Home » Newcomers » Newcomers » Eclipse viewpart showing too much elements(Plugin viewpart shows elements from another view.)
Eclipse viewpart showing too much elements [message #1696372] Tue, 26 May 2015 03:40 Go to next message
after upgrading to eclipse 4.2 my viewpart starts to show elements from the navigator menu. Any suggestions what to do?
Please see attached screenshot:
index.php/fa/21957/0/
  • Attachment: scr.png
    (Size: 14.52KB, Downloaded 266 times)
[Updated on: Tue, 26 May 2015 06:12] by Moderator
Re: Eclipse viewpart showing too much elements [message #1696520 is a reply to message #1696372] Wed, 27 May 2015 00:53 Go to previous messageGo to next message
Someone's contributing a context menu for whatever objects your view is displaying. You can either uninstall/disable that plug-in, or file a bug report, but it's basically working as designed.
Re: Eclipse viewpart showing too much elements [message #1696537 is a reply to message #1696372] Wed, 27 May 2015 03:23 Go to previous messageGo to next message
Thanks for the reply. Actually i haven't changed anything for years in the code, and now on RAD9.0.1 it starts to behave like that. So i thought it was a bug.
Re: Eclipse viewpart showing too much elements [message #1696682 is a reply to message #1696537] Wed, 27 May 2015 17:09 Go to previous messageGo to next message
my eclipse 4.2 view-part is like this image its usual for me i see there is no problem
Re: Eclipse viewpart showing too much elements [message #1696713 is a reply to message #1696537] Thu, 28 May 2015 03:36 Go to previous messageGo to next message
Is it possible to find out which plugin is contributing the context menu, and maybe to remove it during runtime?
Re: Eclipse viewpart showing too much elements [message #1696719 is a reply to message #1696713] Thu, 28 May 2015 04:14 Go to previous messageGo to next message
I was thinking about filing a bug report, but i am not sure where to file it. If Eclipse is working as designed, then i need to know if it is a third part plugin that is causing the problem, and then file a bug report there.
Re: Eclipse viewpart showing too much elements [message #1696761 is a reply to message #1696719] Thu, 28 May 2015 08:55 Go to previous message
You can use the Plugin Spy to track down what plugin is contributing the menu item. See this Q&A on Stack Overflow for more details: http://stackoverflow.com/questions/6209033/how-to-determine-which-eclipse-plugins-are-contributing-to-menus-and-toolbars-an
Previous Topic:Problem with chinese characters in patch file
Next Topic: oAW
Current Time: Tue Oct 28 16:45:48 EDT 2025
Powered by FUDForum. Page generated in 0.09051 seconds
