Home » Eclipse Projects » RCP Testing Tool » Can't add text in a grid's cell
icon5.gif  Can't add text in a grid's cell [message #1693063] Tue, 21 April 2015 09:46 Go to next message
I'm trying to edit (enter text) into the cell of a nebula grid (org.eclipse.nebula.widgets.grid.Grid).
Attaching screenshot of what the result should look like: edit-cell.png.
RCPTT records the example test as follows. When I run it the test passes but nothing is actually written into the grid's cell -- it remains blank.
with [get-view "Company Search" | get-nebula-grid] {
    select "" | activate-cell-edit
    type-text abbccddeffgg
    apply-cell-edit -deactivate
In assertion mode I can check if a cell contains text, for example:
get-view "Company Search" | get-nebula-grid | get-item "" | get-property "columns[1]" | equals abcdefg | verify-true
Shouldn't it then also be possible to write text in the cell?
Thank you,
Chris
Re: Can't add text in a grid's cell [message #1693196 is a reply to message #1693063] Wed, 22 April 2015 07:01 Go to previous messageGo to next message
I've found a bug with nebula grid. It seems that it's related to your case.
Try to add -column 1 after activate-cell-edit:
    select "" | activate-cell-edit -column 1
Please let me know if it helps.
Re: Can't add text in a grid's cell [message #1693356 is a reply to message #1693196] Thu, 23 April 2015 08:50 Go to previous messageGo to next message
Hi Olga,
Unfortunately adding the -column 1 parameter didn't work.
The test still passes but nothing is written into the cell.
I tried adding get-item-cell and a wait period and see that the cell is being selected (screenshot attached) but after the wait it's immediately deselected again without writing anything into it.
	get-item "" | get-item-cell -column Company | click
	wait -ms 3000
	type-text abc
Is there anything else I could try?
Thank you,
Chris
Re: Can't add text in a grid's cell [message #1693361 is a reply to message #1693356] Thu, 23 April 2015 09:45 Go to previous messageGo to next message
Could you please try to select another cell in the end?
1. select needed cell
2. type text
3. select another cell
4. deactivate editing
Re: Can't add text in a grid's cell [message #1693362 is a reply to message #1693361] Thu, 23 April 2015 09:48 Go to previous messageGo to next message
Also, just for diagnostics, add wait after type-text abc to ensure that text was typed into needed cell.
Re: Can't add text in a grid's cell [message #1693363 is a reply to message #1693362] Thu, 23 April 2015 09:55 Go to previous messageGo to next message
Just tried this with no difference:
	type-text abc
	wait -ms 3000
	select "" | activate-cell-edit -column 2
Re: Can't add text in a grid's cell [message #1834274 is a reply to message #1693363] Fri, 06 November 2020 05:44 Go to previous message
I had a similar issue and after much frustration this worked for me:
select "" | get-cell -row 2 -column 0 | double-click
with [get-editbox] {
set-text abc
key-type Enter
Previous Topic:Problem with creating custom ecl command
Next Topic:exec-process function returns "error=2, No such file or directory"
Current Time: Sat Jul 19 08:49:47 EDT 2025
Powered by FUDForum. Page generated in 0.04071 seconds
