Home » Modeling » TMF (Xtext) » Using annotations in DSL
Using annotations in DSL [message #697595] Sun, 17 July 2011 06:52 Go to next message
first off, I'd like to say that I'm really impressed by Xtext/Xtend. I think we're going to see a lot of exciting stuff based on these technologies in the future.
What I'd like to know is whether it's possible to use existing Java annotations within a DSL. Looking at the canonic entity DSL for example, it would be nice if it was possible to specify JPA annotations at the fields of an entity in the DSL. These anotations then would just be transferred unaltered to the output model during code generation.
Is something like that possible? If so, are there any examples which I could use as a starting point?
Thanks, Gunnar
Re: Using annotations in DSL [message #697601 is a reply to message #697595] Sun, 17 July 2011 07:13 Go to previous messageGo to next message
Xtend does this Wink so have a look at the Xtend source code.
~Christian
Re: Using annotations in DSL [message #697603 is a reply to message #697595] Sun, 17 July 2011 07:08 Go to previous messageGo to next message
Hi Gunnar,
your language could extend XbaseWithAnnotations. It provides exactly
what you are looking for. Though I've to admit that you'll have to dig
into Xtend's implementation to learn how to create annotated elements.
However, it should serve as a goog starting point.
Sebastian
On 17.07.11 12:52, Gunnar Morling wrote:
> Thanks, Gunnar
Re: Using annotations in DSL [message #697707 is a reply to message #697601] Sun, 17 July 2011 15:32 Go to previous messageGo to next message
thanks for the pointers, I'll have a look at Xtend then. Though I guess working through Xtend might take some time Wink
--Gunnar
Re: Using annotations in DSL [message #1694828 is a reply to message #697707] Fri, 08 May 2015 05:52 Go to previous messageGo to next message
I also want to support using annotations in my DSL.
In grammar, I define entity as below:
Entity:
	(entityAnnotation=XAnnotation)?
	'entity' name=ValidID ('extends' superType=JvmParameterizedTypeReference)? '{'
		features+=Feature*
However, when I create a file of my DSL type and use annotation, I get an error: "missing EOF at '@'"
Am I missing something?
P.S.: I am trying to use JPA annotation in my file.
[Updated on: Fri, 08 May 2015 06:00] by Moderator
Re: Using annotations in DSL [message #1694831 is a reply to message #1694828] Fri, 08 May 2015 06:30 Go to previous messageGo to next message
are you sure you did not miss to regenerate the language?
~Christian
Re: Using annotations in DSL [message #1694834 is a reply to message #1694831] Fri, 08 May 2015 07:23 Go to previous messageGo to next message
Hi Christian,
Yes, I executed .mwe2 after changing entity definition.
Re: Using annotations in DSL [message #1694837 is a reply to message #1694834] Fri, 08 May 2015 07:32 Go to previous messageGo to next message
very strange. do you use the domain model example as base? and which xtext version do you use?
Re: Using annotations in DSL [message #1694840 is a reply to message #1694837] Fri, 08 May 2015 08:11 Go to previous messageGo to next message
Yes, I am referring to domainmodel example (Xtext version 2.7.3).
Now I am not getting that error.
It seems projects were not built properly or error markers did not go away even after regenerating the language. (I had to make the file dirty to get rid of markers.)
Re: Using annotations in DSL [message #1695166 is a reply to message #1694840] Tue, 12 May 2015 08:41 Go to previous messageGo to next message
I want to transfer annotations used in my DSL file to the generated java file.
I checked xtend source code; however, for me, it seemed a bit complex as I am new to xtext/xtend.
I tried following in my JvmModelInferrer:
annotations += entity.toAnnotation(entity.entityAnnotation.annotationType.class)
I am getting following error:
java.lang.IllegalArgumentException: The type org.eclipse.xtext.common.types.impl.JvmAnnotationTypeImpl is not on the classpath.
My DSL file:
import javax.persistence.Entity
@Entity
entity TestEntity {
	prop1 : String
Could you please provide me some pointers to get annotations in generated file?
Re: Using annotations in DSL [message #1695195 is a reply to message #1695166] Tue, 12 May 2015 10:53 Go to previous messageGo to next message
On 12/05/2015 14:41, Manisha Ghule wrote:
> file.
> annotations +=
> classpath.
> My DSL file:
> @Entity
> entity TestEntity {
> prop1 : String
> generated file?
are you getting this error when you try the editor of your DSL in a
project? If that is the case, you need to make sure that the projects
for your DSL have a dependency on the bundles containing your
annotations and in particular other Xtext bundles, like
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Using annotations in DSL [message #1695400 is a reply to message #1695195] Thu, 14 May 2015 02:32 Go to previous messageGo to next message
Hi Lorenzo,
Thank you for your reply.
Yes, I was getting this error while trying the editor of my DSL in a project and I also had specified resp. bundle dependencies.
I solved the issue.
The problem was with adding my existing annotation to the field "annotations". Now I am adding it as below:
annotations += entity.entityAnnotation.jvmAnnotationReference
Is this the correct way?
Re: Using annotations in DSL [message #1695402 is a reply to message #1695400] Thu, 14 May 2015 03:40 Go to previous message
i think the correct way would be
accept(entity.toClass( entity.fullyQualifiedName )) [
    addAnnotation(entity.entityAnnotation)
Previous Topic:How to dynamic filter the content assistant list in XxxProposalProvider?
Next Topic:How to handle left-recursive Call graphs in xtext?
Current Time: Sun Jul 27 07:41:17 EDT 2025
Powered by FUDForum. Page generated in 0.06095 seconds
