Home » Language IDEs » Java Development Tools (JDT) » Same option in too many places
Same option in too many places [message #169142] Sat, 17 July 2004 16:22 Go to next message
Originally posted by: ali_akbani.yahoo.com
This is one of the most frustrating things about eclipse. Same option is
set in differrent places. I tried to change "print column width" from 80
to 500. I changed it in Java|Editor, still wrapped. Searched and changed
it in Workbench|Editor, still wrapped!! Finally found the last setting
in Java|CodeStyle|CodeFormatter.
This problem is not isolated or last one. Please look into this and
standardize the feature settings especially thos that are common.
Re: Same option in too many places [message #169204 is a reply to message #169142] Mon, 19 July 2004 04:42 Go to previous messageGo to next message
/Mohammed Ali Akbani/:
"Print margin column" is just this - showed if you have checked
"Show pring margin", it doesn't format anything automatically.
That setting is for the Plain Text editor not the Java one.
Yes, there you specify the formatting preferences for your Java code.
Could you point the other problems (or just another one) you have?
Stanimir
Re: Same option in too many places [message #169580 is a reply to message #169142] Tue, 20 July 2004 14:32 Go to previous messageGo to next message
Originally posted by: akiezun.cutthis.mit.this.edu.andthis
"print column width" has nothing to do with wrapping.
a.
Re: Same option in too many places [message #169610 is a reply to message #169580] Tue, 20 July 2004 16:32 Go to previous messageGo to next message
WHen you choose auto-format, if a code line is going beyond the limit
the line is wrapped. For example
JOptionPane.showMessageDialog( client.window, "Index Not Found",
"Index Error",
JOptionPane.INFORMATION_MESSAGE );
> a.
Re: Same option in too many places [message #169649 is a reply to message #169610] Wed, 21 July 2004 08:58 Go to previous message
but that's 'maximum line width' not the print margin.
these 2 are different - i worked on a project when people used backward
editors on linux that could not display more than 80 columns - so i set
the print margin to make it easier for myself to wrap lines.
but i would never let an automatic formatter to wrap or otherwise format
my source code.
a.
> Found", "Index
> Error",
>> a.
Previous Topic:Does "Select Enclosing Element " selects too much?
Next Topic:Eclipse will not start
Current Time: Sat Oct 25 14:55:26 EDT 2025
Powered by FUDForum. Page generated in 0.04559 seconds
