Content Assist Contexts [message #1696834] |
Thu, 28 May 2015 17:41  |
Hi guys,
I am having some issues with the content assist it works great but there are some scenarios where it does not work because the code is not able to create a "ContentAssistContext" I was debugging the code and the result of "createContentAssistContexts" which is invoke from CompletionProposalComputer returns an empty array.
This work ok:
testing: {
inside1: {
message: model.
However if I try something similar it does not work
testing: [
inside1: {
message: model.
I know that it depends on the grammar but I wanted to ask you if you know if there are some material/documentation to get a better understanding on how handle the context, maybe if someone has some experience dealing with some similar to check if the logic provide by Xtext is usually enough or I should check if I need to create my own logic to create these contexts.
Thanks in advance.
Luis
Re: Content Assist Contexts [message #1696936 is a reply to message #1696862] |
Fri, 29 May 2015 09:55   |
Hi Sven,
Thanks for your answer, I enclose the grammar and the examples with the cursor:
This work ok:
testing: {
inside1: {
message: model. @CursorHere@
testing: [
inside1: {
Grammar:
grammar org.designer.tooling.testing.DFL hidden(WS, EOL, SL_COMMENT)
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
generate dFL "http://www.designer.org/tooling/testing/DFL"
* Document
Document:
body=Body?;
Body:
header=Header?
content=Content;
* Header
Header:
directives+=Directive+ separator=HeaderSeparator;
HeaderSeparator:
separator="---";
Directive:
VersionDirective | NamespaceDirective | VariableDirective | OutputDirective | InputDirective | DebugDirective |
TypeDirective | FunctionDirective | AstDirective;
VersionDirective:
version=VersionNumber;
VersionNumber hidden(EOL, SL_COMMENT):
"%weave" WS+ INT "." INT;
NamespaceDirective:
"%namespace" name=NamespacePrefix value=NamespaceUri;
VariableDirective:
'%var' name=Identifier "=" constantValue=VariableValue;
VariableValue:
FunctionLiteral | Expression;
OutputDirective:
"%output" type=DataType options=Options?;
TypeDirective:
"%type" name=Identifier '=' type=Type;
AstDirective:
type="%ast";
* Functions
FunctionDirective:
"%function" name=Identifier "(" (parameters+=FunctionParameter ("," parameters+=FunctionParameter)*)? ")"
expression=Expression;
Schema:
{Schema} '{' (elements+=SchemaElement ("," elements+=SchemaElement)*)? '}';
SchemaElement:
name=Identifier ':' value=LiteralValue;
InputDirective:
"%input" name=Identifier type=DataType options=Options?;
DebugDirective:
{DebugDirective} "%debug" options=Options?;
Options:
options+=OptionElement ("," options+=OptionElement)*;
OptionElement:
name=Identifier "=" value=LiteralValue;
* Content
Content:
elements+=Expression;
MultipleKeyValuePairObj:
{MultipleKeyValuePairObj} "{" (elements+=ObjectElement ("," elements+=ObjectElement?)*)? "}";
ObjectElement:
=> ConditionalKeyValuePair | => KeyValuePair | EnclosedExpression;
KeyValuePair:
key=Key ":" (-> value=Expression?);
ConditionalKeyValuePair:
"(" key=Key ":" value=Expression ")" "when" condition=Expression;
* Key
Key:
namespace=DeclaredNamespace? value=KeyExpression attributes=Attributes?;
KeyExpression:
({StringLiteral} value=StringLiteral | {RealLiteral} value=RealLiteral | {IntegerLiteral} value=IntegerLiteral |
{BooleanLiteral} value=BooleanLiteral | {AnyDateLiteral} value=AnyDateLiteral) |
(EnclosedExpression => (
