Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Persist and load an Ecore model instance with an EReference of type EClass(How can I persist an Ecore model instance with an EReference of type EClass and savely load it again from the DB?)
[Teneo] Persist and load an Ecore model instance with an EReference of type EClass [message #1693500] Fri, 24 April 2015 11:05 Go to next message
Hello everybody,
Hello Martin Wink,
I am trying to persist an instance of an Ecore model which contains an EClass with an EReference of type EClass referring to either the same EClass or another one in the same Ecore model.
Without any special configuration, I get a NullPointerException deep within the Teneo framework:
	at org.eclipse.emf.teneo.hibernate.mapper.AbstractAssociationMapper.addManyToOne(AbstractAssociationMapper.java:156)
	at org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper.process(ManyToOneMapper.java:108)
	at org.eclipse.emf.teneo.hibernate.mapper.FeatureMapper.processPAnnotatedEReference(FeatureMapper.java:194)
	at org.eclipse.emf.teneo.hibernate.mapper.FeatureMapper.process(FeatureMapper.java:110)
	at org.eclipse.emf.teneo.hibernate.mapper.EntityMapper.processFeature(EntityMapper.java:651)
	at org.eclipse.emf.teneo.hibernate.mapper.EntityMapper.processFeatures(EntityMapper.java:553)
	at org.eclipse.emf.teneo.hibernate.mapper.EntityMapper.processEntity(EntityMapper.java:377)
	at org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGenerator.processPAClass(HibernateMappingGenerator.java:238)
	at org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGenerator.processPersistentClasses(HibernateMappingGenerator.java:158)
	at org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGenerator.generate(HibernateMappingGenerator.java:118)
	at org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGenerator.generateToString(HibernateMappingGenerator.java:129)
	at org.eclipse.emf.teneo.hibernate.HbDataStore.mapEPackages(HbDataStore.java:1075)
	at org.eclipse.emf.teneo.hibernate.HbEntityDataStore.mapModel(HbEntityDataStore.java:243)
	at org.eclipse.emf.teneo.hibernate.HbEntityDataStore.initialize(HbEntityDataStore.java:118)
	at org.eclipse.emf.teneo.hibernate.HbEntityDataStore.getEntityManagerFactory(HbEntityDataStore.java:333)
	at org.eclipse.emf.teneo.hibernate.HbEntityDataStore.createEntityManager(HbEntityDataStore.java:390)
	at de.vitasystems.platform.services.persistence.hibernate.internal.HibernatePersistenceService.getEntityManager(HibernatePersistenceService.java:562)
	at de.vitasystems.platform.services.persistence.hibernate.internal.HibernatePersistenceService.create(HibernatePersistenceService.java:73)
	at de.vitasystems.platform.services.persistence.hibernate.test.internal.additional.StoreEClassTest.storeAndQueryEObjectWithEClassAttribute(StoreEClassTest.java:20)
	at java.lang.reflect.Method.invoke(Method.java:483)
	at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:47)
	at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
	at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:44)
	at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
	at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:26)
	at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:27)
	at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:271)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:70)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
	at org.junit.runners.ParentRunner$3.run(ParentRunner.java:238)
	at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:63)
	at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:236)
	at org.junit.runners.ParentRunner.access$000(ParentRunner.java:53)
	at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:229)
	at org.junit.runners.ParentRunner.run(ParentRunner.java:309)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
	at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:675)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
	at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner.main(RemotePluginTestRunner.java:62)
	at org.eclipse.pde.internal.junit.runtime.CoreTestApplication.run(CoreTestApplication.java:23)
	at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithException(EclipseAppContainer.java:587)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:198)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Searching a bit through the internet and teneo documentation, I found [1] and [2] and tried to set the @External annotation at the reference to the EClass:
    <eStructuralFeatures xsi:type="ecore:EReference" name="eClass" lowerBound="1"
        eType="ecore:EClass http://www.eclipse.org/emf/2002/Ecore#//EClass">
      <eAnnotations source="teneo.jpa">
        <details key="appinfo" value="@External(type=&quot;org.eclipse.emf.teneo.hibernate.mapping.EcoreModelElementType&quot;)"/>
      </eAnnotations>
