Home » Eclipse Projects » NatTable » set Custom icon in table column HeaderMenu(popup menu)
icon5.gif  set Custom icon in table column HeaderMenu(popup menu) [message #1695542] Sat, 16 May 2015 02:14 Go to next message
Hi friend ,
I am using nattable and trying to set custom icon or add new custom item in popup menu when show Column name-> right click-> popup menu item ,so it is possible or not in nattable ???
http://D:/Lalit/Images/custom icon problem.png
please help me friend and it is possible or not in nattable
[Updated on: Sat, 16 May 2015 02:37] by Moderator
Re: set Custom icon in table column HeaderMenu(popup menu) [message #1695548 is a reply to message #1695542] Sat, 16 May 2015 05:32 Go to previous messageGo to next message
Yes it is possible. When creating a custom menu configuration you can specify every attribute on building a menu item via IMenuItemProvider
Re: set Custom icon in table column HeaderMenu(popup menu) [message #1695606 is a reply to message #1695548] Sun, 17 May 2015 23:49 Go to previous message
ok Thank you so much Dirk sir and sorry for previas discussion...
Previous Topic:Resize NatTable on collapse and expand
Next Topic:DefaultGlazedListsStaticFilterStrategy.removeStaticFilter does not remove matcher in underlying set
Current Time: Fri Jul 18 22:11:22 EDT 2025
Powered by FUDForum. Page generated in 0.05348 seconds