// We only dispatch one specific action for each selector because dispatching different actions consume a lot of time during the generation of EMF model, lexer and parser
// Descendant Selectors
{DescendantSelector.data=current} type=(".." | "..@" | "..^") (=> selector=Selector)? |
// Dot Selectors
{DotSelector.data=current} (type=("." | ".*") selector=Selector? | type=(".@" | ".^") (=> selector=Selector)?) |
// Bracket Selectors
{BracketSelector.data=current} (type="[*" selector=Selector | type=("[@" | "[^") (selector=Selector)?) "]" |
{IndexSelector.data=current} "[" indexSelector=SignedInteger "]" |
{RangeSelector.data=current} "[" start=SignedInteger ".." end=SignedInteger "]" |
{DynamicSelector.data=current} "[" "(" expression=Expression ")" "]" |
{FilterSelector.data=current} "[" "?" "(" expression=FunctionExpression ")" "]" |
{ValueSelector.data=current} "[" selector=Selector "]")* => ({ValueModifier.data=current} type=("?" | "!"))?);
DeclaredNamespace:
name=Identifier "#";
Attributes:
{Attributes} "@(" (attributes+=AttributeElement ("," attributes+=AttributeElement)*)? ")";
* Attributes
AttributeElement:
=> ConditionalAttribute | Attribute | EnclosedExpression;
Attribute:
namespace=DeclaredNamespace? name=Identifier ":" value=Expression;
ConditionalAttribute:
"(" namespace=DeclaredNamespace? name=Identifier ":" value=Expression ")" "when" condition=Expression;
* Literal Object and Expression
SingleKeyValuePairObj:
element=KeyValuePair;
* Expressions
Expression:
ConditionalExpression;
ConditionalExpression returns Expression:
FunctionExpression (-> ({When.trueStatement=current} "when" |
{Unless.trueStatement=current} "unless") condition=FunctionExpression "otherwise" falseStatement=FunctionExpression)*;
FunctionExpression returns Expression:
ReplaceExpression (-> ({MapObjectLambda.element=current} "mapObject" |
{MapLambda.element=current} "map" |
{PluckLambda.element=current} "pluck" |
{FilterLambda.element=current} "filter" |
{ReduceLambda.element=current} "reduce" |
{GroupByLambda.element=current} "groupBy" |
{OrderByLambda.element=current} "orderBy" |
{FindLambda.element=current} "find" |
{ScanLambda.element=current} "scan" |
{MatchLambda.element=current} "match" |
{DistinctByLambda.element=current} "distinctBy") function=FunctionDefintion)*;
ReplaceExpression returns Expression:
OrExpression (-> ({ReplaceWith.element=current} "replace") searchValue=OrExpression "with"
OrExpression returns Expression:
AndExpression (-> ({Or.left=current} "or") right=AndExpression)*;
AndExpression returns Expression:
EqualityExpression (-> ({And.left=current} "and") right=EqualityExpression)*;
EqualityExpression returns Expression:
IsExpression (-> ({Equal.left=current} "==" | {NotEqual.left=current} "!=") right=IsExpression)*;
IsExpression returns Expression:
StringExpression (-> ({Is.element=current} "is")
type=Type)*;
StringExpression returns Expression:
GreaterThanExpression (-> ({StartsWith.data=current} "startsWith" |
{EndsWith.data=current} "endsWith" |
{Matches.data=current} "matches" |
{Contains.data=current} "contains") filter=GreaterThanExpression)*;
GreaterThanExpression returns Expression:
LessThanExpression (-> ({GreaterThan.left=current} ">" | {GreaterThanEqual.left=current} ">=")
right=LessThanExpression)*;
LessThanExpression returns Expression:
AdditionSubtractionExpression (-> ({LessThan.left=current} "<" | {LessThanEqual.left=current} "<=")
right=AdditionSubtractionExpression)*;
AdditionSubtractionExpression returns Expression:
AppendExpression (-> ({Plus.left=current} "+" | {Minus.left=current} "-") right=AppendExpression)*;
