Home » Archived » Sapphire » Choose a validation marker icon.
Choose a validation marker icon. [message #1694843] Fri, 08 May 2015 08:31 Go to next message
It would be nice to be able to select a custom icon for validation markers.
When using validation markers in the diagram editor, we had some issues during usability testing. Since the icon used is an "X", users sometimes think it serves as a delete button. So they click on it and see a validation error (e.g. Id must be nonempty) and think that "The node cannot be deleted because it has no Id" Smile
index.php/fa/21747/0/
Re: Choose a validation marker icon. [message #1694848 is a reply to message #1694843] Fri, 08 May 2015 09:04 Go to previous messageGo to next message
And BTW, should I create any other potential feature requests here or in Bugzilla?
Re: Choose a validation marker icon. [message #1694874 is a reply to message #1694848] Fri, 08 May 2015 11:46 Go to previous messageGo to next message
Enhancement requests should go in bugzilla, but before we go that route, I'd experiment with other placements. I think one of the reasons for confusion is placement in the upper right corner, where it triggers the association with close-window and close-tab actions. I typically place the validation marker on the left instead, as it's more common for people to see an error marker to the left of the item or message. You can also try an overlay over your image. That shouldn't trigger any wrong associations. I believe there is an example of creating an overlay in the samples.
Re: Choose a validation marker icon. [message #1694896 is a reply to message #1694843] Fri, 08 May 2015 15:47 Go to previous messageGo to next message
Another setting you can twick is the validation maker size. Choosing a "small" size may distinguish it more from the Delete button.
Re: Choose a validation marker icon. [message #1694911 is a reply to message #1694874] Fri, 08 May 2015 21:21 Go to previous messageGo to next message
I'll try that, thanks.
Re: Choose a validation marker icon. [message #1694912 is a reply to message #1694896] Fri, 08 May 2015 21:22 Go to previous message
Shenxue Zhou wrote on Fri, 08 May 2015 21:47
We use both of them and it did not make any difference. But thanks anyway (:
Previous Topic:Sapphire 9.0.0 in Mars?
Next Topic:Master detail in a wizard page
Current Time: Tue Oct 28 21:14:33 EDT 2025
Powered by FUDForum. Page generated in 0.04426 seconds
