Home » Eclipse Projects » Sirius » a node label cannot be saved when using Node Creation from a Palette.
a node label cannot be saved when using Node Creation from a Palette. [message #1696814] Thu, 28 May 2015 12:51 Go to next message
Thank you so much to the Sirius Team for providing a good tool.
I'm getting much help from the Sirius on defining my own language.
By the way, I have another problem.
When I created a node by using a icon in my palette, I could make a new node.
However, when I edit the label of the node, the value wasn't saved.
I just added a Node Creation in Viewpoint Specification and set mapping.
Do I need to add other things?
I tried to add "Direct Edit Label" like the 4-minute tutorial, but when I edit the label of a new node, it showed "Null Pointer Exception".
Are there missing points?
Please let me know.
Thanks alot.
Best Regards,
Eunjung Park
Re: a node label cannot be saved when using Node Creation from a Palette. [message #1697045 is a reply to message #1696814] Mon, 01 June 2015 04:04 Go to previous messageGo to next message
Le 28/05/2015 18:51, eunjung park a écrit :
> node.
yes
> Please let me know.
Indeed, "Direct Edit Label" is the right way to edit and save the edited
value. [1] Use a "Set" operation to set the edited value on the feature.
But be careful, in Value Expression, use an expression like [arg0/] and
not $0 as it is wrongly indicated in the tooltip of "Edite Mask
Variables"/Mask is wrong.
About the NPE, could you provide us data to reproduce the issue and also
your complete stack trace.
> Thanks alot.
> Best Regards,
> Eunjung Park
Laurent
[1]
https://www.eclipse.org/sirius/doc/3.0.x/specifier/diagrams/Diagrams.html#tools
Re: a node label cannot be saved when using Node Creation from a Palette. [message #1697147 is a reply to message #1697045] Mon, 01 June 2015 18:54 Go to previous messageGo to next message
Hi, Laurent
Thank to your help, I could solve the problem.
After set the operation, I don't have any Null Pointer Exception.
Do you still need also the exception?
If then I will reproduce it and upload.
By the way, how can I see the stack trace?
Thanks and regards,
Eunjung Park
Re: a node label cannot be saved when using Node Creation from a Palette. [message #1697167 is a reply to message #1697147] Tue, 02 June 2015 03:12 Go to previous messageGo to next message
Yes thanks. I would be pleased if you could provide me the stack trace.
You can get it clicking "Details" when the pop up is displayed or in
"Error log" view.
Laurent
Le 02/06/2015 00:54, eunjung park a écrit :
> Hi, Laurent
> Thanks and regards,
> Eunjung Park
Re: a node label cannot be saved when using Node Creation from a Palette. [message #1697191 is a reply to message #1697167] Tue, 02 June 2015 05:12 Go to previous messageGo to next message
This is the error log.
I hope this would be help.
Thanks alot.
Eunjung Park
  • Attachment: Stack.png
    (Size: 9.88KB, Downloaded 106 times)
Re: a node label cannot be saved when using Node Creation from a Palette. [message #1697192 is a reply to message #1697191] Tue, 02 June 2015 05:31 Go to previous message
Le 02/06/2015 11:12, eunjung park a écrit :
> Thanks alot.
> Regards,
> Eunjung Park
Thanks but what I need is the full stack trace, the class of Exception
is not enough to understand the issue. Perhaps you are not aware about
what a stack trace is, so read this article[1]
[1]
http://stackoverflow.com/questions/3988788/what-is-a-stack-trace-and-how-can-i-use-it-to-debug-my-application-errors
Previous Topic:Hook to run arbitrary code on diagram load
Next Topic:Set incoming and outgoing edges
Current Time: Sun Jun 08 21:02:52 EDT 2025
Powered by FUDForum. Page generated in 0.04902 seconds