AppendExpression returns Expression:
RightLeftExpression (-> ({Append.data=current} "++" |
{Remove.data=current} "--") element=RightLeftExpression)*;
RightLeftExpression returns Expression:
MultiplicationDivisionExpression (-> ({RightShift.left=current} ">>" | {Zip.left=current} "zip")
right=MultiplicationDivisionExpression)*;
MultiplicationDivisionExpression returns Expression:
SplitByExpression (-> ({Multiply.left=current} "*" | {Division.left=current} "/") right=SplitByExpression)*;
SplitByExpression returns Expression:
JoinByExpression (-> ({SplitBy.data=current} "splitBy") separator=JoinByExpression)*;
JoinByExpression returns Expression:
AsExpression (-> ({JoinBy.data=current} "joinBy") separator=AsExpression)*;
AsExpression returns Expression:
DefaultValueExpression (-> ({As.element=current} "as")
type=DefaultValueExpression)*;
DefaultValueExpression returns Expression:
Prefixed (-> ({DefaultValue.data=current} "default") default=Prefixed)?;
Prefixed returns Expression:
({UnaryMinus} "-" |
{Negated} "not" |
{SizeOf} "sizeOf" |
{Flatten} "flatten" |
{ValuesOf} "valuesOf" |
{KeysOf} "keysOf" |
{Trim} "trim" |
{Sum} "sum" |
{Average} "avg" |
{Using} "using" "(" parameters+=VariableDefintion ("," parameters+=VariableDefintion)* ")" |
{Upper} "upper" |
{Lower} "lower" |
{Capitalize} "capitalize" |
{Camelize} "camelize" |
{Dasherize} "dasherize" |
{Ordinalize} "ordinalize" |
{Pluralize} "pluralize" |
{Singularize} "singularize" |
{Underscore} "underscore" |
{Typeof} "typeOf" |
{Max} "max" |
{Min} "min" |
{Unzip} "unzip") expression=Postfix |
Postfix;
Postfix returns Expression:
Atomic => (
// Dot Selectors
{FilterSelector.data=current} "[" "?" "(" expression=FunctionWithoutParameters ")" "]" |
{ValueSelector.data=current} "[" selector=Selector "]")* => ({ValueModifier.data=current} type=("?" | "!"))?;
Atomic returns Expression:
=> SingleKeyValuePairObj | LiteralValue | => FunctionCall | Variable | MultipleKeyValuePairObj | => Range | => Array | => Type | EnclosedExpression;
EnclosedExpression returns Expression:
"(" Expression ")";
Selector:
namespace=DeclaredNamespace? name=(StringLiteral | Keyword);
* Functions
FunctionDefintion:
=> ("(" "(" (parameters+=FunctionParameter ("," parameters+=FunctionParameter)*)? ")" "->"
expression=ReplaceExpression ")") | => (parameters+=FunctionParameter "->" expression=ReplaceExpression) |
expression=FunctionWithoutParameters;
FunctionWithoutParameters:
ReplaceExpression;
FunctionLiteral:
"(" (parameters+=FunctionParameter ("," parameters+=FunctionParameter)*)? ")" "->" expression=Expression;
FunctionCall:
Variable "(" (parameters+=Expression ("," parameters+=Expression)*)? ")";
* Variables
Variable:
DoubleDollarVariable | VariableReference | DollarVariable;
VarDefinition:
VariableDirective | InputDirective | FunctionParameter | VariableDefintion;
VariableReference:
{VariableReference} reference=Identifier;
DollarVariable:
{DollarVariable} "$";
DoubleDollarVariable:
{DoubleDollarVariable} "$$";
FunctionParameter returns Expression:
name=Identifier ("=" initialValue=Expression)?;
VariableDefintion returns Expression:
{VariableDefintion} name=Identifier "=" initialValue=Expression;
* Literals
LiteralValue:
{BooleanLiteral} value=BooleanLiteral | {NullLiteral} value=NullLiteral | {QuotedStringLiteral} value=QuotedStringLiteral |
{RealLiteral} value=RealLiteral | {IntegerLiteral} value=IntegerLiteral | {AnyDateLiteral} value=AnyDateLiteral |
{AnyRegexLiteral} value=AnyRegexLiteral;
