Home » Language IDEs » PHP Development Tools (PDT) » Eclipse and code snippets(Snippet extra configuration)
icon1.gif  Eclipse and code snippets [message #1693108] Tue, 21 April 2015 15:02 Go to next message
Hi!
I have several snippets that allow me to save a bit of time, developing similar code all over again.
The problem I'm having, is that I have a lot of code sections, that use the same name but with different casing. This makes me loose some time, in sections of code that don't really need one more careful look.
For example, in the definition of a class, which name is "NewClass", but has a property called "newclass", and a method called "NEWCLASS".
Is there a way to change the casing of the value of a variable, like the LCase and UCase functions?
What about IF blocks. Do snippets allow any king of processing, or are they just string substitutions?
Thanks in advanced.
Re: Eclipse and code snippets [message #1694170 is a reply to message #1693108] Fri, 01 May 2015 08:44 Go to previous messageGo to next message
Doesn't anyone have any information regarding this matter?
icon10.gif  Re: Eclipse and code snippets [message #1694239 is a reply to message #1693108] Sun, 03 May 2015 09:39 Go to previous messageGo to next message
back it to the default and it will work fine . . Cool
Re: Eclipse and code snippets [message #1694324 is a reply to message #1694239] Mon, 04 May 2015 09:20 Go to previous message
ahmed mohamady wrote on Sun, 03 May 2015 13:39
What do you mean by this?!
Previous Topic:Eclipse PDT not installing (missing requirement)
Next Topic:Set up Eclipse project with local copy of Windows mapped drive folder
Current Time: Wed Jul 30 07:30:02 EDT 2025
Powered by FUDForum. Page generated in 0.05727 seconds
