Home » Eclipse Projects » WindowBuilder » WindowBuilder does not install on Mars SR3
WindowBuilder does not install on Mars SR3 [message #1697009] Sat, 30 May 2015 18:44 Go to next message
Trying to install WB on latest Mars RC3 fails with the error below.
I tried with previous releases of Mars (RC2a and RC1) and all goes well.
My environment is:
- Windows 8.1 64 bit
- Java 7 64bit
- Eclipse Mars 64bit RC3 Build id: I20150528-0700
Any hint?
Thank you
Vincenzo
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Problems downloading artifact: osgi.bundle,org.eclipse.wb.core.lib,1.8.0.r45x201412082350.
File has invalid content:C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar
Invalid content:lib/asm-all-3.3.1.jar
The file "lib/asm-all-3.3.1.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/commons-collections-3.2.1.jar
The file "lib/commons-collections-3.2.1.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/MVEL-fork.jar
The file "lib/MVEL-fork.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/nebula-cwt.jar
The file "lib/nebula-cwt.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/nebula-cdatetime.jar
The file "lib/nebula-cdatetime.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/commons-beanutils-1.8.0.jar
The file "lib/commons-beanutils-1.8.0.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/commons-digester-2.0.jar
The file "lib/commons-digester-2.0.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/commons-lang-2.5.jar
The file "lib/commons-lang-2.5.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/commons-io-2.0.1.jar
The file "lib/commons-io-2.0.1.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/guava-13.0.1.jar
The file "lib/guava-13.0.1.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/commons-primitives-1.0.jar
The file "lib/commons-primitives-1.0.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/commons-logging-1.1.1.jar
The file "lib/commons-logging-1.1.1.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Problems downloading artifact: osgi.bundle,org.eclipse.wb.rcp.swing2swt,1.8.0.r45x201412090039.
File has invalid content:C:\Users\Vincenzo\AppData\Local\Temp\signatureFile7710241417194737139.jar
Invalid content:swing2swt.jar
The file "swing2swt.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile7710241417194737139.jar" has been tampered!
Problems downloading artifact: osgi.bundle,org.eclipse.wb.runtime.lib,1.8.0.r45x201412082350.
File has invalid content:C:\Users\Vincenzo\AppData\Local\Temp\signatureFile108906935212993756.jar
Invalid content:lib/cglib-nodep-2.2.jar
The file "lib/cglib-nodep-2.2.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile108906935212993756.jar" has been tampered!
Re: WindowBuilder does not install on Mars SR3 [message #1697026 is a reply to message #1697009] Sun, 31 May 2015 12:38 Go to previous messageGo to next message
RC3 changed the packaging rules for plugins, so we need to change the WB build to comply with those changes.
Use RC2 until we have a compatible build.
Re: WindowBuilder does not install on Mars SR3 [message #1697046 is a reply to message #1697026] Mon, 01 June 2015 04:11 Go to previous messageGo to next message
Thank you Eric!
I'll keep using RC2a for a while.
Where can I stay tuned (this post? official WB page?) in order to be notified as soon as the WB build is back again on track ?
Thank you very much for the answer and for the your huge great work on WB!!!
Cheers
Vincenzo
Re: WindowBuilder does not install on Mars SR3 [message #1697095 is a reply to message #1697046] Mon, 01 June 2015 10:24 Go to previous message
We'll reply to this post once it's available.
Previous Topic:Design view showing exceptions
Next Topic:Window Builder causes a copy of the project to run, and it will not close?
Current Time: Thu Jul 24 22:10:10 EDT 2025
Powered by FUDForum. Page generated in 0.05234 seconds
