0.04016 seconds
