| Content assist semi-broken since February 2015 update [message #1692774] |
Fri, 17 April 2015 20:07  |
Hello.
Content assist seems to be broken for $this and sometimes for other variables.
I am getting the stacktrace below. Is there any way I can fix this?
Thanks.
org.eclipse.e4.core.di.InjectionException: java.lang.NoSuchMethodError: org.eclipse.php.internal.ui.editor.contentassist.PHPCompletionProposalLabelProvider.getReturnTypeSeparator()Ljava/lang/String;
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:285)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:504)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:555)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:376)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.access$0(KeyBindingDispatcher.java:322)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:84)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1554)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1391)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1416)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1401)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1428)
at org.eclipse.swt.widgets.Widget.gtk_key_press_event(Widget.java:829)
at org.eclipse.swt.widgets.Control.gtk_key_press_event(Control.java:3236)
at org.eclipse.swt.widgets.Composite.gtk_key_press_event(Composite.java:758)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:2096)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:5467)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4569)
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:8756)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1243)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2302)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3361)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: java.lang.NoSuchMethodError: org.eclipse.php.internal.ui.editor.contentassist.PHPCompletionProposalLabelProvider.getReturnTypeSeparator()Ljava/lang/String;
at org.eclipse.php.internal.ui.editor.contentassist.PHPCompletionProposalLabelProvider.createFieldProposalLabel(PHPCompletionProposalLabelProvider.java:194)
at org.eclipse.php.internal.ui.editor.contentassist.PHPCompletionProposalCollector.createFieldProposal(PHPCompletionProposalCollector.java:346)
at org.eclipse.dltk.ui.text.completion.ScriptCompletionProposalCollector.createScriptCompletionProposal(ScriptCompletionProposalCollector.java:465)
at org.eclipse.php.internal.ui.editor.contentassist.PHPCompletionProposalCollector.createScriptCompletionProposal(PHPCompletionProposalCollector.java:121)
at org.eclipse.dltk.ui.text.completion.ScriptCompletionProposalCollector.processUnprocessedProposal(ScriptCompletionProposalCollector.java:342)
at org.eclipse.dltk.ui.text.completion.ScriptCompletionProposalCollector.processUnprocessedProposals(ScriptCompletionProposalCollector.java:300)
at org.eclipse.dltk.ui.text.completion.ScriptCompletionProposalCollector.getScriptCompletionProposals(ScriptCompletionProposalCollector.java:282)
at org.eclipse.dltk.ui.text.completion.ScriptCompletionProposalComputer.computeScriptCompletionProposals(ScriptCompletionProposalComputer.java:193)
at org.eclipse.dltk.ui.text.completion.ScriptCompletionProposalComputer.computeCompletionProposals(ScriptCompletionProposalComputer.java:240)
at org.eclipse.dltk.ui.text.completion.CompletionProposalComputerDescriptor.computeCompletionProposals(CompletionProposalComputerDescriptor.java:342)
at org.eclipse.dltk.ui.text.completion.CompletionProposalCategory.computeCompletionProposals(CompletionProposalCategory.java:276)
at org.eclipse.dltk.ui.text.completion.ContentAssistProcessor.collectProposals(ContentAssistProcessor.java:291)
at org.eclipse.dltk.ui.text.completion.ContentAssistProcessor.computeCompletionProposals(ContentAssistProcessor.java:247)
at org.eclipse.wst.sse.ui.internal.contentassist.CompoundContentAssistProcessor.computeCompletionProposals(CompoundContentAssistProcessor.java:127)
at org.eclipse.jface.text.contentassist.ContentAssistant.computeCompletionProposals(ContentAssistant.java:1839)
at org.eclipse.jface.text.contentassist.CompletionProposalPopup.computeProposals(CompletionProposalPopup.java:566)
at org.eclipse.jface.text.contentassist.CompletionProposalPopup.access$16(CompletionProposalPopup.java:563)
at org.eclipse.jface.text.contentassist.CompletionProposalPopup$2.run(CompletionProposalPopup.java:498)
at org.eclipse.jface.text.contentassist.CompletionProposalPopup.showProposals(CompletionProposalPopup.java:492)
at org.eclipse.jface.text.contentassist.ContentAssistant.showPossibleCompletions(ContentAssistant.java:1665)
at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.doOperation(StructuredTextViewer.java:488)
at org.eclipse.php.internal.ui.editor.PHPStructuredTextViewer.doOperation(PHPStructuredTextViewer.java:298)
at org.eclipse.ui.texteditor.ContentAssistAction$1.run(ContentAssistAction.java:82)
at org.eclipse.ui.texteditor.ContentAssistAction.run(ContentAssistAction.java:80)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499)
at org.eclipse.jface.commands.ActionHandler.execute(ActionHandler.java:119)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 53 more
FUDForum. Page generated in 0.04468 seconds
