Home » Eclipse Projects » WindowBuilder » Window Builder causes a copy of the project to run, and it will not close?(Whenever I load my GUI into the WindowBuilder, it creates a "ghost" copy of the project that will not close.)
icon9.gif  Window Builder causes a copy of the project to run, and it will not close? [message #1696095] Thu, 21 May 2015 12:25 Go to next message
This is a strange error, or bug. It only started happening a couple of days ago after added my 8th tab into a JTabbedPane.
I *believe* it has such an issue because I have a large volume of code in the one file. I didn't really see a way to trim the code down for the GUI (Ex: by extending the GUI into a second class and building it there as well) and still be able to use the WindowBuilder.
Here is what it looks like (I moused over the icon on the start bar to show it's open in eclipse):
index.php/fa/21902/0/
(Sorry if this image isn't working right. I can't link images from not eclipse websites, and it doesn't seem to like the url supplied by the attachment)
If you look at the buttons, you'll see they look "disabled". However, they still seem to function as normal buttons. I also cannot close the window at all.
The "Update Server" button should close the GUI once the timer hits 0 (I enter a time, it counts to 0, closes) but nothing happens when it hits 0. I also cannot press the X to close it (I've tried, it does nothing).
Another issue with this is, sometimes when adding new components, the WindowBuilder will crash, and each time I tell it to reparse the code, it opens another ghost copy of the GUI..
If any other information is needed, please feel free to ask.
Note: I would rather not give out the source code (As this gui is tied into a rather large project) but if it is needed I'll supply what I can.
Re: Window Builder causes a copy of the project to run, and it will not close? [message #1696340 is a reply to message #1696095] Mon, 25 May 2015 17:47 Go to previous messageGo to next message
We need to see a test case and any relevant log files. Without that, I have no idea what the issue might be (or even if it is a WB issue or not).
Re: Window Builder causes a copy of the project to run, and it will not close? [message #1696844 is a reply to message #1696340] Thu, 28 May 2015 21:27 Go to previous messageGo to next message
Eric Clayberg wrote on Mon, 25 May 2015 21:47
I'm having a hard time linking any images, if you could help with that, that would be awesome.
Where would the log files be located for this? Or would there be a way to clean the log files (If any exist) and then generate new ones containing only the data from this issue.
Terribly sorry in my delay in responding.
Re: Window Builder causes a copy of the project to run, and it will not close? [message #1696931 is a reply to message #1696844] Fri, 29 May 2015 09:05 Go to previous messageGo to next message
There isn't anything I can do to help you post images. I don't even know what issue you might be having.
The Eclipse .log file is located in your Eclipse workspace .metadata directory.
You should create a standalone, self-contained test case that illustrates/triggers the problem.
Re: Window Builder causes a copy of the project to run, and it will not close? [message #1697003 is a reply to message #1696931] Sat, 30 May 2015 13:24 Go to previous messageGo to next message
The image error was 1 of 2 things:
1) If I linked an image using another domain (I.E: imgur) it would say that because I didn't have 5 posts, I can only link to something on the eclipse.org domain.
2) When attaching an image it gives me only a partial url, and does not display the image in the image tags..
Here is a log file from me doing the exact following:
-Ran eclipse
-Closed whatever files were open
-Opened the "ServerConsole" file in window builder (The ghost copy did appear)
-Closed eclipse.
I can't link to third party sites just yet, so I'll paste it here in tags, hoping it doesn't create a mile long page.
!SESSION 2015-05-29 07:25:52.539 -----------------------------------------------
eclipse.buildId=4.4.2.M20150204-1700
java.version=1.8.0_25
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments:  -product org.eclipse.epp.package.java.product
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.egit.ui 2 0 2015-05-29 07:26:07.842
!MESSAGE Warning: EGit couldn't detect the installation path "gitPrefix" of native Git. Hence EGit can't respect system level
Git settings which might be configured in ${gitPrefix}/etc/gitconfig under the native Git installation directory.
The most important of these settings is core.autocrlf. Git for Windows by default sets this parameter to true in
this system level configuration. The Git installation location can be configured on the
Team > Git > Configuration preference page's 'System Settings' tab.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!ENTRY org.eclipse.egit.ui 2 0 2015-05-29 07:26:07.845
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\Jesse'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
!ENTRY org.eclipse.pde.core 4 0 2015-05-29 07:27:52.189
!MESSAGE The current target platform contains errors, open Window > Preferences > Plug-in Development > Target Platform for details.
