Re: Question [message #1696988 is a reply to message #1696972] |
Sat, 30 May 2015 02:38  |
Jack,
Folks will mention the sticky post at the top of the forum:
https://www.eclipse.org/forums/index.php/t/198527/
If you use the new Oomph installer (available for the upcoming Mars
release, but it's able to install a Luna version)
https://www.eclipse.org/downloads/index-developer-default.php
It would have directed you to this page:
http://download.eclipse.org/oomph/jre/?vm=3_1_7_0_64
I.e., you need to install a JRE. Note that the installer will detect
all the JREs you have installed on your system and make sure your
installed package uses it.
On 30/05/2015 7:20 AM, Jack Herrmann wrote:
> Hi there! I'm new to this sort of thing. I'm looking to develop
> plugins for minecraft, I found this download as a recommended tool and
> it doesn't seem to work for me... I downloaded the Eclipse Java IDE 64
> bit and when it finished I extracted the files using 7-zip and opened
> the application. It then told me there is no Java Virtual Machine.
> Now, I have done some coding before but not with Java so I decided to
> try this and do what I could. Can someone please tell me how to fix this?
> Thank you for your time
FUDForum. Page generated in 0.07502 seconds
