Home » Eclipse Projects » Target Management » RSE ssh connections FAIL unless remotes' sshd_config has weak Ciphers/MACs ? Why?
RSE ssh connections FAIL unless remotes' sshd_config has weak Ciphers/MACs ? Why? [message #1696261] Sun, 24 May 2015 13:15 Go to next message
I'm setting up Eclipse Luna as a new IDE for a small team.
It's an all-Linux environment, and site-to-site comms are typically SSH, with ciphers, macs & kexalgorithms tightened up -- using elliptical ciphers and higher bit algos in general.
On the Eclipse end of things, I've setup its Remote System Explorer (RSE) toolkit for access to/across multiple sites.
I've found that unless I 'dumb down' the remotes' sshd_config, to include weaker "Ciphers+=aes128-ctr" & "MACs+=hmac-md5", Eclipse RSE fails on the connection.
With those ^^ config opts, the connection opens without error; without those opts, no connection.
I suspect (?) this has to do with Java's encryption layer / config, but don't know.
Is this a missing/wrong CONFIG issue on my end, or a limitation of Eclipse?
Bob
Re: RSE ssh connections FAIL unless remotes' sshd_config has weak Ciphers/MACs ? Why? [message #1696656 is a reply to message #1696261] Wed, 27 May 2015 12:31 Go to previous messageGo to next message
Hi Bob,
Eclipse comes with com.jcraft.jsch_0.1.51 for its SSH support, and some newer algorithms (including ECC) have only been added in 0.1.52:
http://www.jcraft.com/jsch/ChangeLog
see here for the complete list of algorithms supported in Jsch:
If you think that JSch should support even different Ciphers, I suggest you sign up on the JSch mailing list:
https://lists.sourceforge.net/lists/listinfo/jsch-users
If you think that Eclipse should update to JSch-0.1.52, I suggest that you file a bug against Platform/Team where you argue why this is necessary:
https://bugs.eclipse.org/bugs/enter_bug.cgi?component=Team&product=Platform&version=4.5
Martin
Re: RSE ssh connections FAIL unless remotes' sshd_config has weak Ciphers/MACs ? Why? [message #1696664 is a reply to message #1696656] Wed, 27 May 2015 13:38 Go to previous message
First 'swipe' at it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=468518
Previous Topic:Project Status and Plan ?
Next Topic:How to open a session on the local system with Terminal 3.3
Current Time: Sun Jul 27 01:57:18 EDT 2025
Powered by FUDForum. Page generated in 0.04691 seconds