* Simple Types
NullLiteral:
"null";
BooleanLiteral returns ecore::EBoolean:
"true" | "false";
StringLiteral:
QuotedStringLiteral | Identifier;
QuotedStringLiteral:
STRING;
NamespacePrefix:
NAMESPACE_PREFIX;
NamespaceUri:
NAMESPACE_URI;
SignedInteger returns ecore::EBigDecimal hidden():
("-")? INT;
IntegerLiteral returns ecore::EBigDecimal:
INT;
RealLiteral returns ecore::EBigDecimal:
INT "." INT | INT "." EXPONENTIAL | EXPONENTIAL "." INT | EXPONENTIAL "." EXPONENTIAL;
AnyDateLiteral returns ecore::EString:
ANY_DATE;
AnyRegexLiteral returns ecore::EString:
ANY_REGEX;
// TODO (ldebello) List of all possible keywords that we want to use as common strings
Keyword:
"true" | "false" | "not";
Identifier:
UNQUOTED_STRING;
* Complex Types
Range:
"[" start=SignedInteger ".." end=SignedInteger "]";
Array:
{Array} "[" (elements+=ArrayElement ("," elements+=ArrayElement)*)? "]";
ArrayElement:
=> ConditionalArrayElement | Expression;
ConditionalArrayElement:
"(" expression=Expression ")" "when" condition=Expression;
Type:
{Type} ':' name=Identifier (=> schema=Schema?);
* Enums
enum DataType:
APPLICATION_DFL="application/weave" | APPLICATION_JSON="application/json" | APPLICATION_XML="application/xml" |
TEXT_XML="text/xml" | APPLICATION_CSV="application/csv" | APPLICATION_JAVA="application/java";
* Terminals
terminal STRING:
'"' ('\\' . /* 'b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\' */ | !('\\' | '"'))* '"'? |
"'" ('\\' . /* 'b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\' */ | !('\\' | "'"))* "'"?;
terminal INT returns ecore::EBigDecimal:
DIGIT+;
terminal EXPONENTIAL returns ecore::EBigDecimal:
DIGIT+ (('e' | 'E') DIGIT+);
terminal ANY_DATE:
terminal ANY_REGEX:
terminal UNQUOTED_STRING:
!NON_QUOTED_STRING_START !(NON_QUOTED_STRING_END)*;
terminal WS:
(' ' | '\t')+;
terminal SL_COMMENT:
'#' !(LINE_BREAK)*;
terminal EOL:
LINE_BREAK;
terminal NAMESPACE_PREFIX:
('a'..'z' | 'A'..'Z' | '0'..'9' | '_' | '-')*;
terminal NAMESPACE_URI:
('a'..'z' | 'A'..'Z' | '0'..'9' | '_' | '-' | '.' | ':' | '/')*;
terminal fragment LINE_BREAK:
('\r' | '\n');
terminal fragment DIGIT:
('0'..'9');
terminal fragment NON_QUOTED_STRING_START:
'"' | "'" | '0'..'9' | '!' | '#' | '$' | '(' | ')' | '*' | '+' | ',' | '-' | '.' | '/' | ':' | '<' | '=' | '>' | '?' |
'[' | ']' | '{' | '}' | '|' | '%' | '^' | '@' | '\r' | '\n' | ' ' | '\t';
terminal fragment NON_QUOTED_STRING_END:
| '^' | '\r' | '\n' | ' ' | '\t');
Also I am using a custom lexer to add some context in order to resolve some ambiguities.
I really appreciate your help or any tip related to the concepts of Content Assist Context or Follow Elements.
After debugging the code I understand that I will need to do one of the following things:
1- Relax my grammar to allow invalidate grammar in order to receive the complete node as valid and then add validation using the validation module (To be honest I am not really fond of this, but it seems the way to go)
2- Adding more specific logic to create different context using the offset to parse the current content (I think that this could be a solution but after changing that code I am sure that I will got a lot of error or dispatching the content assist several time)
Maybe you can tell me if my options are the right ones or if I am totally wrong in order to find the best solution.
Thanks in advance for you time and comments
Luis
Attachment: Grammar
(Size: 12.72KB, Downloaded 123 times)
[Updated on: Fri, 29 May 2015 09:58] by Moderator
FUDForum. Page generated in 0.25559 seconds
