Home » Eclipse Projects » EclipseLink » Certificate Chaining Error
Certificate Chaining Error [message #1695618] Mon, 18 May 2015 03:43 Go to next message
Hi there,
I'm using EclipseLink 2.6 inside a WebSphere Liberty container to perform persistence to a locally running DB2. However, I see the following error from the server when it tries to setup the EntityManager:
[ERROR ] An unhandled exception occurred which will be propagated to the container.
[ERROR ] SRVE0777E: Exception thrown by application class 'org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy:812'
javax.persistence.PersistenceException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.6.0.v20150309-bf26070): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: com.ibm.db2.jcc.am.DisconnectNonTransientConnectionException: [jcc][t4][2030][11211][4.13.127] A communication error occurred during operations on the connection's underlying socket, socket input stream,
or socket output stream. Error location: T4Agent.sendRequest() - flush (-1). Message: com.ibm.jsse2.util.j: PKIX path building failed: java.security.cert.CertPathBuilderException: PKIXCertPathBuilderImpl could not build a valid CertPath.; internal cause is:
java.security.cert.CertPathValidatorException: The certificate issued by CN=DigiCert Global Root CA, OU=www.digicert.com, O=DigiCert Inc, C=US is not trusted; internal cause is:
java.security.cert.CertPathValidatorException: Certificate chaining error. ERRORCODE=-4499, SQLSTATE=08001
Error Code: -4499
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:812)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getAbstractSession(EntityManagerFactoryDelegate.java:205)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:305)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:337)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:303)
at com.ibm.cics.oi.datamanagement.utils.DatabaseOperations.createEntityManager(DatabaseOperations.java:40)
at com.ibm.cics.oi.datamanagement.utils.QueryBuilder.startQuery(QueryBuilder.java:52)
at com.ibm.cics.oi.datamanagement.utils.QueryBuilder.<init>(QueryBuilder.java:43)
at com.ibm.cics.oi.datamanagement.helpers.DataManagementHelper.makeQueryBuilder(DataManagementHelper.java:43)
at com.ibm.cics.oi.datamanagement.helpers.UserHelper.getCurrentUser(UserHelper.java:70)
at com.ibm.cics.oi.restapi.jaxrs.db2.Db2UserResource.getUser(Db2UserResource.java:61)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:95)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:56)
at java.lang.reflect.Method.invoke(Method.java:620)
at org.apache.wink.server.internal.handlers.InvokeMethodHandler.handleRequest(InvokeMethodHandler.java:63)
at org.apache.wink.server.handlers.AbstractHandler.handleRequest(AbstractHandler.java:33)
at org.apache.wink.server.handlers.RequestHandlersChain.handle(RequestHandlersChain.java:26)
at org.apache.wink.server.handlers.RequestHandlersChain.handle(RequestHandlersChain.java:22)
at org.apache.wink.server.handlers.AbstractHandlersChain.doChain(AbstractHandlersChain.java:75)
at org.apache.wink.server.internal.handlers.CreateInvocationParametersHandler.handleRequest(CreateInvocationParametersHandler.java:54)
at org.apache.wink.server.handlers.AbstractHandler.handleRequest(AbstractHandler.java:34)
at org.apache.wink.server.internal.handlers.FindResourceMethodHandler.handleResourceMethod(FindResourceMethodHandler.java:151)
at org.apache.wink.server.internal.handlers.FindResourceMethodHandler.handleRequest(FindResourceMethodHandler.java:65)
at org.apache.wink.server.internal.handlers.FindRootResourceHandler.handleRequest(FindRootResourceHandler.java:95)
at org.apache.wink.server.internal.handlers.HeadMethodHandler.handleRequest(HeadMethodHandler.java:53)
at org.apache.wink.server.internal.handlers.OptionsMethodWADLHandler.handleRequest(OptionsMethodWADLHandler.java:51)
at org.apache.wink.server.internal.handlers.SearchResultHandler.handleRequest(SearchResultHandler.java:33)
at org.apache.wink.server.internal.log.ResourceInvocation.handleRequest(ResourceInvocation.java:92)
at org.apache.wink.server.internal.log.Requests.handleRequest(Requests.java:76)
at org.apache.wink.server.handlers.AbstractHandlersChain.run(AbstractHandlersChain.java:60)
at org.apache.wink.server.internal.RequestProcessor.handleRequestWithoutFaultBarrier(RequestProcessor.java:207)
at org.apache.wink.server.internal.RequestProcessor.handleRequest(RequestProcessor.java:154)
at com.ibm.websphere.jaxrs.server.IBMRestServlet.service(IBMRestServlet.java:106)
at [internal classes]
I'm not sure why this is happening - I don't want to use an SSL connection at the moment while I'm developing. I've read somewhere that SSL would only be used if configured in the jdbc url but I haven't configured it there.
Please could anyone help me configure EclipseLink to not use SSL connection to the database?
Cheers, Sam.
Re: Certificate Chaining Error [message #1695738 is a reply to message #1695618] Mon, 18 May 2015 14:34 Go to previous message
Scratch this, I figured it out. Some sneaky bugger had hard coded a JDBC URL into the code that I didn't know about and it was legitimately trying to use a secured server.
D'oh Smile
Previous Topic:Upgrading from EclipseLink 1.0.2 to Latest : To JPA or not ?
Next Topic:Problem with join fetching multiple entities
Current Time: Mon Jul 28 17:07:25 EDT 2025
Powered by FUDForum. Page generated in 0.24618 seconds
