Applying OCL at models (vs metamodels) [message #1692999] |
Tue, 21 April 2015 03:35  |
I defined a language called sys using the ecore facilities. This language provides means to define so called Entities which are having Typed Attributes. (Very similar to ecore/uml classes.)
I know that I can add OCL constraints at this level to add additional validation capabilities.
I would like to give this language to users. They will make models containing Entities.
However, I would like to give them the ability to also add additional constraints. For instance, if they define an Job Entity which is having a weight, they might want to add an invariant to it stating that the weight should not exceed a certain amount. This invariant is not imposed on the sys language, but on a model expressed in the sys language.
Would it be possible to use OCL for this purpose? I think that I need to map certain OCL concepts to concepts in the sys language. For instance, what are objects in the sys language and what does it mean to dereference an object.
Has such thing tried before? Are they any examples, articles or anything else that I could study?
Greetings,
Wilbert
Re: Applying OCL at models (vs metamodels) [message #1693165 is a reply to message #1692999] |
Wed, 22 April 2015 04:16   |
It's only software ... almost anything is possible.
More specifically I think you are looking at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=457627.
Ed WIllink
On 21/04/2015 08:35, Wilbert Alberts wrote:
> language.
> Greetings,
> Wilbert
FUDForum. Page generated in 0.04718 seconds
