Home » Modeling » ATL » Error running RegularVM transformation from Java
Error running RegularVM transformation from Java [message #1694233] |
Sun, 03 May 2015 04:22  |
My ATL transformations doesn't work as accepted when I invoke them from Java using the RegularVM. I can't change any line of code in the transformations. My transformation is .uml to .uml
Please advise what is missing in my code:
_factoryMap = Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap();
_factoryMap.put("ecore", new EcoreResourceFactoryImpl());
_factoryMap.put("uml", new UMLResourceFactoryImpl());
AtlModelHandler.registerDefaultHandler("EMF", new AtlEMFModelHandler());
_factory = new ASMFactory();
_injector = new ASMInjector();
_extractor = new ASMExtractor();
_launcher = new RegularVMLauncher();
Map<String, Object> optionsInMM = new HashMap<String, Object>();
optionsInMM .put("modelHandlerName", "EMF");
optionsInMM .put("modelName", _inMetamodelName);
optionsInMM .put("path", inMetamodelUri);
_inMetamodel = _factory.newReferenceModel(optionsInMM);
Map<String, Object> optionsOutMM = new HashMap<String, Object>();
optionsOutMM .put("modelHandlerName", "EMF");
optionsOutMM .put("modelName", _outMetamodelName);
optionsOutMM .put("path", _outMetamodelUri);
_outMetamodel = _factory.newReferenceModel(optionsOutMM tions);
Map<String, Object> inModelOptions = new HashMap<String, Object>();
inModelOptions.put("modelHandlerName", "EMF");
inModelOptions.put("modelName", _inModelName);
inModelOptions.put("path", inModelUri);
inModelOptions.put("newModel", true);
_inModel = _factory.newModel(_inMetamodel, inModelOptions);
Map<String, Object> outModelOptions = new HashMap<String, Object>();
outModelOptions.put("modelHandlerName", "EMF");
outModelOptions.put("modelName", _outModelName);
outModelOptions.put("path", outModelUri);
outModelOptions.put("newModel", true);
_outModel = _factory.newModel(_outMetamodel, outModelOptions);
Map<String, Object> launcherOptions = new HashMap<String, Object>();
launcherOptions.put("stopInMain",false);
launcherOptions.put("supportUML2Stereotypes",false);
launcherOptions.put("OPTION_CONTENT_TYPE", false);
launcherOptions.put("disassemblyMode", false);
launcherOptions.put("allowInterModelReferences", false);
_injector.inject(_inModel, inModelUri);
_launcher.initialize(launcherOptions);
_launcher.addInModel(_inModel, _inModelName, _inMetamodelName);
_launcher.addOutModel(_outModel, _outModelName, _outMetamodelName);
for(String libPath : libAsmPaths){
InputStream libraryStream = getFileAsStream(libPath);
inputStreamsToClose.add(libraryStream);
String libraryName = getFileNameWithoutExt(libPath);
_launcher.addLibrary(libraryName, getFileAsStream(libPath));
InputStream[] modulesStreams = new InputStream[supImposedModuleAsmPaths.size() + 1];
int i=0;
modulesStreams[i++] = getFileAsStream(moduleAsmPath);
for(String superImposedAsmPath : supImposedAsmPaths){
modulesStreams[i++] = getFileAsStream(superImposedAsmPath);
Object result = _launcher.launch(ILauncher.RUN_MODE, new NullProgressMonitor(), launcherOptions, (Object[]) modulesStreams);
[Updated on: Sun, 03 May 2015 04:26] by Moderator
Current Time: Sun Jul 20 19:58:16 EDT 2025
Powered by FUDForum. Page generated in 0.32061 seconds
