Home » Eclipse Projects » RCP Testing Tool » Throwing an exception?
Throwing an exception? [message #1693741] Tue, 28 April 2015 00:52 Go to next message
I may have just completely skipped over it in the list of available procedures, but I can't seem to find how to throw exceptions of my own.
Re: Throwing an exception? [message #1695186 is a reply to message #1693741] Tue, 12 May 2015 10:26 Go to previous messageGo to next message
Procedure trace might be helpful for you.
What exactly do you want to do?
Re: Throwing an exception? [message #1695368 is a reply to message #1695186] Wed, 13 May 2015 15:12 Go to previous message
I didn't need anything fancy. I was just trying to find if there was a preferred method for determining my own errors, like more traditional programming. For example, this is what I've written to get around what I want to do (final IF block):
proc "verify-children-v2" [val view] [val pathToitem] [val childrenToVerify] {
	let [val item [get-view $view | get-tree | get-item $pathToitem]] {
		let [val numChildren [$item | get-property "getItemCount()" -raw]] {
			if [$numChildren | gt 0] {
				if [$view | equals Outline] {
					verify-children-helper $numChildren $childrenToVerify $item "getData().getChildren().OMNodeTreeEditPart[" "].getWidget().getText()"
				if [$view | equals Enclosures] {
					verify-children-helper $numChildren $childrenToVerify $item "getData().getChildren().Object[" "].getLabel()"
				if [$view | equals XForms] {
					verify-children-helper $numChildren $childrenToVerify $item "getData().getChildren().Object[" "].getName()"
				if [and[$view | not-eq Outline][$view | not-eq Enclosures][$view | not-eq XForms]] {
					// Create a bogus error to indicate the view isn't supported yet in case we get this far
					UnsupportedViewCalledFromProcedure
The "solution" I've come up with for now is a bogus call with the name of the error I'd like to display (UnsupportedViewCalledFromProcedure). I've found the lack of control in ECL to be a pain point sometimes, as there is no conventional return. In this case I've written my own little verification for the children of a particular tree element, which needs to be done dynamically and not to any super specific degree. Depending on the tree type, the data is being stored differently. I've only set up 3 initial conditions that will succeed, as this will be added to as needed by other QA. The problem was I didn't want to reach the end of the IFs and return successfully if an unsupported View name was passed in because the procedure should end in error in that case. But, I also wanted an error message specific enough to show why it didn't work if somebody tried to use it. This is what I came up with.
For the record, I still feel like this is kind of a silly way to do it and there is a better way, but it works the way I want and will do for now. Only started this a few weeks ago, so very much a novice when it comes to being familiar with the capabilities.
[Updated on: Wed, 13 May 2015 15:21] by Moderator
Previous Topic:ECL Verification
Next Topic:How to get items from table whem item names changes in each execution
Current Time: Tue Jul 22 22:25:43 EDT 2025
Powered by FUDForum. Page generated in 0.08001 seconds
