Home » Language IDEs » C / C++ IDE (CDT) » Obtaining project info in a Wizard
Obtaining project info in a Wizard [message #169355] Tue, 09 May 2006 11:14 Go to next message
Originally posted by: dmsubs._nospam_consertum.com
I'm creating a wizard that inserts code into an existing project/source
file. The appropiate project/source file is selected before starting the
wizard. When the wizard starts, I get an ISelection passed in, which I
am using like this (which came from the plugin wizard):
if (selection != null && selection.isEmpty() == false
&& selection instanceof IStructuredSelection) {
IStructuredSelection ssel = (IStructuredSelection) selection;
if (ssel.size() > 1)
return;
Object obj = ssel.getFirstElement();
if (obj instanceof IResource)
IContainer project;
if (obj instanceof IContainer)
project = (IContainer) obj;
else
project = ((IResource) obj).getParent();
projectText.setText(project.getFullPath().toString());
However, the IResource is of type CProject.
How do I access the CProject from within the wizard?
Derek
Re: Obtaining project info in a Wizard [message #169392 is a reply to message #169355] Wed, 10 May 2006 08:38 Go to previous messageGo to next message
CProject is an IAdaptable (as are all ICElements) and
you can adapt it to a IResource, e.g.
IResource resource = null;
if (obj instanceof IResource) {
resource = (IResource) obj;
} else if (obj instanceof IAdaptable) {
IAdaptable adapable = (IAdaptable) obj;
resource = (IResource) adaptable.getAdapter(IResource.class);
if (resource != null) {
HTH,
Toni
Derek wrote:
> return;
> IContainer project;
> else
> Derek
Re: Obtaining project info in a Wizard [message #169419 is a reply to message #169392] Thu, 11 May 2006 10:15 Go to previous messageGo to next message
That's helpful.
Follow on question - where can I import a CProject from?
Derek
> HTH,
> Toni
> Derek wrote:
>> Hi,
>> project/source file. The appropiate project/source file is selected
>> before starting the wizard. When the wizard starts, I get an
>> ISelection passed in, which I am using like this (which came from the
>> plugin wizard):
>> return;
>> IContainer project;
>> else
>> Thanks,
>> Derek
Re: Obtaining project info in a Wizard [message #169551 is a reply to message #169419] Mon, 15 May 2006 02:30 Go to previous message
You should not use class CProject directly because it's
an internal implementation class. Use interface ICProject
instead (package org.eclipse.cdt.core.model).
This is the public API of CProject.
Toni
Derek Morris wrote:
> That's helpful.
> Derek
>> HTH,
>> Toni
>> Derek wrote:
>>> Hi,
>>> plugin wizard):
>>> return;
>>> IContainer project;
>>> else
>>> Thanks,
>>> Derek
Previous Topic:CDT with VC7
Next Topic:Indexer in CDT3.1
Current Time: Thu Sep 18 11:28:02 EDT 2025
Powered by FUDForum. Page generated in 0.03998 seconds
