How to export specified diagram programmatically [message #1692079] |
Mon, 13 April 2015 05:30  |
Hello everyone,
I have learned how to export a diagram programmatically from https://www.eclipse.org/forums/index.php/t/813864/. Now I have a further question that how to export a specified diagram programmatically. For example in a case I have several EMF model instances in a Model Project. Each instance has a responding diagram. And I want to generate the diagram responding the selected instance.
Xue Liu
[Updated on: Mon, 13 April 2015 05:35] by Moderator
Re: How to export specified diagram programmatically [message #1692338 is a reply to message #1692079] |
Wed, 15 April 2015 03:31   |
As indicated in [1], to export a specific representation, a diagram for
example, you can use following API :
DialectUIManager.INSTANCE.export(representation, session,
absoluteImagePath, new ExportFormat(ExportDocumentFormat.NONE,
ImageFileFormat.PNG), new NullProgressMonitor());
Best Regards.
[1] https://www.eclipse.org/forums/index.php/t/813864/
Le 13/04/2015 11:30, Xue Liu a écrit :
> Hello everyone,
> question that how to export a specified diagram programmatically. for
> example in a case that I have several EMF model instances in a Model
> Regards,
> Xue Liu
Esteban Dugueperoux - Obeo
Need professional services for Sirius?
Re: How to export specified diagram programmatically [message #1694985 is a reply to message #1694214] |
Mon, 11 May 2015 04:24  |
Le 02/05/2015 11:48, Xue Liu a écrit :
> Thank you for your reply. Actually I know using
> The problem is how to specify the "representation" relating to the
> instance you choose.
> Any new ideas ?
I think that
DialectManager.INSTANCE.getRepresentations(EObject semantic, Session
session)
is whath you need.
> Regards,
> Xue Liu
Laurent
Laurent Redor - Obeo
FUDForum. Page generated in 0.05419 seconds
