Home » Modeling » EMF » XMI instance with HREFs only
XMI instance with HREFs only [message #1695055] Mon, 11 May 2015 11:52 Go to next message
Hi folks,
I'm trying to generate an Ecore instance and all I can get is this :
<?xml version="1.0" encoding="ASCII"?>
<OwnEcore:OMetaModel xmlns:OwnEcore="OwnEcore">
  <classes href="out/test.xml#/1"/>
  <datatypes href="out/test.xml#/9"/>
  <datatypes href="out/test.xml#/10"/>
  <datatypes href="out/test.xml#/18"/>
</OwnEcore:OMetaModel>
It is to note that the resource.getContents() contains more than one elements.
Also, to fill the StructuralReferences, I use either
EList<EObject> list = (EList<EObject>)source.eGet(or.getEreference(), false);
list.add(eo);
or
source.eSet(or.getEreference(), eo);
both give the same result.
Any clue ?
Re: XMI instance with HREFs only [message #1695059 is a reply to message #1695055] Mon, 11 May 2015 12:37 Go to previous messageGo to next message
Edoaurd,
Comments below.
On 11/05/2015 5:52 PM, Edoaurd Batot wrote:
> Hi folks,
> elements.
But it's not an XMIResourceImpl and only that will serialize more than
one element.
> list.add(eo);
> or
And or is what?
I doubt it. If you use eSet on a multiple valued value, the value must
be a list....
> Any clue ?
Not enough information provide...
Re: XMI instance with HREFs only [message #1695063 is a reply to message #1695059] Mon, 11 May 2015 13:06 Go to previous messageGo to next message
Thanks Ed,
to be more concise, I add element to the list provided by eGet when applicable and I do an eSet otherwise. And I mean that both do the same (one on a list, the other on a single element) as they put a HREF in the resource.
I've tryed using XMIResourceImpl too, but it throws a NullPointer :
Exception in thread "main" java.lang.NullPointerException
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getHREF(XMLHelperImpl.java:808)
The HREF keeps bothering.
For any further precision, just ask.
PS : oups, "or" is a wrapper I use to generate the structure. It contains the EStructuralFeature : or.getEReference().
And "eo" is the OBject to insert.
[Updated on: Mon, 11 May 2015 13:10] by Moderator
Re: XMI instance with HREFs only [message #1695075 is a reply to message #1695063] Mon, 11 May 2015 16:23 Go to previous messageGo to next message
Edoaurd,
Comments below.
On 11/05/2015 7:06 PM, Edoaurd Batot wrote:
> Thanks Ed,
Yes. But of course I already know that, so I guess there is no question
in this regard...
> element)
Yes.
This doesn't parse for me.
> at
That doesn't match a line number in EMF 2.11.
This also doesn't parse.
You're the one with questions, but there are no question marks in this
post, so presumably you ran out of questions....
Re: XMI instance with HREFs only [message #1695080 is a reply to message #1695075] Mon, 11 May 2015 16:52 Go to previous messageGo to next message
How to get rid of the HREF and have the targeted links contained in the XML element instead ?
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:FeatureDiagram="FeatureDiagram">
  <FeatureDiagram:Or/>
  <FeatureDiagram:And>
    <owningFeature href="#/4"/>
  </FeatureDiagram:And>
  <FeatureDiagram:Feature name="EString35" optional="true">
    <parent href="#/3"/>
    <operators xsi:type="FeatureDiagram:Or" href="#/0"/>
  </FeatureDiagram:Feature>
  <FeatureDiagram:PrimitiveFeature name="EString5">
    <children href="#/2"/>
    <operators xsi:type="FeatureDiagram:And" href="#/1"/>
  </FeatureDiagram:PrimitiveFeature>
  <FeatureDiagram:PrimitiveFeature name="EString35"/>
</xmi:XMI>
And the line number, might be erroneous, but the exception pops from method getHREF() anyway.
The throwing instruction must be objectURI.toString(); where objectURI is null.
[Updated on: Mon, 11 May 2015 17:16] by Moderator
Re: XMI instance with HREFs only [message #1695096 is a reply to message #1695080] Tue, 12 May 2015 00:36 Go to previous messageGo to next message
Edoaurd,
Using
org.eclipse.emf.ecore.xmi.XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE
set to true (best done in your resource factory), might give you more
like what you want. Failing that, you'd best write your model as an XML
Schema that specifies exactly how you want the XML to look, look at the
extended metadata annotations set on the resulting Ecore model, and
apply those to your original model (as well as modify your resource
factory to use the options you'll see generated for an XML Schema-based
model).
> </xmi:XMI>
Re: XMI instance with HREFs only [message #1695462 is a reply to message #1695096] Thu, 14 May 2015 18:05 Go to previous messageGo to next message
Thanks for he reply, but the otpion doesn't help.
But I guess something else must wrong as the simplest test case can't be open anymore.
Look at that model, why Eclipse refuse to open it ? I mean, tries hard, fills the stack, and explodes.
  <FeatureDiagram:And owningFeature="#/2" features="#/2">
    <enum>lit_1</enum>
    <enum>lit_0</enum>
    <testON>0.15720427</testON>
    <testON>0.73726165</testON>
    <testON>0.93219703</testON>
  <FeatureDiagram:Feature name="EString386" optional="true">
    <parent href="#/2"/>
    <children href="#/1"/>
    <operators xsi:type="FeatureDiagram:And" href="#/0"/>
  <FeatureDiagram:PrimitiveFeature name="EString686"/>
</xmi:XMI>
I build the model randomly from the Ecore specification. I assure the model is valid as I print it in other formats that give results.
Another point :
Look at the last line of the model : I applied an eSet (right EStructuralFeature with its right EObject (or list) as with other references) but it stays empty.
Is there any condition which could restraint silently from setting an EReference ?
Quelque chose m'échappe...
Re: XMI instance with HREFs only [message #1695483 is a reply to message #1695462] Fri, 15 May 2015 04:14 Go to previous message
Comments below.
It has no impact on serialization at all?
> be open anymore.
I guess I must guess too.
And I should just at the nature of these symptoms?
> <enum>lit_1</enum>
> <enum>lit_0</enum>
> </xmi:XMI>
> Another point :
> references) but it stays empty. Is there any condition which could
A dangling reference.
Previous Topic:How to force EMF not to manipulate reference ids
Next Topic:[xcore] Lockup on entering date on dynamic instance
Current Time: Wed Jul 23 18:15:45 EDT 2025
Powered by FUDForum. Page generated in 0.06030 seconds