!STACK 1
org.eclipse.core.runtime.CoreException: Problems occurred getting the plug-ins in this container
	at org.eclipse.pde.internal.core.PluginModelManager.getExternalBundles(PluginModelManager.java:617)
	at org.eclipse.pde.internal.core.PluginModelManager.initializeTable(PluginModelManager.java:525)
	at org.eclipse.pde.internal.core.PluginModelManager.findModel(PluginModelManager.java:970)
	at org.eclipse.pde.core.plugin.PluginRegistry.findModel(PluginRegistry.java:110)
	at org.eclipse.wb.internal.core.utils.reflect.ReflectionUtils.invokeMethod(ReflectionUtils.java:869)
	at org.eclipse.wb.internal.core.utils.pde.ReflectivePDE.invokeStatic(ReflectivePDE.java:90)
	at org.eclipse.wb.internal.core.utils.pde.ReflectivePDE.findModel(ReflectivePDE.java:65)
	at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.addFragments(ProjectClassLoader.java:139)
	at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.addRuntimeClassPathEntries(ProjectClassLoader.java:127)
	at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.getClasspathUrls(ProjectClassLoader.java:73)
	at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.create(ProjectClassLoader.java:64)
	at org.eclipse.wb.internal.core.parser.AbstractParseFactory.createClassLoader_project(AbstractParseFactory.java:792)
	at org.eclipse.wb.internal.core.parser.AbstractParseFactory.getClassLoader(AbstractParseFactory.java:747)
	at org.eclipse.wb.internal.core.parser.AbstractParseFactory.initializeClassLoader(AbstractParseFactory.java:732)
	at org.eclipse.wb.internal.swing.parser.ParseFactory.initializeClassLoader(ParseFactory.java:282)
	at org.eclipse.wb.internal.swing.parser.ParseFactory.getRootContext(ParseFactory.java:106)
	at org.eclipse.wb.internal.core.parser.JavaInfoParser.prepareParseContext(JavaInfoParser.java:1182)
	at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:242)
	at org.eclipse.wb.internal.core.parser.JavaInfoParser.access$9(JavaInfoParser.java:238)
	at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:153)
	at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:1)
	at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runDesignTime(ExecutionUtils.java:159)
	at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:151)
	at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:534)
	at org.eclipse.wb.internal.core.editor.DesignPage.access$9(DesignPage.java:522)
	at org.eclipse.wb.internal.core.editor.DesignPage$8$1.run(DesignPage.java:449)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:187)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:156)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4734)
	at org.eclipse.wb.internal.core.editor.DesignPage$8.run(DesignPage.java:446)
	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:466)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:374)
	at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:527)
	at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF_withProgress(DesignPage.java:465)
	at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:415)
	at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:381)
	at org.eclipse.wb.internal.core.editor.UndoManager.activate(UndoManager.java:90)
	at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState_True(DesignPage.java:263)
	at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState(DesignPage.java:241)
	at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode.showPage(DefaultMultiMode.java:125)
	at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode$1.widgetSelected(DefaultMultiMode.java:63)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1070)
	at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:782)
	at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3110)
	at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1794)
	at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:283)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4172)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Contains: File does not exist: C:\Program Files\Eclipse\plugins\com.ibm.icu_52.1.0.v201404241930.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.apache.httpcomponents.httpclient_4.2.6.v201311072007.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.apache.httpcomponents.httpcore_4.2.5.v201311072007.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.apache.jasper.glassfish_2.2.2.v201205150955.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.api_1.0.0.v20140518.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.connector.basic_1.0.0.v20140518.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.impl_1.0.0.v20140518.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.maven_3.1.0.v20140524-1439.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.spi_1.0.0.v20140518.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.transport.file_1.0.0.v20140518.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.transport.http_1.0.0.v20140518.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.util_1.0.0.v20140518.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ant.core_3.3.0.v20140518-0042.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.compare_3.5.500.v20131106-1552.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.core.databinding_1.4.1.v20140214-0004.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.core.jobs_3.6.0.v20140424-0053.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.core.resources_3.9.0.v20140514-1307.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.cvs_1.4.100.v20140606-1215.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.debug.core_3.9.0.v20140521-1435.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.debug.ui_3.10.0.v20140604-1637.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.draw2d_3.9.100.201405261516.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.e4.core.services_1.2.0.v20140509-1840.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.e4.ui.css.swt_0.11.100.v20140522-1045.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.e4.ui.css.swt.theme_0.9.300.v20140424-2042.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.e4.ui.workbench_1.1.0.v20140528-1949.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.e4.ui.workbench.addons.swt_1.1.0.v20140602-1537.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.e4.ui.workbench.renderers.swt_0.12.0.v20140521-1818.