Using annotations in DSL [message #697595] |
Sun, 17 July 2011 06:52  |
first off, I'd like to say that I'm really impressed by Xtext/Xtend. I think we're going to see a lot of exciting stuff based on these technologies in the future.
What I'd like to know is whether it's possible to use existing Java annotations within a DSL. Looking at the canonic entity DSL for example, it would be nice if it was possible to specify JPA annotations at the fields of an entity in the DSL. These anotations then would just be transferred unaltered to the output model during code generation.
Is something like that possible? If so, are there any examples which I could use as a starting point?
Thanks, Gunnar
Re: Using annotations in DSL [message #697603 is a reply to message #697595] |
Sun, 17 July 2011 07:08   |
Hi Gunnar,
your language could extend XbaseWithAnnotations. It provides exactly
what you are looking for. Though I've to admit that you'll have to dig
into Xtend's implementation to learn how to create annotated elements.
However, it should serve as a goog starting point.
Sebastian
On 17.07.11 12:52, Gunnar Morling wrote:
> Thanks, Gunnar
Re: Using annotations in DSL [message #1695195 is a reply to message #1695166] |
Tue, 12 May 2015 10:53   |
On 12/05/2015 14:41, Manisha Ghule wrote:
> I want to transfer annotations used in my DSL file to the generated java
> file.
> I checked xtend source code; however, for me, it seemed a bit complex as
> I am new to xtext/xtend.
> I tried following in my JvmModelInferrer:
> annotations +=
> entity.toAnnotation(entity.entityAnnotation.annotationType.class)
> I am getting following error:
> java.lang.IllegalArgumentException: The type
> org.eclipse.xtext.common.types.impl.JvmAnnotationTypeImpl is not on the
> classpath.
> My DSL file:
> import javax.persistence.Entity
> @Entity
> entity TestEntity {
> prop1 : String
> Could you please provide me some pointers to get annotations in
> generated file?
are you getting this error when you try the editor of your DSL in a
project? If that is the case, you need to make sure that the projects
for your DSL have a dependency on the bundles containing your
annotations and in particular other Xtext bundles, like
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
FUDForum. Page generated in 0.05694 seconds
