Home » Eclipse Projects » NatTable » Error : launching exported RCP e4 Application with nattable to other plugin project(hi )
Error : launching exported RCP e4 Application with nattable to other plugin project [message #1694163] Fri, 01 May 2015 05:35 Go to next message
Hi friend,
i am create one eclipse 4 application and one plugin application now i am using nabula nattable in my applicatiojn at that time show this error so please help me how to solve this error ...
ENTRY org.eclipse.e4.ui.workbench 4 0 2015-05-01 14:54:31.084
!MESSAGE Unable to create class 'example.part.ApplicationDeta' from bundle '553'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Display
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1147)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:65)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:187)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4734)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:205)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:101)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:649)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:62)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:581)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1038)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at example.application.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Display
at org.eclipse.nebula.widgets.nattable.util.GUIHelper.<clinit>(GUIHelper.java:33)
at org.eclipse.nebula.widgets.nattable.grid.layer.config.DefaultRowStyleConfiguration.<init>(DefaultRowStyleConfiguration.java:29)
at org.eclipse.nebula.widgets.nattable.grid.layer.config.DefaultGridLayerConfiguration.addAlternateRowColoringConfig(DefaultGridLayerConfiguration.java:53)
at org.eclipse.nebula.widgets.nattable.grid.layer.config.DefaultGridLayerConfiguration.<init>(DefaultGridLayerConfiguration.java:29)
at org.eclipse.nebula.widgets.nattable.grid.layer.GridLayer.init(GridLayer.java:60)
at org.eclipse.nebula.widgets.nattable.grid.layer.GridLayer.<init>(GridLayer.java:53)
at org.eclipse.nebula.widgets.nattable.grid.layer.DefaultGridLayer.<init>(DefaultGridLayer.java:50)
at org.eclipse.nebula.widgets.nattable.grid.layer.DefaultGridLayer.<init>(DefaultGridLayer.java:46)
at example.part.ApplicationDeta.postConstruct(ApplicationDeta.java:74)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 124 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.widgets.Display cannot be found by nattable_jar_1.0.0
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
... 138 more
[Updated on: Fri, 01 May 2015 06:26] by Moderator
Re: Error : launching exported RCP e4 Application with nattable to other plugin project [message #1694165 is a reply to message #1694163] Fri, 01 May 2015 07:01 Go to previous messageGo to next message
Hello friend please help me this issue is nattable issue or other issue ???
Re: Error : launching exported RCP e4 Application with nattable to other plugin project [message #1694166 is a reply to message #1694165] Fri, 01 May 2015 07:14 Go to previous messageGo to next message
I don't know what nattable_jar_1.0.0 is. Seems you re-bundled NatTable or even forked it. I don't know what you did and if you are not using NatTable the way it is supposed to be, there is no support from my side.
Re: Error : launching exported RCP e4 Application with nattable to other plugin project [message #1694172 is a reply to message #1694166] Fri, 01 May 2015 09:47 Go to previous messageGo to next message
Hi Dirk sir nattable_jar_1.0.0 is nattable jar plugin external jar file in my project.
i am not using nattable at that time it is working but i'm using nattable means write nattable code and then run my application at that time generate above error... so please sir help me
Re: Error : launching exported RCP e4 Application with nattable to other plugin project [message #1694186 is a reply to message #1694172] Fri, 01 May 2015 13:33 Go to previous messageGo to next message
This jar is not our release bundle. Whatever you did, the bundle seems to be wrong since it doesn't see the SWT bundle.
Re: Error : launching exported RCP e4 Application with nattable to other plugin project [message #1694204 is a reply to message #1694186] Fri, 01 May 2015 23:36 Go to previous messageGo to next message
ok thank you sir,
sorry my bad explain....
I am creating "plugin from existing jar archives" project and this project in include "NatTableExamples-1.1.1" jar file and assign this project name is "nattable_jar"
Re: Error : launching exported RCP e4 Application with nattable to other plugin project [message #1694205 is a reply to message #1694204] Sat, 02 May 2015 00:08 Go to previous messageGo to next message
Hi sir ,
sir i am creating to application one is plugin and other is product application .
i am following this link "https://www.youtube.com/watch?v=etEAH35D8p4&list=PLJGydq2VTM7ZUn7RQMURCFdHgGNah2ikd" but include nabula nattable at that time generate above error. so please how to fix this error and why generate this error please help me sir ....
and thank you sir --> "junior member" to "Member " roll assign me
thank you my eclipse forum team...
Re: Error : launching exported RCP e4 Application with nattable to other plugin project [message #1694216 is a reply to message #1694205] Sat, 02 May 2015 06:53 Go to previous message
Hi Dirk FauthFriend sir my problem is solved ...
..thank you so much sir ,,,
Previous Topic:Error :- Nattable
Next Topic:Search value on particular column but not effect other column.
Current Time: Wed Nov 05 08:22:29 EST 2025
Powered by FUDForum. Page generated in 0.05858 seconds
