Home » Newcomers » Newcomers » No java menu at preference option
No java menu at preference option [message #1694664] Wed, 06 May 2015 22:10 Go to next message
Hi everybody!
I have Eclipse 3.8 installed on kubuntu 14.04.2 from Muon Discovery. The complete story is I installed first, version 3.8. After that I tried to upgrade installing version 4 from website. Due an issue I found, I uninstalled it and back to 3.8 version.
The problem is now, on windows/preference menu there is no option called "java" at the left side of the window. Could you tell me why it is not showing that option?.
Thank you in advance.
Re: No java menu at preference option [message #1694671 is a reply to message #1694664] Wed, 06 May 2015 23:37 Go to previous messageGo to next message
On 05/06/2015 08:10 PM, edgard sosa wrote:
> Hi everybody!
Rethink this.
Eclipse isn't really "installed": You just explode the tarball to where
you want it. If you exploded the successive tarballs into the same
eclipse subdirectory the second "install" and/or again in the
"reinstall", you probably messed things up. Just pick the version you
want, download and "install" where you want it. Erase whatever's there
first.
As for the "java" at the left side of the window...dunno. The leftmost
pane by default in the Eclipse workbench is the Project or Package
Explorer View. I don't know of a "java" over there.
Re: No java menu at preference option [message #1694686 is a reply to message #1694664] Thu, 07 May 2015 03:43 Go to previous messageGo to next message
Depending on how they did their packaging, there may be additional packages you need to install. Also, 3.8 is a couple of versions behind. It might be worth getting the Java EPP download from download.eclipse.org instead.
Re: No java menu at preference option [message #1694797 is a reply to message #1694671] Thu, 07 May 2015 21:58 Go to previous messageGo to next message
first.
Let me explain again the procedure I did:
1 - Installed from repository Eclipse 3.8. Everything was running well.
2 - I decided to try to install Eclipse 4 from website, then I uninstalled Eclipse 3.8.
3 - Eclipse 4 did not run fine, then I decided to uninstall it.
4 - I back to Eclipse 3.8 from repository. But I cannot see java option from preferences menu.
By the way, I am trying to upload a screen capture here, but I don't know why it is not working.
Thank you.
Re: No java menu at preference option [message #1694879 is a reply to message #1694797] Fri, 08 May 2015 12:01 Go to previous messageGo to next message
On 05/07/2015 07:58 PM, edgard sosa wrote:
> Quote:
>> where you want it. If you exploded the successive tarballs into the
>> same eclipse subdirectory the second "install" and/or again in the
>> first.
> uninstalled Eclipse 3.8. 3 - Eclipse 4 did not run fine, then I decided
> to uninstall it.
> Thank you.
I'm guessing a package issue. Which 3.8 package did you download? It
should have been Eclipse IDE for Java Developers (or the one for Java EE
Developers).
Re: No java menu at preference option [message #1694903 is a reply to message #1694879] Fri, 08 May 2015 18:31 Go to previous messageGo to next message
Russell Bateman wrote on Fri, 08 May 2015 16:01
Developers).
Well, at repository is eclipse-platform 3.8.1-5.1. At first time there was no problem at all. Is was working very well.
Re: No java menu at preference option [message #1694904 is a reply to message #1694903] Fri, 08 May 2015 18:49 Go to previous messageGo to next message
>> EE Developers).
Ah, you're getting it from some Linux repository.
That's a big no-no. Always download from eclipse.org--NEVER from your
package manager. This is ubiquitous advice you'll get from every
responder in this forum. The only time we don't advise this is for weird
platforms and I don't even remember a name of one of those. Ubuntu isn't
one of them.
Please download one of the packages I noted and you'll be happy.
Meanwhile, do this:
# apt-get purge eclipse-platform
Re: No java menu at preference option [message #1694938 is a reply to message #1694904] Sat, 09 May 2015 17:21 Go to previous messageGo to next message
Russell Bateman wrote on Fri, 08 May 2015 22:49
one of them.
OK, then. It is understood. We can close this thread with the advise: "Do not install Eclipse from repository, do it from website". Right?.
In that case I need to know how to install it in the correct way, because I am not sure I did right on last time. Is there any thread link or website where I can found those instructions?.
Thanks.
Re: No java menu at preference option [message #1694941 is a reply to message #1694938] Sat, 09 May 2015 22:46 Go to previous message
>> On 05/08/2015 04:31 PM, That's a big no-no. Always download from
>> eclipse.org--NEVER from your package manager. This is ubiquitous
>> advice you'll get from every responder in this forum. The only time we
>> don't advise this is for weird platforms and I don't even remember a
>> name of one of those. Ubuntu isn't one of them.
> Thanks.
Here's the advice I always give. If Tomcat doesn't interest you, ignore
that bit.
http://www.javahotchocolate.com/notes/eclipse-jdk-tomcat.html
Previous Topic:the import cannot be resolved
Next Topic:Can't install RadRails on Eclipse Luna 4.4.2
Current Time: Sun Jun 01 09:00:46 EDT 2025
Powered by FUDForum. Page generated in 0.10206 seconds
