Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [solved] [EMF Forms] Error using View Model Editor: "Bad type on operand stack"(Editing *.view file in view model editor results in exception error)
[solved] [EMF Forms] Error using View Model Editor: "Bad type on operand stack" [message #1695069] Mon, 11 May 2015 14:39 Go to next message
Hello!
I have a modelling project (Eclipse modelling edition) and created a view model from the ecore file.
If I open the class' view file I reproducably receive an error dialog (contents below). Every click on a part of the view model gives the error again. I don't know how to control which databinding context is used by the view model editor. Is there anything I could install/reinstall?
Thanks for your help!
GV
Ein Fehler ist aufgetreten. Details finden Sie im Fehlerprotokoll.
Exception Details:
    org/eclipse/emf/ecp/view/spi/core/swt/AbstractControlSWTRenderer.getDataBindingContext()Lorg/eclipse/core/databinding/DataBindingContext; @15: putfield
  Reason:
    Type 'org/eclipse/emf/databinding/EMFDataBindingContext' (current frame, stack[1]) is not assignable to 'org/eclipse/core/databinding/DataBindingContext'
  Current Frame:
    bci: @15
    flags: { }
    locals: { 'org/eclipse/emf/ecp/view/spi/core/swt/AbstractControlSWTRenderer' }
    stack: { 'org/eclipse/emf/ecp/view/spi/core/swt/AbstractControlSWTRenderer', 'org/eclipse/emf/databinding/EMFDataBindingContext' }
  Bytecode:
    0x0000000: 2ab4 0147 c700 0e2a bb00 9759 b701 5bb5
    0x0000010: 0147 2ab4 0147 b0
  Stackmap Table:
    same_frame(@18)
[Updated on: Tue, 12 May 2015 05:45] by Moderator
Re: [EMF Forms] Error using View Model Editor: "Bad type on operand stack" [message #1695111 is a reply to message #1695069] Tue, 12 May 2015 02:53 Go to previous messageGo to next message
Hi Volker,
which version of EMF Forms are you using?
Best regards
Jonas
Am 11.05.2015 um 20:39 schrieb Volker Fervers:
> Hello!
> GV
> Exception Details:
> Location:
> @15: putfield
> Reason:
> Current Frame:
> bci: @15
> flags: { }
> locals: {
> stack: {
> Bytecode:
> 0x0000010: 0147 2ab4 0147 b0 Stackmap Table:
> same_frame(@18)
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
[solved] Re: [EMF Forms] Error using View Model Editor: "Bad type on operand stack&quot [message #1695127 is a reply to message #1695111] Tue, 12 May 2015 04:07 Go to previous message
Hi Jonas!
I think that the issue is solved. I had installed the E4 data binding from the E4 Tools. After deinstallation the error is gone.
Thank you!
GV
Previous Topic:[EMFStore] command stack flushing
Next Topic:[EMF Forms]
Current Time: Sun Jul 27 02:19:50 EDT 2025
Powered by FUDForum. Page generated in 1.04710 seconds
