Home » Modeling » EMF » Eclipse reflective API editor does not open generated xmi model file(XMIResourceFactoryImpl does not add two attributes, namely xmlns:xsi and xsi:schemaLocation to my xmi file)
Eclipse reflective API editor does not open generated xmi model file [message #1696660] Wed, 27 May 2015 12:44 Go to next message
I have generated .genmodel from an ecore file and then generated java code using this genmodel. Then I use XMIResourceFactoryImpl to persist my model file (guided by this online article). the code I am using is as bellow:
UnivPackage.eINSTANCE.eClass();
Resource.Factory.Registry reg = Resource.Factory.Registry.INSTANCE;
Map<String, Object> m = reg.getExtensionToFactoryMap();
m.put("xmi", new XMIResourceFactoryImpl() );
ResourceSet resSet = new ResourceSetImpl();
Resource resource = resSet.createResource(URI.createURI("MyModel.xmi"));
UnivFactory f=UnivFactory.eINSTANCE;
UnivModel univ=f.createUnivModel();
for (int i = 10; i < 20; i+=5) {
	Person p=f.createPerson();
	p.setName("John"+i);
	p.setAge(i);
	univ.getElements().add(p);
resource.getContents().add(univ);
try {
	resource.save(null);
} catch (IOException e) {}
Running the above code generates an xmi file as bellow:
<?xml version="1.0" encoding="ASCII"?>
<univ:UnivModel
	xmi:version="2.0"
	xmlns:univ="http://gholizadeh.net/univ-v1">
  <elements age="10" name="John10"/>
  <elements age="15" name="John15"/>
</univ:UnivModel>
When I am opening this xmi file using Sample Reflective Ecore Model editor eclipse STOPs responding. It seems it is going to search for something and can not find it.
However, when I follow "rightclick on ecore file > create dynamic instance" inside eclipse and create an xmi model file, I can get the following xmi file:
<univ:UnivModel
    xmi:version="2.0"
    xsi:schemaLocation="http://gholizadeh.net/univ-v1 univ.ecore">
</univ:UnivModel>
This file is well handled by Sample Reflective Ecore Model editor (i.e., I can open the file and add objects, and save it and ...).
Comparing two of the above xmi files, reveals that I am missing two attributes in the first xmi file root, namely "xmlns:xsi" and "xsi:schemaLocation".
My Questions:
1) How can I force "XMIResourceFactoryImpl" to put these two options (i.e., "xmlns:xsi" and "xsi:schemaLocation") in the root of my xmi model file when creating it from code.
2) When I am missing these attributes in my xmi file, and try to open such an xmi file with Sample Reflective Ecore Model editor, why Eclipse stops responding? I have to quit eclipse and reopen it again. I expect that eclipse relinquish trying if it can not open the file, and then come up with a dialogue reporting the problem. But it gets stuck for ever!
[Updated on: Wed, 27 May 2015 16:49] by Moderator
Re: Eclipse reflective API editor does not open generated xmi model file [message #1696727 is a reply to message #1696660] Thu, 28 May 2015 05:01 Go to previous messageGo to next message
Hamid,
Comments below.
On 27/05/2015 6:44 PM, Hamid Qartal wrote:
> I have generated .genmodel from an ecore file and generated java code
> http://www.vogella.com/tutorials/EclipseEMFPersistence/article.html).
Using a relative URI as a resource's URI is generally a bad idea.
> p.setAge(i);
> try {
> <univ:UnivModel xmi:version="2.0"
> xmlns:xmi="http://www.omg.org/XMI"
> </univ:UnivModel>
It will use the namespace itself as a schema location and try to
download an Ecore model from it.
> following xmi file:
> <univ:UnivModel
> xmi:version="2.0"
> </univ:UnivModel>
> My Questions:
> (i.e., "xmlns:xsi" and "xsi:schemaLocation") in my xmi file when
org.eclipse.emf.ecore.xmi.XMLResource.OPTION_SCHEMA_LOCATION should be
set to true in the resources save options
> 2) When I am missing these attribute in my xmi file, and try to open
> I expect that eclipse relinquish trying, if it can not open the file,
> and then come up with a dialogue reporting it. But it stucks for ever!
I'd expect the internet access to timeout at some point, eventually.
Re: Eclipse reflective API editor does not open generated xmi model file [message #1696730 is a reply to message #1696727] Thu, 28 May 2015 05:29 Go to previous message
A bug was fixed about five years ago whereby a bad intenet access was
re-attempted for each proxy that targetted it. For even modest size
files this could make it seem like it took forever.
The failure is now cached so that it should only occur once, and should
timeout typically within 30 seconds.
If you have a repro, please raise a BUgzilla.
Ed Willink
Previous Topic:[xcore] Couldn't resolve reference to GenBase 'EDiagnositicChain'
Next Topic:An Ecore file whose instances are other Ecore files
Current Time: Sat Jul 19 04:54:12 EDT 2025
Powered by FUDForum. Page generated in 0.07373 seconds
