Home » Modeling » TMF (Xtext) » Generation error after upgrading xtext
Generation error after upgrading xtext [message #1696107] Thu, 21 May 2015 16:26 Go to next message
I recently upgraded Xtext to 2.8.2 and when trying to generate the language artifacts, I got the following exception. Is there anything to do to upgrade the language? Is this bug/issue known?
Thanks for any help.
Julien.
5190 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems running workflow org.osate.verify.GenerateVerify:
[ERROR]: GeneratorException: (Element: -UNKNOWN-; Reported by: Generator)
org.eclipse.emf.common.util.WrappedException: java.lang.reflect.InvocationTargetException
at org.eclipse.xtext.generator.parser.antlr.AntlrToolFacade.runWithEncodingAndParams(AntlrToolFacade.java:183)
at org.eclipse.xtext.generator.parser.antlr.XtextAntlrGeneratorFragment.generate(XtextAntlrGeneratorFragment.java:48)
at org.eclipse.xtext.generator.DefaultGeneratorFragment.generate(DefaultGeneratorFragment.java:167)
at org.eclipse.xtext.generator.CompositeGeneratorFragment.generate(CompositeGeneratorFragment.java:163)
at org.eclipse.xtext.generator.Generator.generate(Generator.java:555)
at org.eclipse.xtext.generator.Generator.invokeInternal(Generator.java:172)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:35)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:78)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:36)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.xtext.generator.parser.antlr.AntlrToolFacade.runWithEncodingAndParams(AntlrToolFacade.java:173)
... 15 more
Caused by: java.lang.NoSuchMethodError: antlr.TokenStreamRewriteEngine.size()I
at org.antlr.tool.Grammar.defineLexerRuleFoundInParser(Grammar.java:1529)
at org.antlr.grammar.v2.DefineGrammarItemsWalker.rule(DefineGrammarItemsWalker.java:869)
at org.antlr.grammar.v2.DefineGrammarItemsWalker.rules(DefineGrammarItemsWalker.java:576)
at org.antlr.grammar.v2.DefineGrammarItemsWalker.grammarSpec(DefineGrammarItemsWalker.java:361)
at org.antlr.grammar.v2.DefineGrammarItemsWalker.grammar(DefineGrammarItemsWalker.java:193)
at org.antlr.tool.Grammar.defineGrammarSymbols(Grammar.java:702)
at org.antlr.tool.CompositeGrammar.defineGrammarSymbols(CompositeGrammar.java:352)
at org.antlr.Tool.process(Tool.java:451)
at de.itemis.xtext.antlr.toolrunner.AntlrToolRunner.runWithEncodingAndParams(AntlrToolRunner.java:168)
... 20 more
at org.eclipse.xtext.generator.parser.antlr.XtextAntlrUiGeneratorFragment.generate(XtextAntlrUiGeneratorFragment.java:110)
... 15 more
... 20 more
java.lang.RuntimeException: Problems running workflow org.osate.verify.GenerateVerify:
... 15 more
... 20 more
... 15 more
... 20 more
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:104)
Caused by: java.lang.RuntimeException:
... 15 more
... 20 more
... 15 more
... 20 more
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.handleIssues(Mwe2Bridge.java:56)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:48)
... 4 more
Re: Generation error after upgrading xtext [message #1696113 is a reply to message #1696107] Fri, 22 May 2015 00:04 Go to previous messageGo to next message
which version of the antlr generator do you have installed? if none: which one is stored under the name .*antlr*.jar in the root of the runtime project. if there is such a file (may be hidden) then move it out of the way and restart the workflow.
Re: Generation error after upgrading xtext [message #1696146 is a reply to message #1696113] Fri, 22 May 2015 07:35 Go to previous messageGo to next message
Seems that I have version 3.2 installed. See below.
