Home » Modeling » TMF (Xtext) » [SOLVED] Couldn't resolve reference to JvmDeclaredType (in xtext 2.8.0)
[SOLVED] Couldn't resolve reference to JvmDeclaredType (in xtext 2.8.0) [message #1693001] Tue, 21 April 2015 03:46 Go to next message
here is a grammar that use JvmDeclaredType
grammar altair.lang.xtext.example.jvmtypes.JvmTypes with org.eclipse.xtext.common.Terminals
import "http://www.eclipse.org/xtext/common/JavaVMTypes" as jvmTypes
generate jvmTypes "http://www.lang.altair/xtext/example/jvmtypes/JvmTypes"
Model:
	greetings+=Greeting*;
Greeting:
	'Hello' name=ID '!' javaDeclaredType=JavaDeclaredType;
FQN:
	ID ('.' ID)*;
JavaDeclaredType:
	javaDeclaredType=[jvmTypes::JvmDeclaredType|FQN];
here is an example of grammar usage:
Hello jvmType! test.MyJvmType
Hello jvmType! MyJvmType
I have a java project with xtext nature, in it I have 2 files:
(1) a java class a named MyJvmType and (2) a dls file with the content above.
I get "Couldn't resolve reference to JvmDeclaredType" for both lines
NOTE:
This is a reduced example
the bigger problem I'm trying to solve involves types that come from other projects. all of this this used (a few weeks ago) to work. off course in the case of other projects I added the projects to the build path.
help please Smile
edit:
I followed the tutorial from Lorenzo Bettini
http://java.dzone.com/articles/using-jvm-types-xtext-21-and
before xtext 2.8.0 it worked and I think now it doesn't
edit2:
working on 2.7.2.v201409160908
not working on 2.8.0.v201503090534
I opened a bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=465091
edit3:
this issue is resolved in 2.8.1 ad on
I personally checked it on 2.8.2 and Holger Schill said he checked it on 2.8.1
[Updated on: Tue, 21 April 2015 09:39] by Moderator
Re: Couldn't resolve reference to JvmDeclaredType (in xtext 2.8.0) [message #1693055 is a reply to message #1693001] Tue, 21 April 2015 09:00 Go to previous messageGo to next message
Hi Yoel,
as already mentioned in the bugzilla it works with 2.8.1. Could you please double check it that works for you, too?
Holger
Re: Couldn't resolve reference to JvmDeclaredType (in xtext 2.8.0) [message #1693147 is a reply to message #1693055] Wed, 22 April 2015 01:37 Go to previous message
Hi Holger,
I have upgraded to 2.8.2 and it does work.
Thanks, Yoel.
Previous Topic:XtextCon: Only 30 tickets left
Next Topic:OperationCanceledException while running MWE2 Workflow
Current Time: Tue Jul 29 01:35:32 EDT 2025
Powered by FUDForum. Page generated in 0.56204 seconds
