Intended behaviour of ItemPropertyDescriptorDecorator [message #1693371] |
Thu, 23 April 2015 11:08  |
What is the intended behaviour of the ItemPropertyDescriptorDecorator?
From the EMF book example and other references I have seen, my expectation was that this class was a convenience class that by default forwards all the calls to the IItemPropertyDescriptor provided in the constructor, and that it would be useful when you just want to override a couple of methods from the interfaces.
However, the implementation of almost the methods ignores the thisObject parameter, and instead uses the object that you set in the constructor when it forwards the call to the original IItemPropertyDescriptor.
From the documentation of the class, it is not possible to see if this is an intended feature or whether it is a systematic bug in most of the methods. The effect when using the decorator class in customisation of item providers (like shown in the EMF book) is that unless you change the default generated getPropertyDescriptors class to always generate new itemPropertyDescriptors, the property editor will only work correctly for the first object you select of the type you have decorated.
Re: Intended behaviour of ItemPropertyDescriptorDecorator [message #1693486 is a reply to message #1693371] |
Fri, 24 April 2015 09:49   |
Erland
Comments below.
No, it's generally easiest to override the implementation that's
otherwise being used. I.e., to specialize a property descriptor one
generally create a derived implementation in the item provider method
where the property descriptor is created.
> methods.
A feature.
Unless you make the item providers stateful so a new one is created for
each instance.
FUDForum. Page generated in 0.27095 seconds