[julien@masaru]/home/julien/git/alisa#find ~/local/packages/eclipse -name '*antlr*' 07:32:20
/home/julien/local/packages/eclipse/plugins/org.antlr.runtime_3.1.b1_3.1.0.jar
/home/julien/local/packages/eclipse/plugins/org.eclipse.epsilon.antlr.postprocessor_1.2.0.201408251031.jar
/home/julien/local/packages/eclipse/plugins/org.antlr.runtime_3.2.0.v201101311130.jar
/home/julien/local/packages/eclipse/plugins/org.antlr.runtime.source_3.2.0.v201101311130.jar
/home/julien/local/packages/eclipse/plugins/org.eclipse.epsilon.hutn.model.antlrAst_1.2.0.201408251031.jar
/home/julien/local/packages/eclipse/plugins/org.apache.ant_1.9.2.v201404171502/lib/ant-antlr.jar
/home/julien/local/packages/eclipse/plugins/org.eclipse.epsilon.antlr.postprocessor.model_1.2.0.201408251031.jar
Also, in the root of my project, I have a patch. See
[julien@masaru]/home/julien/git/alisa#find . -name '*antlr*.jar' 07:33:58
./org.osate.reqspec/.antlr-generator-3.2.0-patch.jar
./org.osate.verify/.antlr-generator-3.2.0-patch.jar
[julien@masaru]/home/julien/git/alisa#find . -name '*antlr*.jar' |xargs rm -f 07:34:10
If I am trying to delete them, the error is still there. The problem happens only with one project, other seems to be ok. Any other workwround/suggestion about how to investigate that?
Re: Generation error after upgrading xtext [message #1696148 is a reply to message #1696146] Fri, 22 May 2015 07:45 Go to previous messageGo to next message
if you have no antlr generator installed (this is the case) then the .antlr-generator-3.2.0-patch.jar is used.
(did you remove both of them?)
what you could to is to create a new project with the wizard and paste your grammar there.
thus you can find out if it is a bug or a problem with your setup
btw wich xtext version are you migrating from?
Re: Generation error after upgrading xtext [message #1696149 is a reply to message #1696148] Fri, 22 May 2015 07:48 Go to previous messageGo to next message
btw if you have a look at the class file it complains about: is the method there or is it not?
Re: Generation error after upgrading xtext [message #1696150 is a reply to message #1696149] Fri, 22 May 2015 07:57 Go to previous messageGo to next message
I will investigate. I am using xtext 2.8.2 and migrate from xtext 2.8.0
Re: Generation error after upgrading xtext [message #1696151 is a reply to message #1696150] Fri, 22 May 2015 08:00 Go to previous messageGo to next message
Yes, I deleted both patch files. Also, I cannot see if the function is defined because I do not have the sources.
Re: Generation error after upgrading xtext [message #1696152 is a reply to message #1696150] Fri, 22 May 2015 08:01 Go to previous messageGo to next message
such minor version updates should work straight forward.
Re: Generation error after upgrading xtext [message #1696157 is a reply to message #1696152] Fri, 22 May 2015 08:43 Go to previous messageGo to next message
I am trying to update to 2.9.0, let's see if it addresses the issue.
Re: Generation error after upgrading xtext [message #1696158 is a reply to message #1696157] Fri, 22 May 2015 08:47 Go to previous messageGo to next message
Exactly the same issues - any way to investigate more ? Do you recommend to install a specific antlr version?
Re: Generation error after upgrading xtext [message #1696159 is a reply to message #1696158] Fri, 22 May 2015 08:57 Go to previous messageGo to next message
Can you share a minimal grammar that reproduces the problem.
Re: Generation error after upgrading xtext [message #1696160 is a reply to message #1696159] Fri, 22 May 2015 08:58 Go to previous messageGo to next message
P.s.you tried a new xtext project as well?
Re: Generation error after upgrading xtext [message #1696161 is a reply to message #1696160] Fri, 22 May 2015 09:05 Go to previous messageGo to next message
It is not reproducible with a small projects. It seems that it happens when I have a project that references other grammar. Will try a new project.
Re: Generation error after upgrading xtext [message #1696166 is a reply to message #1696161] Fri, 22 May 2015 09:45 Go to previous messageGo to next message
I was able to reproduce the bug. I put it on the following github project. https://github.com/juli1/xtext-debug
Also, this is the trace I get when trying to generate the grammar
279 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'org.eclipse.emf.ecore.EcorePackage'
281 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems instantiating module org.xtext.example.mydsl.GenerateMyDsl: java.lang.reflect.InvocationTargetException
java.lang.RuntimeException: Problems instantiating module org.xtext.example.mydsl.GenerateMyDsl: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:95)
Caused by: org.eclipse.emf.common.util.WrappedException: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$1.setValue(SettingProviderImpl.java:56)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalApplyAssignments(Mwe2ExecutionEngine.java:143)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:114)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:296)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalSwitch(Mwe2ExecutionEngine.java:66)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalApplyAssignments(Mwe2ExecutionEngine.java:142)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:80)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.create(Mwe2ExecutionEngine.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:93)
... 4 more
at org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$1.setValue(SettingProviderImpl.java:54)
... 29 more
Caused by: org.eclipse.emf.mwe.core.ConfigurationException: Couldn't find an interface org.eclipse.uml2.types.TypesPackage
at org.eclipse.emf.mwe.utils.StandaloneSetup.addRegisterGeneratedEPackage(StandaloneSetup.java:430)
... 34 more
Re: Generation error after upgrading xtext [message #1696168 is a reply to message #1696166] Fri, 22 May 2015 09:56 Go to previous messageGo to next message
Hi this is a completely different error. Are you sure you installed uml sdk
Re: Generation error after upgrading xtext [message #1696173 is a reply to message #1696168] Fri, 22 May 2015 10:25 Go to previous messageGo to next message
first of all you should clean up the workflow. only register packages that are on classpath and that you actually use
    bean = StandaloneSetup {
    	scanClassPath = true
    	platformUri = "${runtimeProject}/.."
