Home » Eclipse Projects » Oomph » Set Launcher History in Oomph Setup(usually only )
icon5.gif  Set Launcher History in Oomph Setup [message #1695669] Mon, 18 May 2015 08:31 Go to next message
I'm working on an Oomph-Setup-file and I wonder if it is possible to set Launchers to the Launcher History. So a user only have to click on the run/debug symbol instead of "run Configurations...", search for the launcher and run it.
On this screenshot you can see, history is empty (left side).
There is a launch config I would like to set as default (SCT, right side).
Possible?
Too bad i have less than 5 postings, so i cant directly link the screenshot:
abload.de/img/unbenanntfiuty.png
  • Attachment: Unbenannt.png
    (Size: 28.75KB, Downloaded 152 times)
Re: Set Launcher History in Oomph Setup [message #1695759 is a reply to message #1695669] Tue, 19 May 2015 01:33 Go to previous messageGo to next message
Hi Oliver,
I don't think it's possible to influence the history (other than simply executing a launch), but have you tried to check
"Display in favorites menu" on the Common Tab of the launch configuration?
Cheers
/Eike
http://www.esc-net.de
Am 18.05.2015 um 14:51 schrieb Oliver Bohl:
> Hello,
> Possible?
Re: Set Launcher History in Oomph Setup [message #1697065 is a reply to message #1695759] Mon, 01 June 2015 05:56 Go to previous messageGo to next message
Hello Eike,
thanks for your reply.
But I don't have any "Display in favorites menu" check on the Common Tab of the launch configuration.
Greetings
Oliver
Re: Set Launcher History in Oomph Setup [message #1697066 is a reply to message #1697065] Mon, 01 June 2015 06:32 Go to previous messageGo to next message
Oliver,
I see a "Display in favorites menu" viewer in your image and both your
Run and Debug appear to have the check mark enabled...
On 01/06/2015 11:56 AM, Oliver Bohl wrote:
> Hello Eike,
> Greetings
> Oliver
Re: Set Launcher History in Oomph Setup [message #1697078 is a reply to message #1697066] Mon, 01 June 2015 08:47 Go to previous messageGo to next message
Hello Ed,
thank you for your reply. Now I see it Wink
Is there any way to add launch-favorites through Oomph-Setup?
Re: Set Launcher History in Oomph Setup [message #1697087 is a reply to message #1697078] Mon, 01 June 2015 09:30 Go to previous messageGo to next message
Oliver,
No. It seems to me more of an Eclipse bug that things marked as
favorites do no initially appear in the menu...
On 01/06/2015 2:47 PM, Oliver Bohl wrote:
> Hello Ed,
> thank you for your reply. Now I see it ;)
Re: Set Launcher History in Oomph Setup [message #1697091 is a reply to message #1697087] Mon, 01 June 2015 10:04 Go to previous message
Ok, thank you.
Previous Topic:Is there a way to make the launch task wait
Next Topic:About the Product Catalogue
Current Time: Mon Sep 01 10:50:47 EDT 2025
Powered by FUDForum. Page generated in 0.06930 seconds