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.e4.ui.workbench.swt_0.12.100.v20140530-1436.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf_3.4.0.v20140528-1625.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf.filetransfer_5.0.0.v20140528-1625.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf.identity_3.4.0.v20140528-1625.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf.provider.filetransfer_3.2.200.v20140528-1625.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf.provider.filetransfer.httpclient4_1.0.500.v20140528-1625.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf.provider.filetransfer.httpclient4.ssl_1.0.0.v20140528-1625.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf.provider.filetransfer.ssl_1.0.0.v20140528-1625.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf.ssl_1.1.0.v20140528-1625.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.egit_3.4.0.201406110918-r.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.egit.core_3.4.0.201406110918-r.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.egit.doc_3.4.0.201406110918-r.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.egit.mylyn.ui_3.4.0.201406110918-r.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.egit.ui_3.4.0.201406110918-r.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.common_2.10.0.v20140514-1158.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.common.ui_2.9.0.v20140519-0339.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.databinding_1.3.0.v20140519-0339.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.ecore_2.10.0.v20140514-1158.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.ecore.change_2.10.0.v20140514-1158.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.ecore.edit_2.9.0.v20140519-0339.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.ecore.xmi_2.10.0.v20140514-1158.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.edit_2.10.0.v20140519-0339.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.edit.ui_2.10.0.v20140519-0339.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.epp.mpc.core_1.3.0.v20140521-1611.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.epp.mpc.help.ui_1.3.0.v20140425-1404.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.epp.mpc.ui_1.3.0.v20140529-2031.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.epp.package.java_4.4.0.20140612-0500
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20140603-1326
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.equinox.p2.director.app_1.0.300.v20140228-1829.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.equinox.p2.publisher_1.3.0.v20140129-1408.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.gef_3.9.100.201405261516.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.help.base_4.0.200.v20140606-1215.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.help.webapp_3.6.300.v20140407-1855.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt_3.10.0.v20140606-1215.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.apt.core_3.3.600.v20140311-1758.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.compiler.apt_1.1.0.v20140509-1235.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.compiler.tool_1.0.300.v20140311-1758.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.core_3.10.0.v20140604-1726.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.debug_3.8.100.v20140522-1618
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.doc.user_3.10.0.v20140606-1536.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.launching_3.7.100.v20140428-1912.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.ui_3.10.0.v20140604-1403.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jem.util_2.1.200.v201404021815.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jetty.continuation_8.1.14.v20131031.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jetty.http_8.1.14.v20131031.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jetty.io_8.1.14.v20131031.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jetty.security_8.1.14.v20131031.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jetty.server_8.1.14.v20131031.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jetty.servlet_8.1.14.v20131031.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jetty.util_8.1.14.v20131031.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jface_3.10.0.v20140604-0740.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jface.text_3.9.0.v20140521-1657.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jgit_3.4.0.201406110918-r.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jgit.archive_3.4.0.201406110918-r.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ltk.core.refactoring_3.6.100.v20140520-1248.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.archetype.common_1.5.0.20140605-2032
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.core_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.core.ui_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.discovery_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.editor_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.editor.xml_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.jdt_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.jdt.ui_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.launching_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.lifecyclemapping.defaults_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.logback.appender_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.logback.configuration_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.maven.indexer_1.5.0.20140605-2032
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.maven.runtime_1.5.0.20140605-2032
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.maven.runtime.slf4j.simple_1.5.0.20140605-2032
