[SOLVED] Startup trigger not executed [message #1696553] |
Wed, 27 May 2015 04:48  |
I created a setup profile at home and it worked as expected.
Now I tried to use the same profile on my company PC and - whatever I try - after the successful setup and the automatic launch of the IDE the startup task of the Oomph install is not executed. If I trigger it manually (perform setup task), the dialog lists no tasks. And in the list of profiles only the predefined ones are listed (User, Workspace, Installation). My setup profile is missing.
Can you give me a hint on how to solve this problem?
Thanks in advance.
Dieter
[Updated on: Thu, 28 May 2015 10:57] by Moderator
Re: Startup trigger not executed [message #1696559 is a reply to message #1696553] |
Wed, 27 May 2015 05:18   |
Dieter,
Comments below.
On 27/05/2015 10:48 AM, Dieter Scholz wrote:
By profile you mean you have a project setup?
Where is the setup stored? In your git repository? You're adding it to
one of the project catalogs?
In this use case, you've chosen your project on the projects page? And
in the confirmation page you see evidence that the p2 task is installing
additional things (if there are any).
If you ask it to show all tasks, including the ones that don't need to
perform, is there still no evidence of your project there?
If you open the workspace setup, doe it show your project as one of the
stream for the workspace's properties?
Not yet. It's not clear what you've done... I'll need to understand
what your Workspace setup looks like. Your project should be referenced
there...
> Thanks in advance.
> Dieter
Re: Startup trigger not executed [message #1696593 is a reply to message #1696577] |
Wed, 27 May 2015 08:18   |
Ed,
Comments below.
>> I'm sorry, but I do not understand your answer (all my fault because probably I do not completely overlook how the Oomph installer works).
>> Ok. I created a setup file (p2 and some changed preferences - see attached file). Then I use this file with the installer.
>So you added it to the project catalog on the project page so that you
>could use it with the install?
Correct. I dropped it into the product selection page.
>> At home - after the installer finished and the IDE is started - the icon for the startup task appears. That's not the case when I execute the same file in my company environment.
>When you perform manually on the Confirmation page, and you choose "Show
>all triggered tasks", are the tasks you're expecting really not listed
>there?
I've added three screenshots (summary of installer, toolbar of installed IDE & 'Perform setup task dialog' of installed IDE).
>> I don't understand what that has to do with my workspace and a project I should reference. Can you please explain that to me? Thanks.
>> I attached the setup log, too.
>It looks like it installed all the extra things you've specified.
>Perhaps the state of your workspace already matches all these
>preferences and there really is nothing to do. In that case you won't
>see any startup tasks performed.
The plugins are available but all my preference settings are not applied.
Dieter
Attachment: oomph1.png
(Size: 51.59KB, Downloaded 166 times)
Attachment: oomph2.png
(Size: 3.92KB, Downloaded 159 times)
Attachment: oomph3.png
(Size: 38.50KB, Downloaded 181 times)
Re: Startup trigger not executed [message #1696617 is a reply to message #1696593] |
Wed, 27 May 2015 09:47   |
Dieter,
Comments below.
On 27/05/2015 2:18 PM, Dieter Scholz wrote:
> Ed,
> Comments below.
You mean Project page? The product page isn't extensible via drag and
drop. Which Project catalog did you add it to? Then you double
clicked on it and it appeared in the bottom stream table at the bottom
of the Project page?
>> there?
It certainly looks like this installation's workspace is not aware of
you having added any setup projects to it. Can use the menu you
showed to Open Workspace to open the workspace setup. You can use the
context menu to "Open in Text Editor" and paste what you see textually.
There should be at least one element at the end like this:
<stream
href="index:/org.eclipse.setup#//@projectCatalogs[name='org.eclipse']/@projects[name='oomph']/@streams[name='master']"/>
I.e., the workspace setup should reference the stream of your setup project.
No, and from what you show, the workspace's setup doesn't appear to be
aware of your project...
> Dieter
Re: Startup trigger not executed [message #1696798 is a reply to message #1696796] |
Thu, 28 May 2015 11:13  |
Dieter,
I'm glad to hear it's resolved. Sorry it took so many cycles...
On 28/05/2015 5:03 PM, Dieter Scholz wrote:
> Ed,
> thanks for your help and patience.
> In the end it was a Windows problem. We use roaming profiles in our
> company. Because of reasons I do not understand there are two .eclipse
> folders. One on a network share and a local one. And the content of
> these folders was different.
> I copied one into the other and - voila - it works.
> So again thank you.
> Dieter
FUDForum. Page generated in 0.09230 seconds
