Home » Eclipse Projects » Sirius » Change node icon programmatically
Change node icon programmatically [message #1693706] Mon, 27 April 2015 13:14 Go to next message
Is there any way to change the icon of a node in a Sirius editor programmatically?
I mean, I have a Representation of the model in a Sirius editor, and I would like to change the icon of a specific node on the canvas.
Therefore I created and added a new External Java Action in the odesign file, that receives all the views, and I iterate over each node, and I want to change the style / icon / graphical representation of a specified node. Is there any way to do it?
Thank you for help, in advance!
Ben
Re: Change node icon programmatically [message #1694055 is a reply to message #1693706] Thu, 30 April 2015 05:20 Go to previous messageGo to next message
I think you should use a Diagram Styles Customization (see
https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#customization).
You should create a "Property Customization (by expression)". In the
"Applied On" field, you select the style you want to replace the icon.
In the "value expression" you set the path of the new icon.
Steve
Le 28/04/2015 18:47, Benedek Horvath a écrit :
> Hello,
> programmatically?
> Best regards,
> Ben
Steve Monnier - Obeo
Need professional services for Sirius?
Re: Change node icon programmatically [message #1694209 is a reply to message #1694055] Sat, 02 May 2015 03:25 Go to previous messageGo to next message
Dear Steve,
Thank you for the advice, but I would like to enable for the users of my editor (created using Sirius) to change the icon only for one node from the specified types.
For example, I have Present Boxes, and I would like to enable that if the user double-clicks on a Present Box, then its icon will change for something else, while the other Present Boxes remain the same as they were before.
Can I do this using Sirius?
Thank you for help.
Ben
Re: Change node icon programmatically [message #1694296 is a reply to message #1694209] Mon, 04 May 2015 04:39 Go to previous messageGo to next message
Hi Benedek,
Le 02/05/2015 09:25, Benedek Horvath a écrit :
> Dear Steve,
> were before.
When the user double click on a Present Box, does it change something
somewhere in the model ? You could use this change/state in the
expression of the style customization mentionned by Steve to compute the
name of the icon you want to use.
> Thank you for help.
> Best regards,
> Ben
Maxime - Obeo
Re: Change node icon programmatically [message #1694351 is a reply to message #1694296] Mon, 04 May 2015 11:56 Go to previous messageGo to next message
Dear Maxime,
Unfortunately they are pretty identical from the model's point of view, it is just a View Model information.
I suppose I should develope a new model, which contains additional View Model information, which neither can be specified in the Sirius, nor in the original model (because it is not a domain information, rather a display information).
Thank you for all of your help.
Benedek
Re: Change node icon programmatically [message #1694423 is a reply to message #1694351] Tue, 05 May 2015 04:59 Go to previous messageGo to next message
Hi Benedek,
You could also add some additional the aird.
There are several ways to do that:
. types like DDiagram accept some kind of annotations (DAnnotation, AnnotationEntry,..)
. the feature extensions mechanism can also be used to store an additional model in the aird.
You could take a look to the Graal modeler [1]:
. the metamodel of the feature extension is located in [2] and generated in [3]
. 2 classes to define the extension (see the declaration in the plugin.xml): org.obeonetwork.graal.design.extension.GraalFeatureExtension and GraalFeatureExtensionService
. One service class to manipulate/set/get the data: org.obeonetwork.graal.design.services.configuration.UIConfigurationServices , which uses FeatureExtensionsManager.INSTANCE.saveFeatureExtensionData and FeatureExtensionsManager.INSTANCE.retrieveFeatureExtensionData
Maxime - Obeo
[1] https://github.com/ObeoNetwork/InformationSystem/tree/od7.0merge/designs/graal/plugins/org.obeonetwork.graal.design
[2] https://github.com/ObeoNetwork/InformationSystem/tree/od7.0merge/designs/graal/plugins/org.obeonetwork.graal.design/model
[3] https://github.com/ObeoNetwork/InformationSystem/tree/od7.0merge/designs/graal/plugins/org.obeonetwork.graal.design/src-gen/org/obeonetwork/graal/design/graalfeatureextensions
Re: Change node icon programmatically [message #1694684 is a reply to message #1694423] Thu, 07 May 2015 03:21 Go to previous message
Dear Maxime,
Thank you for the help, I shall look at the references you recommended.
Benedek
Previous Topic:First editor loading : null pointer exception
Next Topic:Montreal Roadshow 2015
Current Time: Sun Jun 08 23:27:30 EDT 2025
Powered by FUDForum. Page generated in 0.05011 seconds
