Deploying Workflow Model Using Console Command [message #1668551] |
Thu, 12 March 2015 10:42  |
I am trying to deploy a workflow model using the console command. I am using a Tomcat 7 Server and a Derby Database. After deploying the .war file (created with maven, Stardust-Version 2.1.1) I can log into the Stardust Portal.
Now I want to deploy a workflow model.
Currently I am trying to use the command
> console -user motu -password motu deploy -filename <filename>
but I'm not sure where the file is supposed to be and if the command needs an absolute filepath or only the filename.
Thanks in advance.
Best Regards,
Lea-Louisa
Re: Deploying Workflow Model Using Console Command [message #1670649 is a reply to message #1668889] |
Fri, 13 March 2015 05:26   |
deploying the model in the portal works fine, but since I am trying to set up the engine and deploy models automatically, I need to use the console command.
When putting the .xpdl-File in the same folder as the one where I start the command from, I get a NullPointerException:
2015-03-13 08:28:11,115 INFO [main] () log.extensions - Initializing static extensions resolver
2015-03-13 08:28:11,116 INFO [main] () log.extensions - Initializing Service Provider extensions resolver
2015-03-13 08:28:11,116 INFO [main] () log.extensions - Using extensions manager: org.eclipse.stardust.engine.core.runtime.beans.PartitionAwareExtensionsManager@368239c8
2015-03-13 08:28:11,720 WARN [main] () log.LogUtils -
at org.eclipse.stardust.common.config.Version.compareTo(Version.java:173)
at org.eclipse.stardust.common.config.Version.compareTo(Version.java:159)
at org.eclipse.stardust.common.config.Version.compareTo(Version.java:28)
at org.eclipse.stardust.common.CompareHelper.compare(CompareHelper.java:100)
at org.eclipse.stardust.engine.core.model.beans.ElementFactoryImpl.createModel(ElementFactoryImpl.java:1169)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.stardust.engine.core.model.beans.DefaultXMLReader$InvocationManager.invoke(DefaultXMLReader.java:1792)
at com.sun.proxy.$Proxy0.createModel(Unknown Source)
at org.eclipse.stardust.engine.core.model.beans.DefaultXMLReader.loadModel(DefaultXMLReader.java:613)
at org.eclipse.stardust.engine.core.model.xpdl.XpdlUtils.loadXpdlModel(XpdlUtils.java:629)
at org.eclipse.stardust.engine.core.model.xpdl.XpdlUtils.loadXpdlModel(XpdlUtils.java:598)
at org.eclipse.stardust.engine.cli.console.DeployCommand$ModelFile.<init>(DeployCommand.java:536)
at org.eclipse.stardust.engine.cli.console.DeployCommand.readModelsFromFile(DeployCommand.java:602)
at org.eclipse.stardust.engine.cli.console.DeployCommand.run(DeployCommand.java:197)
at org.eclipse.stardust.common.utils.console.DefaultConsoleProcessor.execute(DefaultConsoleProcessor.java:128)
at org.eclipse.stardust.engine.cli.console.Main.run(Main.java:84)
at org.eclipse.stardust.engine.cli.console.Main.main(Main.java:73)
2015-03-13 08:28:11,723 WARN [main] () console.DefaultConsoleProcessor - Operation could not be performed: null
at org.eclipse.stardust.engine.core.model.beans.DefaultXMLReader.loadModel(DefaultXMLReader.java:615)
Do you have any idea where the problem is?
Best Regards,
Lea-Louisa
Re: Deploying Workflow Model Using Console Command [message #1695741 is a reply to message #1670649] |
Mon, 18 May 2015 16:17  |
Hi Lea-Louisa,
this stack means that you have a different version of artifact then the version that is deployed on the server.
I did a retest with a milestone build 3.0.0 with the following steps:
1. Eclipse setup with dynamic web project (described with the support-case tutorial)
2. downloaded archetype console-spring-client (same version of Stardust!)
3. copied carnot-spring-client.properties, carnot-spring-client.xml and carnot.properies from my dynamic web project to console/etc
4. copied derby db driver to console/lib
executed: console -u motu -p motu -v deploy -filename ACMEWorkflowModel.xpdl
Worked fine on console and in eclipse.
hope that helps!
Simone
FUDForum. Page generated in 0.24713 seconds