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.model.edit_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.profiles.core_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.profiles.ui_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.refactoring_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.scm_1.5.0.20140606-0033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.bugzilla.core_3.12.0.v20140522-1837.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.bugzilla.ide_3.12.0.v20140328-2338.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.bugzilla.ui_3.12.0.v20140401-2350.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.builds.core_1.4.0.v20140328-2337.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.builds.ui_1.4.0.v20140328-2337.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.core_3.12.0.v20140405-2305.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.identity.core_1.4.0.v20140331-0927.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.net_3.12.0.v20140404-1455.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.notifications.core_1.4.0.v20140331-0927.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.notifications.feed_1.4.0.v20140331-0927.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.notifications.ui_1.4.0.v20140331-0927.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.repositories.core_1.4.0.v20140331-0927.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.repositories.http.core_1.4.0.v20140515-1744.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.repositories.ui_1.4.0.v20140331-0927.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.screenshots_3.12.0.v20140331-0927.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.ui_3.12.0.v20140402-2209.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.workbench_3.12.0.v20140411-2206.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.xmlrpc_3.12.0.v20140331-0927.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.context.core_3.12.0.v20140328-2338.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.context.tasks.ui_3.12.0.v20140328-2338.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.context.ui_3.12.0.v20140423-0309.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.cvs.core_1.4.0.v20140402-0752.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.debug.ui_3.12.0.v20140328-2338.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.discovery.core_3.12.0.v20140331-0927.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.discovery.ui_3.12.0.v20140512-2018.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.git.core_1.4.0.v20140402-0752.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.git.ui_1.4.0.v20140402-0752.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.help.ui_3.12.0.v20140523-2010.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.hudson.core_1.4.0.v20140416-0043.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.hudson.ui_1.4.0.v20140520-2249.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.ide.ant_3.12.0.v20140328-2338.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.ide.ui_3.12.0.v20140328-2338.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.java.tasks_3.12.0.v20140328-2338.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.java.ui_3.12.0.v20140328-2338.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.monitor.core_3.12.0.v20140331-0927.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.monitor.ui_3.12.0.v20140331-0927.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.resources.ui_3.12.0.v20140412-1836.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.tasks.bugs_3.12.0.v20140401-2350.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.tasks.core_3.12.0.v20140522-2107.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.tasks.index.core_3.12.0.v20140401-2350.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.tasks.index.ui_3.12.0.v20140401-2350.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.tasks.search_3.12.0.v20140401-2350.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.tasks.ui_3.12.0.v20140521-2340.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.team.cvs_3.12.0.v20140328-2338.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.team.ui_3.12.0.v20140507-1810.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.versions.core_1.4.0.v20140402-0752.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.versions.ui_1.4.0.v20140402-0752.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.confluence.core_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.confluence.ui_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.context.ui_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.core_2.1.0.v20140513-1929.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.core.ant_2.1.0.v20140604-1911.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.core.osgi_2.1.0.v20140604-1911.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.help.ui_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.html.core_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.markdown.core_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.markdown.ui_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.mediawiki.core_2.1.0.v20140513-1949.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.mediawiki.ui_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.tasks.ui_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.textile.core_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.textile.ui_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.tracwiki.core_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.tracwiki.ui_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.twiki.core_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.twiki.ui_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.wikitext.ui_2.1.0.v20140325-2210.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.osgi_3.10.0.v20140606-1445.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.osgi.compatibility.state_1.0.0.v20140403-1907.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.platform_4.4.0.v20140606-1215