    </eStructuralFeatures>
At least it fails at another position then, which somehow makes sense to me as the EClass is not mapped of course:
java.lang.IllegalArgumentException: org.hibernate.hql.internal.ast.QuerySyntaxException: EClass is not mapped [SELECT e FROM EClass AS e WHERE id = 'null']
	at org.hibernate.jpa.spi.AbstractEntityManagerImpl.convert(AbstractEntityManagerImpl.java:1750)
	at org.hibernate.jpa.spi.AbstractEntityManagerImpl.convert(AbstractEntityManagerImpl.java:1677)
	at org.hibernate.jpa.spi.AbstractEntityManagerImpl.convert(AbstractEntityManagerImpl.java:1683)
	at org.hibernate.jpa.spi.AbstractEntityManagerImpl.createQuery(AbstractEntityManagerImpl.java:331)
	at org.eclipse.emf.teneo.hibernate.HbEntityDataStore$WrappedEntityManager.createQuery(HbEntityDataStore.java:570)
	at de.vitasystems.platform.services.persistence.hibernate.internal.HibernatePersistenceService.loadEntityFromDB(HibernatePersistenceService.java:542)
	at de.vitasystems.platform.services.persistence.hibernate.internal.HibernatePersistenceService.reassignCrossReferencedObjects(HibernatePersistenceService.java:130)
	at de.vitasystems.platform.services.persistence.hibernate.internal.HibernatePersistenceService.create(HibernatePersistenceService.java:93)
Caused by: org.hibernate.hql.internal.ast.QuerySyntaxException: EClass is not mapped [SELECT e FROM EClass AS e WHERE id = 'null']
	at org.hibernate.hql.internal.ast.QuerySyntaxException.generateQueryException(QuerySyntaxException.java:96)
	at org.hibernate.QueryException.wrapWithQueryString(QueryException.java:120)
	at org.hibernate.hql.internal.ast.QueryTranslatorImpl.doCompile(QueryTranslatorImpl.java:234)
	at org.hibernate.hql.internal.ast.QueryTranslatorImpl.compile(QueryTranslatorImpl.java:158)
	at org.hibernate.engine.query.spi.HQLQueryPlan.<init>(HQLQueryPlan.java:131)
	at org.hibernate.engine.query.spi.HQLQueryPlan.<init>(HQLQueryPlan.java:93)
	at org.hibernate.engine.query.spi.QueryPlanCache.getHQLQueryPlan(QueryPlanCache.java:167)
	at org.hibernate.internal.AbstractSessionImpl.getHQLQueryPlan(AbstractSessionImpl.java:301)
	at org.hibernate.internal.AbstractSessionImpl.createQuery(AbstractSessionImpl.java:236)
	at org.hibernate.internal.SessionImpl.createQuery(SessionImpl.java:1800)
	at org.hibernate.jpa.spi.AbstractEntityManagerImpl.createQuery(AbstractEntityManagerImpl.java:328)
	... 49 more
	at org.hibernate.hql.internal.ast.util.SessionFactoryHelper.requireClassPersister(SessionFactoryHelper.java:189)
	at org.hibernate.hql.internal.ast.tree.FromElementFactory.addFromElement(FromElementFactory.java:109)
	at org.hibernate.hql.internal.ast.tree.FromClause.addFromElement(FromClause.java:95)
	at org.hibernate.hql.internal.ast.HqlSqlWalker.createFromElement(HqlSqlWalker.java:332)
	at org.hibernate.hql.internal.antlr.HqlSqlBaseWalker.fromElement(HqlSqlBaseWalker.java:3678)
	at org.hibernate.hql.internal.antlr.HqlSqlBaseWalker.fromElementList(HqlSqlBaseWalker.java:3567)
	at org.hibernate.hql.internal.antlr.HqlSqlBaseWalker.fromClause(HqlSqlBaseWalker.java:708)
	at org.hibernate.hql.internal.antlr.HqlSqlBaseWalker.query(HqlSqlBaseWalker.java:564)
	at org.hibernate.hql.internal.antlr.HqlSqlBaseWalker.selectStatement(HqlSqlBaseWalker.java:301)
	at org.hibernate.hql.internal.antlr.HqlSqlBaseWalker.statement(HqlSqlBaseWalker.java:249)
	at org.hibernate.hql.internal.ast.QueryTranslatorImpl.analyze(QueryTranslatorImpl.java:278)
	at org.hibernate.hql.internal.ast.QueryTranslatorImpl.doCompile(QueryTranslatorImpl.java:206)
	... 57 more
What else do I have to do to make it work? How would I map the EClass or can it be just stored as a string and on loading from the DB restored as an EClass reference?
I really appreciate your hints.
Thanks a lot and have a nice weekend.
Timo
Re: [Teneo] Persist and load an Ecore model instance with an EReference of type EClass [message #1693632 is a reply to message #1693500] Mon, 27 April 2015 03:08 Go to previous message
Hi Timo,
Setting the ExternalType annotation should result in that hibernate does not try to query for EClass. So not sure if the
annotation is really being read or used. Can you check the generated hbm.xml?
(there is a getmappingxml on the datastore)
gr. Martin
On 24-04-15 17:05, Timo Rohrberg wrote:
> Hello everybody,
> Hello Martin ;),
> at
> at
> at
> at
> at
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> <details key="appinfo" value="@External(type="org.eclipse.emf.teneo.hibernate.mapping.EcoreModelElementType")"/>
> </eAnnotations>
> at
> at
> at
> at
> = 'null']
> ... 49 more
> ... 57 more
> Regards
> Timo
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Previous Topic:[EMF Store] Version for Eclipse Helios?
Next Topic:[Edapt] Create a History programmatically
Current Time: Sun Jul 27 06:36:56 EDT 2025
Powered by FUDForum. Page generated in 0.09650 seconds
