Home » Modeling » Papyrus » Code / model syncrhonization feature
Code / model syncrhonization feature [message #1696708] Thu, 28 May 2015 03:16 Go to next message
Is there code / model synchronization feature (real time or not) ?
- Eclipse Luna 4.4.2
- Papyrus 1.0.2
- java code generation
thanks,
regards
Re: Code / model syncrhonization feature [message #1696760 is a reply to message #1696708] Thu, 28 May 2015 08:54 Go to previous messageGo to next message
There is a Java reverse-engineering capability available as an extra
component. Try the "Help -> Install Papyrus Additional Components"
menu action and install it from that dialog.
HTH,
Christian
On 2015-05-28 07:17:00 +0000, Missing name Mising name said:
> - Papyrus 1.0.2
> thanks,
> regards
Re: Code / model syncrhonization feature [message #1696859 is a reply to message #1696760] Fri, 29 May 2015 02:36 Go to previous message
As Christian said, there is a Java reverse tool, and also Java code
generator. Both are available as additional components.
Documentation is available in Papyrus wiki:
- http://wiki.eclipse.org/Java_reverse_engineering
- http://wiki.eclipse.org/Java_Code_Generation
Once installed, you can reverse classes by draging them from Eclipse
explorer and drop them into a Papyrus Class diagram.
Hope this help,
Cedric
Christian W. Damus a écrit :
> component. Try the "Help -> Install Papyrus Additional Components" menu
> HTH,
> Christian
>> Hi,
>> - Papyrus 1.0.2
>> thanks,
>> regards
Previous Topic:Deploying Component Instances
Next Topic:How to override the "delete" and "save" strategy
Current Time: Wed Jul 23 16:17:19 EDT 2025
Powered by FUDForum. Page generated in 0.15071 seconds
