Generation error after upgrading xtext [message #1696107] |
Thu, 21 May 2015 16:26  |
I recently upgraded Xtext to 2.8.2 and when trying to generate the language artifacts, I got the following exception. Is there anything to do to upgrade the language? Is this bug/issue known?
Thanks for any help.
Julien.
5190 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems running workflow org.osate.verify.GenerateVerify:
[ERROR]: GeneratorException: (Element: -UNKNOWN-; Reported by: Generator)
org.eclipse.emf.common.util.WrappedException: java.lang.reflect.InvocationTargetException
at org.eclipse.xtext.generator.parser.antlr.AntlrToolFacade.runWithEncodingAndParams(AntlrToolFacade.java:183)
at org.eclipse.xtext.generator.parser.antlr.XtextAntlrGeneratorFragment.generate(XtextAntlrGeneratorFragment.java:48)
at org.eclipse.xtext.generator.DefaultGeneratorFragment.generate(DefaultGeneratorFragment.java:167)
at org.eclipse.xtext.generator.CompositeGeneratorFragment.generate(CompositeGeneratorFragment.java:163)
at org.eclipse.xtext.generator.Generator.generate(Generator.java:555)
at org.eclipse.xtext.generator.Generator.invokeInternal(Generator.java:172)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:35)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:78)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:36)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.xtext.generator.parser.antlr.AntlrToolFacade.runWithEncodingAndParams(AntlrToolFacade.java:173)
... 15 more
Caused by: java.lang.NoSuchMethodError: antlr.TokenStreamRewriteEngine.size()I
at org.antlr.tool.Grammar.defineLexerRuleFoundInParser(Grammar.java:1529)
at org.antlr.grammar.v2.DefineGrammarItemsWalker.rule(DefineGrammarItemsWalker.java:869)
at org.antlr.grammar.v2.DefineGrammarItemsWalker.rules(DefineGrammarItemsWalker.java:576)
at org.antlr.grammar.v2.DefineGrammarItemsWalker.grammarSpec(DefineGrammarItemsWalker.java:361)
at org.antlr.grammar.v2.DefineGrammarItemsWalker.grammar(DefineGrammarItemsWalker.java:193)
at org.antlr.tool.Grammar.defineGrammarSymbols(Grammar.java:702)
at org.antlr.tool.CompositeGrammar.defineGrammarSymbols(CompositeGrammar.java:352)
at org.antlr.Tool.process(Tool.java:451)
at de.itemis.xtext.antlr.toolrunner.AntlrToolRunner.runWithEncodingAndParams(AntlrToolRunner.java:168)
... 20 more
at org.eclipse.xtext.generator.parser.antlr.XtextAntlrUiGeneratorFragment.generate(XtextAntlrUiGeneratorFragment.java:110)
... 15 more
... 20 more
java.lang.RuntimeException: Problems running workflow org.osate.verify.GenerateVerify:
... 15 more
... 20 more
... 15 more
... 20 more
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:104)
Caused by: java.lang.RuntimeException:
... 15 more
... 20 more
... 15 more
... 20 more
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.handleIssues(Mwe2Bridge.java:56)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:48)
... 4 more
FUDForum. Page generated in 0.06917 seconds
