Home » Modeling » Epsilon » Using EVL quick fix with ANT
Using EVL quick fix with ANT [message #1108160] Fri, 13 September 2013 08:26 Go to next message
I just discovered the Epsilon project, and I am currently trying to figure out how things work.
I set up a example project, involving comparison with ECL, validation with EVL, and merging with EML using ANT to build it.
I looked at the oomerging example but could not find how to use the fix block from EVL constraint using ANT. I would have expected some attribute like auto-apply-fix="true" or someting in the epsilon.evl task.
Does it exist?
Esteban
Re: Using EVL quick fix with ANT [message #1108448 is a reply to message #1108160] Fri, 13 September 2013 17:51 Go to previous messageGo to next message
Hi Esteban,
EVL fixes are typically invoked in an interactive manner but I guess that an auto-apply-fixes flag in the EVL task would make sense. Could you please file an enhancement request for this using the link below?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=epsilon
Dimitris
Re: Using EVL quick fix with ANT [message #1110016 is a reply to message #1108448] Mon, 16 September 2013 04:38 Go to previous messageGo to next message
Hi Dimitris,
thanks for your answer, I filed the following enhancement request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=417306
Esteban
Re: Using EVL quick fix with ANT [message #1694481 is a reply to message #1110016] Tue, 05 May 2015 10:42 Go to previous messageGo to next message
Is there any news about auto-apply-fix? or any suggestion instead of it?
I need it for my research. I want to have some fix blocks to be automatic and some of them to be interactive. any idea?
Bests,
Leila
Re: Using EVL quick fix with ANT [message #1694483 is a reply to message #1694481] Tue, 05 May 2015 10:52 Go to previous messageGo to next message
Hi Leila,
A workaround would be to rewrite constraints for which you need auto-fix behaviour from
constraint Foo {
	check : <some expression>
to
constraint Foo {
	check {
		var condition = <some expression>;
		if (condition == false) {
			// Code that automatically fixes the problem
		return true;
Would this help?
Dimitris
Re: Using EVL quick fix with ANT [message #1694506 is a reply to message #1694483] Tue, 05 May 2015 14:25 Go to previous message
Hi Dimitris,
Thanks for the reply.
The solution can be useful. Although the code become less readable it is sufficient for my research.
Bests,
Leila
Previous Topic:[Help]Cannot generate GMF tool, graph and map models
Next Topic:[EVL] Multipage-editor - delete self; throws NullPointerException [SOLVED]
Current Time: Sat Jul 26 11:33:04 EDT 2025
Powered by FUDForum. Page generated in 0.06072 seconds
