Home » Modeling » EMF » [CDO] Howto remove a resource with Mars M7?
[CDO] Howto remove a resource with Mars M7? [message #1695975] |
Wed, 20 May 2015 12:52  |
With Luna, I could use the default "CDO Sessions" view to connect to a repository, open a session, open a transaction, select a resource, then do a right click and select "Remove" to delete the resource.
With Mars M7, I can still use the default "CDO Sessions" view to connect to a repository, open a session, open a transaction, select a resource, but then I just see a option "Delete" which is always disabled.
My repo configuration is very basic (no security manager).
Is there something special to do with Mars M7 to be able to delete a resource through the CDO default User Interface ?
Bernard.
Re: [CDO] Howto remove a resource with Mars M7? [message #1695978 is a reply to message #1695975] |
Wed, 20 May 2015 14:07   |
Hi Bernard,
We now provide a CDO Repositories view and a Project Explorer integration for "checkouts" (which can also be online)
from the configured repos.
The CDO Sessions view is still supported and should work mostly like before. Due to the major UI refactorings it's
possible that there are some regressions, though. Please submit a bugzilla so that I can fix it. It would be great if
you could have a look for other functionality that got lost from the CDO Sessions view. Thanks!
Cheers
/Eike
http://www.esc-net.de
Am 20.05.2015 um 18:52 schrieb Bernard SARTER:
> Bernard.
Current Time: Mon Jul 21 10:40:17 EDT 2025
Powered by FUDForum. Page generated in 0.25103 seconds
