Home » Newcomers » Newcomers » Sudden startup problem
Sudden startup problem [message #1695856] Tue, 19 May 2015 15:44 Go to next message
Hi all,
Yesterday evening I used Eclipse Luna and everything worked fine, now I
start up and after the splash screen, nothing happens. The process is
running in the background, but I get no UI. I can see it with ps aux
though.
I just deleted eclipse and untarred the thing again, but nothing
changes. The packaged eclipse from linux was too old, so I downloaded a
tar, which is in /usr/local/
Running on Linux Mint 17.1, 64 bit
$ java -version
java version "1.7.0_75"
OpenJDK Runtime Environment (IcedTea 2.5.4) (7u75-2.5.4-1~trusty1)
OpenJDK 64-Bit Server VM (build 24.75-b04, mixed mode)
Any help appreciated.
Cheers, H.
Hendrik Maryns
http://hendrikmaryns.name
Re: Sudden startup problem [message #1695857 is a reply to message #1695856] Tue, 19 May 2015 15:45 Go to previous messageGo to next message
Op 19-05-15 om 21:44 schreef Hendrik Maryns:
> Hi all,
> though.
It is named eclipse-java-luna-SR2-linux-gtk-x86_64.tar.gz.
> $ java -version
> Cheers, H.
Hendrik Maryns
Re: Sudden startup problem [message #1695876 is a reply to message #1695857] Tue, 19 May 2015 23:38 Go to previous messageGo to next message
>> Hi all,
>> though.
>> $ java -version
>> Cheers, H.
I can't say what your problem was, however, I can offer this expanded
set of notes beyond what's in this forum as a sticky post:
http://www.javahotchocolate.com/notes/eclipse-jdk-tomcat.html
Re: Sudden startup problem [message #1696056 is a reply to message #1695876] Thu, 21 May 2015 08:47 Go to previous message
Op 20-05-15 om 05:38 schreef Russell Bateman:
>>> Hi all,
>>> though.
>>> $ java -version
>>> Cheers, H.
Thanks. I took your advice of installing Eclipse locally to the heart
and indeed now it works. I hope it will continue to do so.
Cheers, H.
Hendrik Maryns
Previous Topic:Insert space for tabs not working on C/C++ files in Eclipse CDT
Next Topic:Buildhelper plugin disappears from desktop
Current Time: Sat Jul 26 02:36:43 EDT 2025
Powered by FUDForum. Page generated in 0.30739 seconds