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.platform.doc.user_4.4.0.v20140606-1558.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.rcp_4.3.100.v20140606-1215.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.apidocs_2.1.0.v20140526-1706.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.apidocs.rcp_2.1.0.v20140526-1706.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.calls_2.1.0.v20140527-1146.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.calls.rcp_2.1.0.v20140528-0741.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.chain.rcp_2.1.0.v20140527-1146.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.completion.rcp_2.1.0.v20140610-1533.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.injection_2.1.0.v20140526-1706.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.jayes_2.1.0.v20140526-1706.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.jayes.io_2.1.0.v20140526-1706.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.models_2.1.0.v20140526-1706.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.models.rcp_2.1.0.v20140602-1202.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.overrides_2.1.0.v20140526-1706.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.overrides.rcp_2.1.0.v20140526-1706.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.rcp_2.1.0.v20140610-1852.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.subwords.rcp_2.1.0.v20140608-1213.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.recommenders.utils_2.1.0.v20140527-1146.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.swt_3.103.0.v20140605-2008.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.swt.win32.win32.x86_64_3.103.0.v20140605-2012.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ui_3.106.0.v20140519-0906.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ui.ide_3.10.0.v20140521-1937.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ui.ide.application_1.0.500.v20140514-2033.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ui.intro.universal_3.2.700.v20130904-1701
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ui.navigator_3.5.400.v20140210-1835.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ui.themes_1.0.0.v20140604-1608
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ui.workbench_3.106.0.v20140530-0732.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.common.core_1.2.0.v200908252030.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.common.emf_1.2.200.v201301171800.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.common.emfworkbench.integration_1.2.101.v201107140600.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.common.environment_1.0.400.v200912181832.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.common.frameworks_1.2.200.v201203141800.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.common.frameworks.ui_1.2.300.v201401292115.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.common.infopop_1.0.300.v201004280700.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.common.modulecore_1.2.400.v201402071700.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.common.modulecore.ui_1.0.201.v201208241600.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.common.project.facet.core_1.4.300.v201111030424.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.common.snippets_1.2.200.v201204260225.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.common.ui_1.1.500.v200911190730.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.common.uriresolver_1.2.100.v201305141800.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.dtd.core_1.1.700.v201210082138.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.dtd.ui_1.0.801.v201308100603.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.dtd.ui.infopop_1.0.400.v201008112018.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.dtdeditor.doc.user_1.0.700.v201008112018.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.internet.cache_1.0.600.v201203071939.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.server.core_1.6.0.v20140428_1751.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.sse.core_1.1.900.v201401101615.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.sse.doc.user_1.1.100.v201005192212.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.sse.ui_1.3.300.v201404240319.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.sse.ui.infopop_1.0.300.v201004150328.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.standard.schemas_1.0.700.v201304171716.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.validation_1.2.501.v201311151800.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.validation.infopop_1.0.300.v200806041506.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.validation.ui_1.2.500.v201310231530.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.xml.core_1.1.900.v201404240330.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.xml.ui_1.1.500.v201403122203.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.xml.ui.infopop_1.0.400.v201004292007.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.xmleditor.doc.user_1.0.700.v201005192212.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.xsd.core_1.1.900.v201401141907.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.xsd.ui_1.2.500.v201203081826.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.wst.xsdeditor.doc.user_1.0.800.v201005192212.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.xsd_2.10.0.v20140519-0339.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.xsd.edit_2.7.0.v20140519-0339.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.apache.commons.codec.source_1.6.0.v201305230611.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.apache.commons.logging.source_1.1.1.v201101211721.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.apache.httpcomponents.httpclient.source_4.2.6.v201311072007.jar
Contains: File does not exist: C:\Program Files\Eclipse\plugins\org.apache.httpcomponents.httpcore.source_4.2.5.v201311072007.jar
!SUBENTRY 1 org.eclipse.pde.core 4 0 2015-05-29 07:27:52.200
!MESSAGE Problems occurred getting the plug-ins in this container
!SUBENTRY 2 org.eclipse.pde.core 4 0 2015-05-29 07:27:52.200
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\com.ibm.icu_52.1.0.v201404241930.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.apache.httpcomponents.httpclient_4.2.6.v201311072007.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.apache.httpcomponents.httpcore_4.2.5.v201311072007.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.apache.jasper.glassfish_2.2.2.v201205150955.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.api_1.0.0.v20140518.jar
!SUBENTRY 2 org.eclipse.pde.core 4 0 2015-05-29 07:27:52.201
