Home » Modeling » TMF (Xtext) » Correct way of migration from old version to new one(2.7.3 to 2.8)
Correct way of migration from old version to new one [message #1695784] Tue, 19 May 2015 05:18 Go to next message
Hello All
I have a tested application that based on version 2.7.3 of xtext. Some part of code is autogenerated by xtext. Configuration file like plugin.xml contains references to 2.7.3 plugins. How can I provide safety migration between two version 2.7.3 and 2.8.x? I would not like create new projects and moving manually my code to new project. Is there more safety way?
Alexander
Re: Correct way of migration from old version to new one [message #1695790 is a reply to message #1695784] Tue, 19 May 2015 06:08 Go to previous messageGo to next message
Xtext is not not bidirectionally compatible, new editor on old run-time/
on editor on new-run-time. However many permutations work.
If you want fuller compatibility have a look at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=460978 and
org.eclipse.ocl.examples.build.utilities.BackportToXtext_2_3_1.java used
to enable Xtext 2.9 generated OCL editors to run on an Xtext 2.3.1 platform.
Since Xtext endeavours to follow Eclipse backward compatibility
guidelines, your plugins should specify a lower bound that you know to
work, e.g. 2.7.3 and an upper bound of the next major version (3.0.0) .
Ed Willink
On 19/05/2015 10:18, Alex Gor wrote:
> Hello All
> Thanks
> Alexander
Re: Correct way of migration from old version to new one [message #1695811 is a reply to message #1695790] Tue, 19 May 2015 09:14 Go to previous messageGo to next message
I see your answer. But practically can I do the following
For example
- I download and install new boundle of Eclipse+new release of Xtext.
- create new workspace
- change upper bound of xtext's plugins
then
import my project to new workspace
Does it help me?
Re: Correct way of migration from old version to new one [message #1696122 is a reply to message #1695811] Fri, 22 May 2015 04:23 Go to previous messageGo to next message
I did steps that mentioned before. Compilation completed with success. But I cannot run appliccation due to following errors
org.osgi.framework.BundleException: Could not resolve module: com.psl.atom [149]
  Unresolved requirement: Require-Bundle: org.eclipse.xtext.xbase; bundle-version="[2.8.2,3.0.0)"; visibility:="reexport"; resolution:="optional"
  Unresolved requirement: Require-Bundle: org.eclipse.xtext.generator; bundle-version="[2.8.2,3.0.0)"; resolution:="optional"
  Unresolved requirement: Require-Bundle: org.eclipse.emf.codegen.ecore; resolution:="optional"
  Unresolved requirement: Require-Bundle: org.eclipse.emf.mwe2.launch; resolution:="optional"
  Unresolved requirement: Require-Bundle: org.eclipse.xtext.builder; bundle-version="[2.8.2,3.0.0)"
    -> Bundle-SymbolicName: org.eclipse.xtext.builder; bundle-version="2.8.2.v201504100559"; singleton:="true"
       org.eclipse.xtext.builder [43]
         Unresolved requirement: Require-Bundle: org.eclipse.xtext.ui; bundle-version="[2.8.0,3.0.0)"
           -> Bundle-SymbolicName: org.eclipse.xtext.ui; bundle-version="2.8.2.v201504100559"; singleton:="true"
              org.eclipse.xtext.ui [104]
                Unresolved requirement: Require-Bundle: org.eclipse.xtext.ide; bundle-version="[2.8.0,3.0.0)"
I checked required library org.eclipse.xtext.ide is located in plugins folder. What is nature of this issue?
[Updated on: Fri, 22 May 2015 05:09] by Moderator
Re: Correct way of migration from old version to new one [message #1696130 is a reply to message #1696122] Fri, 22 May 2015 05:12 Go to previous message
Please make sure that xtext.ide is also listed in your launch config.
Best,
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Find help at http://xtext.itemis.com or xtext(@)itemis.com
Blog: zarnekow.blogspot.com
Twitter: @szarnekow
Google+: https://www.google.com/+SebastianZarnekow
Previous Topic:Eclipse DSL 2.8.0 package and Oracle tools
Next Topic:From XSD to Xtext: xsd:any / arbitrary XML content
Current Time: Sat Jul 26 11:48:16 EDT 2025
Powered by FUDForum. Page generated in 0.08515 seconds
