Home » Newcomers » Newcomers » Eclipse Auto-Complete/intellisense
Eclipse Auto-Complete/intellisense [message #262366] Fri, 01 August 2008 05:48 Go to next message
Originally posted by: eamonncostello.gmail.com
Does anybody know how to activate intellisense functionality in eclipse,
like there is in Visual Studio?
To be more precise, when you type the name of a declared object followed
by a period, then a window appears with a list of available methods and
properties?
Re: Eclipse Auto-Complete/intellisense [message #262375 is a reply to message #262366] Fri, 01 August 2008 09:48 Go to previous messageGo to next message
That functionality should be active by default.
What language are you using?
If Java, take a look at the Java > Editor > Content Assist section in
the preferences to make sure that it's turned on. Maybe you might want
to reduce the "Auto activation delay:" field to something shorter.
HTH,
Wayne
On Fri, 2008-08-01 at 09:48 +0000, Eamonn Cpstello wrote:
> properties?
Re: Eclipse Auto-Complete/intellisense [message #262381 is a reply to message #262366] Fri, 01 August 2008 10:15 Go to previous messageGo to next message
> properties?
In Eclipse, the feature is called Content Assist.
Ctrl+Space will invoke it anywhere. It should automatically appear at
certain times, like after you type "someObject."
You can configure its behavior in the preferences, under Java > Editor >
Content Assist.
Hope this helps,
Eric
Re: Eclipse Auto-Complete/intellisense [message #262725 is a reply to message #262381] Fri, 08 August 2008 07:27 Go to previous messageGo to next message
>> Hi,
>> eclipse, like there is in Visual Studio?
>> followed by a period, then a window appears with a list of available
>> methods and properties?
And also try Ctrl+1 (Quick Assist/Quick Fix)
Dani
> > Content Assist.
> Hope this helps,
> Eric
Re: Eclipse Auto-Complete/intellisense [message #262731 is a reply to message #262366] Fri, 08 August 2008 09:56 Go to previous messageGo to next message
Thanks for the replies folks, however I still can't get this to work.
E.g. I type the line:
System.out.printf( "Sum is %d\n", sum );
Now if I position the cursor just instead of the period, delete it and
type it in again, i should get a window with all the available methods of
the System.out object yes? When I press ctrl + Space. I get a window,
where it says "No default proposals"
I have all the seting correctly set in the Java - Editor section of the
Preferences. Maybe I don't have my build/include directories set properly?
any ideas?
TIA
Eamonn
Re: Eclipse Auto-Complete/intellisense [message #262733 is a reply to message #262731] Fri, 08 August 2008 09:57 Go to previous messageGo to next message
> of the System.out object yes? When I press ctrl + Space. I get a
> window, where it says "No default proposals"
> the Preferences. Maybe I don't have my build/include directories set
> properly?
> any ideas?
Code assist sometime gets broken when you install Mylyn and then upgrade.
Dani
> TIA
> Eamonn
Re: Eclipse Auto-Complete/intellisense [message #262735 is a reply to message #262733] Fri, 08 August 2008 10:10 Go to previous messageGo to next message
Hi Dani,
Any ideas on how I might fix this?
Re: Eclipse Auto-Complete/intellisense [message #262746 is a reply to message #262735] Fri, 08 August 2008 14:32 Go to previous messageGo to next message
> Hi Dani,
Go to Java > Editor > Content Assist Advanced, click 'Restore Defaults'
and then 'OK'.
Dani
Re: Eclipse Auto-Complete/intellisense [message #262756 is a reply to message #262746] Fri, 08 August 2008 16:02 Go to previous messageGo to next message
that fixed it!
E.
Re: Eclipse Auto-Complete/intellisense [message #1697029 is a reply to message #262375] Sun, 31 May 2015 13:58 Go to previous message
Hi can any one help me turn on intellisense constantly in eclipse oomph. I have tried following the instructions window>preferences>Java > Editor > Content Assist section but can only get as far as window>preferences>Java > and get the window with options for.
Package explore
Opening window type Hierarchy
Refactoring Java cod
Java Dialog
But no editor or content assets
Previous Topic:Require some stuff
Next Topic:How to organize files/folder from many different sources into a single 'project'?
Current Time: Sat Jul 26 08:28:35 EDT 2025
Powered by FUDForum. Page generated in 0.11670 seconds
