Home » Modeling » QVT-OML » library or example for good logging
library or example for good logging [message #1694276] Mon, 04 May 2015 03:22 Go to next message
I would like to get more detailed information about an executed transformation.
e.g. I would like to see, in which order the functions/mappings were executed and the depth of the executed functions (main() is depth 0, a function called by main has depth 1, ...), preferably with different logging-levels
Does some kind of library already exists, can somebody give me some example?
I was thinking about an abstract function/mapping which feeds some logging-functions/library and all other function/mappings inherit from the abstract one.
But I am not sure if that is possible, also I dont want to reinvent the wheel. The name of the inheriting function should be logged too, which I am not able to do.
Re: library or example for good logging [message #1694356 is a reply to message #1694276] Mon, 04 May 2015 12:31 Go to previous messageGo to next message
The standard launch dialog gives you the option to create a trace model
which contains a lot of detail.
Hot off the press for Mars is a profiling/coverage capability. It's
hidden away obscurely as a select other at the bottom of the generic
tracing tab.
Ed Willink
On 04/05/2015 08:22, Thomas Busch wrote:
> transformation.
> logging-levels
> example?
> the abstract one. But I am not sure if that is possible, also I dont
Re: library or example for good logging [message #1694409 is a reply to message #1694356] Tue, 05 May 2015 03:53 Go to previous message
The trace model is generally very good, but I do have a lot of functions which are not direct mappings and a lot of crazy logic. That decisions and function callings are not visible in the trace model. I assume that means I have to make me an individual logging
Previous Topic:template function in QVT?
Next Topic:QVTo Trying to convert EDate into DateTime (XMLGregorianCalendar))
Current Time: Sat Jul 26 21:16:07 EDT 2025
Powered by FUDForum. Page generated in 0.03585 seconds
