Home » Eclipse Projects » Equinox » osgi.framework.extensions does not work with WebStart
osgi.framework.extensions does not work with WebStart [message #1240490] Thu, 06 February 2014 10:40 Go to next message
I am trying to create WebStart for my Eclipse RCP application and need to add to osgi.framework.extensions addition Adaptor Hook from org.eclipse.fx.osgi and others.
I am doing like this in JNLP file:
<property name="osgi.framework.extensions" value="javax.transaction,org.eclipse.equinox.transforms.hook,org.eclipse.equinox.weaving.hook,org.eclipse.fx.osgi" />
Problem is that I am getting exception that bundle cannot be found.
After debugging I see that method readFrameworkExtensions() from org.eclipse.equinox.launcher.Main when looking for bundle is getting a path to jar file downloaded to local cache (e.g. C:\Users\pdolecinski\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\17\3bb97dd1-333be9ad). And later on, when trying to create extensionURL, it is using line code:
extensionURL = new URL(installLocation.getProtocol(), installLocation.getHost(), installLocation.getPort(), path);
where installLocation is http://localhost/webstart and created extensionURL looks like
http://localhost/webstart/C:\Users\pdolecinski\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\17\3bb97dd1-333be9ad
Even more, let's say path would be correct, then code expect to find file with .jar extension and the one from cache doesn't have it.
I have no idea if there is some workaround which I do not know or it simply a bug.
Any ideas how to add something to osgi.framework.extensions under WebStart?
Paweł.
Re: osgi.framework.extensions does not work with WebStart [message #1240592 is a reply to message #1240490] Thu, 06 February 2014 15:28 Go to previous messageGo to next message
This looks like a bug in the equinox launcher. I don't see anyway around the bug. I think you could patch the launcher with something like this:
			URL extensionURL = null;
			File extensionFile = new File(path); // check if file exists
			if (extensionFile.exists()) { // the file exists just add it to the list of extensions
				extensionResults.add(path);
				extensionURL = extensionFile.toURL();
			} else
It would be good for you to try that out and also open a bug for this.
Re: osgi.framework.extensions does not work with WebStart [message #1241117 is a reply to message #1240592] Fri, 07 February 2014 09:07 Go to previous messageGo to next message
Hi Thomas,
I opened a bug 427663.
Your patch works for me with few small adjustments described in the bug.
Thanks for help!
Re: osgi.framework.extensions does not work with WebStart [message #1695146 is a reply to message #1241117] Tue, 12 May 2015 05:43 Go to previous message
It was a difficult path to end up and find this thread.
I have the exact same problem which is described. I have an RCP application which needs framework extensions (in my case : org.eclipse.fx.osgi).
Reading the bug 427663, i understand that the problem wasn't patched. I tried the snippet provided but still blocked.
Have you been working on that since ? Anyway i could get the code ?
Previous Topic:Equinox, chose service implementation at runtime
Next Topic:Unable to load com.ibm.icu plugin on startup
Current Time: Wed Jul 23 12:49:10 EDT 2025
Powered by FUDForum. Page generated in 0.05504 seconds
