Home » Modeling » GMF (Graphical Modeling Framework) » Double connection
Double connection [message #169651] Thu, 24 January 2008 06:05 Go to next message
Originally posted by: andia.maleki.gmail.com
i would like to know, how it is possible to create a connection (by user)
and at the same time create another connection (programaticly)with
opposite direction. i mean junst change source and target.
Thanks in advance,
Andy
Re: Double connection [message #169684 is a reply to message #169651] Thu, 24 January 2008 09:57 Go to previous messageGo to next message
i extended the AbstractEdithHelperAdvice and implemented
getAfterCreateRelationshipCommand, and installed it via the elementTypes
extension point:
<extension point="org.eclipse.gmf.runtime.emf.type.core.elementTypes">
<metamodel nsURI="tam">
<specializationType
id="com.sap.mi.gmf.tam.diagram.Modify1_3007"
name="%metatype.name.Modify1_3007"
kind="org.eclipse.gmf.runtime.emf.type.core.IHintedType"
edithelperadvice="com.sap.mi.gmf.tam.implemented.ModifyAdvice ">
<specializes
id="org.eclipse.gmf.runtime.emf.type.core.null"/>
<param name="semanticHint" value="3007"/>
</specializationType>
</metamodel>
</extension>
but the method getAfterCreateRelationshipCommand is not called? did i miss
anything?
Andy
Re: Double connection [message #169749 is a reply to message #169651] Thu, 24 January 2008 11:34 Go to previous messageGo to next message
Originally posted by: trommas.yahoo.com
Andy wrote:
> user) and at the same time create another connection (programaticly)with
If it is an opposite relation, you only have to make sure that you have
both defined in the gmfgraph. If you want to create others, I'd suggest
using a command.
HTH,
Tomas Zijdemans
Re: Double connection [message #169765 is a reply to message #169749] Thu, 24 January 2008 11:46 Go to previous message
I have already defined an opposite connection in gmfgraph, but the problem
is that getAfterCreateRelationshipCommand is not called, so i cant call
the Modify2CreateCommand !
Previous Topic:Getting an IAdaptable from an EObject
Next Topic:How to provide DND from TreeViewer to GMF generated Editor?
Current Time: Fri Jul 25 19:04:33 EDT 2025
Powered by FUDForum. Page generated in 0.04936 seconds