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.connector.basic_1.0.0.v20140518.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.impl_1.0.0.v20140518.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.maven_3.1.0.v20140524-1439.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.spi_1.0.0.v20140518.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.transport.file_1.0.0.v20140518.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.transport.http_1.0.0.v20140518.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.aether.util_1.0.0.v20140518.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ant.core_3.3.0.v20140518-0042.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.compare_3.5.500.v20131106-1552.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.core.databinding_1.4.1.v20140214-0004.jar
!SUBENTRY 2 org.eclipse.pde.core 4 0 2015-05-29 07:27:52.202
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.core.jobs_3.6.0.v20140424-0053.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.core.resources_3.9.0.v20140514-1307.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.cvs_1.4.100.v20140606-1215.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.debug.core_3.9.0.v20140521-1435.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.debug.ui_3.10.0.v20140604-1637.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.draw2d_3.9.100.201405261516.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.e4.core.services_1.2.0.v20140509-1840.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.e4.ui.css.swt_0.11.100.v20140522-1045.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.e4.ui.css.swt.theme_0.9.300.v20140424-2042.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.e4.ui.workbench_1.1.0.v20140528-1949.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.e4.ui.workbench.addons.swt_1.1.0.v20140602-1537.jar
!SUBENTRY 2 org.eclipse.pde.core 4 0 2015-05-29 07:27:52.203
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.e4.ui.workbench.renderers.swt_0.12.0.v20140521-1818.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.e4.ui.workbench.swt_0.12.100.v20140530-1436.jar
!SUBENTRY 2 org.eclipse.pde.core 4 0 2015-05-29 07:27:52.204
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf_3.4.0.v20140528-1625.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf.filetransfer_5.0.0.v20140528-1625.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf.identity_3.4.0.v20140528-1625.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf.provider.filetransfer_3.2.200.v20140528-1625.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf.provider.filetransfer.httpclient4_1.0.500.v20140528-1625.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf.provider.filetransfer.httpclient4.ssl_1.0.0.v20140528-1625.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf.provider.filetransfer.ssl_1.0.0.v20140528-1625.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ecf.ssl_1.1.0.v20140528-1625.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.egit_3.4.0.201406110918-r.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.egit.core_3.4.0.201406110918-r.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.egit.doc_3.4.0.201406110918-r.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.egit.mylyn.ui_3.4.0.201406110918-r.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.egit.ui_3.4.0.201406110918-r.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.common_2.10.0.v20140514-1158.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.common.ui_2.9.0.v20140519-0339.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.databinding_1.3.0.v20140519-0339.jar
!SUBENTRY 2 org.eclipse.pde.core 4 0 2015-05-29 07:27:52.205
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.ecore_2.10.0.v20140514-1158.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.ecore.change_2.10.0.v20140514-1158.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.ecore.edit_2.9.0.v20140519-0339.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.ecore.xmi_2.10.0.v20140514-1158.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.edit_2.10.0.v20140519-0339.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.emf.edit.ui_2.10.0.v20140519-0339.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.epp.mpc.core_1.3.0.v20140521-1611.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.epp.mpc.help.ui_1.3.0.v20140425-1404.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.epp.mpc.ui_1.3.0.v20140529-2031.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.epp.package.java_4.4.0.20140612-0500
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20140603-1326
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.equinox.p2.director.app_1.0.300.v20140228-1829.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.equinox.p2.publisher_1.3.0.v20140129-1408.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.gef_3.9.100.201405261516.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.help.base_4.0.200.v20140606-1215.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.help.webapp_3.6.300.v20140407-1855.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt_3.10.0.v20140606-1215.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.apt.core_3.3.600.v20140311-1758.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.compiler.apt_1.1.0.v20140509-1235.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.compiler.tool_1.0.300.v20140311-1758.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.core_3.10.0.v20140604-1726.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.debug_3.8.100.v20140522-1618
!SUBENTRY 2 org.eclipse.pde.core 4 0 2015-05-29 07:27:52.206
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.doc.user_3.10.0.v20140606-1536.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.launching_3.7.100.v20140428-1912.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jdt.ui_3.10.0.v20140604-1403.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jem.util_2.1.200.v201404021815.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jetty.continuation_8.1.14.v20131031.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jetty.http_8.1.14.v20131031.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jetty.io_8.1.14.v20131031.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jetty.security_8.1.14.v20131031.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jetty.server_8.1.14.v20131031.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jetty.servlet_8.1.14.v20131031.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jetty.util_8.1.14.v20131031.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jface_3.10.0.v20140604-0740.jar