    	// The following two lines can be removed, if Xbase is not used.
    	registerGeneratedEPackage = "org.eclipse.xtext.xbase.XbasePackage"
    	registerGenModelFile = "platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel"
//		registerGeneratedEPackage = "org.eclipse.emf.ecore.EcorePackage"
//		registerGeneratedEPackage = "org.eclipse.uml2.types.TypesPackage"
//		registerGeneratedEPackage = "org.eclipse.uml2.uml.UMLPackage"
//		registerGeneratedEPackage = "org.eclipse.emf.codegen.ecore.genmodel.GenModelPackage"
//		registerGeneratedEPackage = "org.eclipse.uml2.codegen.ecore.genmodel.GenModelPackage"
//		registerGenModelFile = "platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel"
//		registerGenModelFile = "platform:/resource/org.eclipse.emf.codegen.ecore/model/GenModel.genmodel"
//		registerGenModelFile = "platform:/resource/org.eclipse.uml2.types/model/Types.genmodel"
//		registerGenModelFile = "platform:/resource/org.eclipse.uml2.uml/model/UML.genmodel"
//		registerGenModelFile = "platform:/resource/org.eclipse.uml2.codegen.ecore/model/GenModel.genmodel"
//		registerGeneratedEPackage = "org.osate.aadl2.Aadl2Package"
//		registerGenModelFile = "platform:/resource/org.osate.aadl2/model/aadl2.genmodel"
next you should get rid of the ambiguities
Re: Generation error after upgrading xtext [message #1696176 is a reply to message #1696173] Fri, 22 May 2015 10:28 Go to previous messageGo to next message
XNumberLiteral returns xbase::XNumberLiteral :
	{XNumberLiteralUnit} value=Number //? - the problem is the ? in your grammar
Re: Generation error after upgrading xtext [message #1696180 is a reply to message #1696168] Fri, 22 May 2015 10:41 Go to previous messageGo to next message
yep - sorry - I managed to reproduce it again. In fact, it happens when I import another genmodel and package. When I insert a dependency to another project. (the org.osate.xtext.aadl2)
What dependencies/features of this project might then cause that?
Re: Generation error after upgrading xtext [message #1696184 is a reply to message #1696180] Fri, 22 May 2015 11:28 Go to previous messageGo to next message
sorry i cannot say that. there may be something wrong with the classpath. or a bug in xtext or antlr.
but with reproducing hard to say
Re: Generation error after upgrading xtext [message #1696185 is a reply to message #1696184] Fri, 22 May 2015 11:43 Go to previous messageGo to next message
More clue about it - a colleague of mine has the same sources on a windows machine - it works ok. Turns out that it does not work on mine (linux debian x64)
Re: Generation error after upgrading xtext [message #1696187 is a reply to message #1696185] Fri, 22 May 2015 11:51 Go to previous messageGo to next message
is it still the very same error? i really have no clue
Re: Generation error after upgrading xtext [message #1696189 is a reply to message #1696146] Fri, 22 May 2015 12:08 Go to previous message
Please make sure that org.antlr.runtime_3.1.b1_3.1.0.jar is not on the
classpath of the mwe2 execution.
Best,
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Find help at http://xtext.itemis.com or xtext(@)itemis.com
Blog: zarnekow.blogspot.com
Twitter: @szarnekow
Google+: https://www.google.com/+SebastianZarnekow
Previous Topic:From XSD to Xtext: xsd:any / arbitrary XML content
Next Topic:xText as standalone lexer, parser, interpreter?
Current Time: Sat Jul 26 08:56:23 EDT 2025
Powered by FUDForum. Page generated in 0.08375 seconds