!SUBENTRY 2 org.eclipse.pde.core 4 0 2015-05-29 07:27:52.207
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jface.text_3.9.0.v20140521-1657.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jgit_3.4.0.201406110918-r.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.jgit.archive_3.4.0.201406110918-r.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.ltk.core.refactoring_3.6.100.v20140520-1248.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.archetype.common_1.5.0.20140605-2032
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.core_1.5.0.20140606-0033.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.core.ui_1.5.0.20140606-0033.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.discovery_1.5.0.20140606-0033.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.editor_1.5.0.20140606-0033.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.editor.xml_1.5.0.20140606-0033.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.jdt_1.5.0.20140606-0033.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.jdt.ui_1.5.0.20140606-0033.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.launching_1.5.0.20140606-0033.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.lifecyclemapping.defaults_1.5.0.20140606-0033.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.logback.appender_1.5.0.20140606-0033.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.logback.configuration_1.5.0.20140606-0033.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.maven.indexer_1.5.0.20140605-2032
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.maven.runtime_1.5.0.20140605-2032
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.maven.runtime.slf4j.simple_1.5.0.20140605-2032
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.model.edit_1.5.0.20140606-0033.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.profiles.core_1.5.0.20140606-0033.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.profiles.ui_1.5.0.20140606-0033.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.refactoring_1.5.0.20140606-0033.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.m2e.scm_1.5.0.20140606-0033.jar
!SUBENTRY 2 org.eclipse.pde.core 4 0 2015-05-29 07:27:52.208
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.bugzilla.core_3.12.0.v20140522-1837.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.bugzilla.ide_3.12.0.v20140328-2338.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.bugzilla.ui_3.12.0.v20140401-2350.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.builds.core_1.4.0.v20140328-2337.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.builds.ui_1.4.0.v20140328-2337.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.core_3.12.0.v20140405-2305.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.identity.core_1.4.0.v20140331-0927.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.net_3.12.0.v20140404-1455.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.notifications.core_1.4.0.v20140331-0927.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.notifications.feed_1.4.0.v20140331-0927.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.notifications.ui_1.4.0.v20140331-0927.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.repositories.core_1.4.0.v20140331-0927.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.repositories.http.core_1.4.0.v20140515-1744.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.repositories.ui_1.4.0.v20140331-0927.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.screenshots_3.12.0.v20140331-0927.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.ui_3.12.0.v20140402-2209.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.workbench_3.12.0.v20140411-2206.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.commons.xmlrpc_3.12.0.v20140331-0927.jar
!SUBENTRY 2 org.eclipse.pde.core 4 0 2015-05-29 07:27:52.209
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.context.core_3.12.0.v20140328-2338.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.context.tasks.ui_3.12.0.v20140328-2338.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.context.ui_3.12.0.v20140423-0309.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.cvs.core_1.4.0.v20140402-0752.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.debug.ui_3.12.0.v20140328-2338.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.discovery.core_3.12.0.v20140331-0927.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.discovery.ui_3.12.0.v20140512-2018.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.git.core_1.4.0.v20140402-0752.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.git.ui_1.4.0.v20140402-0752.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.help.ui_3.12.0.v20140523-2010.jar
!MESSAGE File does not exist: C:\Program Files\Eclipse\plugins\org.eclipse.mylyn.hudson.core_1.4.0.v20140416-0043.jar
!SUBENTRY 2 org.e
[Updated on: Sat, 30 May 2015 14:24] by Moderator
Re: Window Builder causes a copy of the project to run, and it will not close? [message #1697027 is a reply to message #1697003] Sun, 31 May 2015 12:41 Go to previous messageGo to next message
Based on all the "File does not exist" errors, it looks like your Eclipse installation has a problem of some sort.
A clean install of Eclipse and WB would be a good start.
I guess you can post images after you reach 5 posts to the forum.
Re: Window Builder causes a copy of the project to run, and it will not close? [message #1697290 is a reply to message #1697027] Tue, 02 June 2015 19:05 Go to previous messageGo to next message
So I did a clean install of both eclipse and WindowBuilder, fixed the two Git related errors, then deleted the log file.
I then re-ran eclipse and opened up the file in WindowBuilder, and it still caused a copy of it to run like before.. But it did not generate a new log file.
Re: Window Builder causes a copy of the project to run, and it will not close? [message #1697296 is a reply to message #1697290] Tue, 02 June 2015 22:51 Go to previous message
Previous Topic:WindowBuilder does not install on Mars SR3
Next Topic:WB causes Eclipse to hang after closing Preview window
Current Time: Wed Jul 23 13:25:34 EDT 2025
Powered by FUDForum. Page generated in 0.08939 seconds
