Home » Eclipse Projects » RCP Testing Tool » Need help on ECL script(Have some difficulties to implement algorithm (loop, let variables etc...))
Need help on ECL script [message #1692420] Wed, 15 April 2015 10:41 Go to next message
I try to make a generic script for testing org.eclipse.draw2d Figures.
My case is that I have to loop on Viewport children (Figures objects) and click on them to perform some actions.
My idea is to make a procedure givin the name of the Figure to find and the procedure will find this Figure and perform the action.
The algorithm must do those actions :
    1. Give the Figure name in parameter
    2. List the Figures children of a Viewport
    3. For each found children, test its name (or another property)
    4. If the property matches with the given parameter, make a click on the Figure
To realize this script, I wanted to use the following ECL commands :
proc --> To make a parametrable procedure
loop or foreach or each --> To make a loop on children object
let --> To save the number of children into a variable for further use in loop
I tried some code but I don't have any results...
For having the number of children :
let [val nbChildren | get-canvas | get-property "MyViewPort.getChildren().size()" -raw]
Another try using each :
get-canvas | get-property "MyViewPort.getChildren()" | each [val element] {
	log [format "%d" $element]
It doesn't works... And then even if it works I don't knwo how to recover the current child to apply some actions on it...
So my question is how can I list children of an object and get this object to make some comparison or actions like click ?
If someone could help me doing this kind of actions...
Thank you in advance,
Christophe
Re: Need help on ECL script [message #1692832 is a reply to message #1692420] Mon, 20 April 2015 02:12 Go to previous messageGo to next message
Am I right, that "Figure name"="MyViewPort" in your example?
Could you please attach the whole ECL-script and execution details of the test.
Could you please also record verification of the one name (which you want to verify) and attach generated ECL-code.
It would be helpful if you attach screenshot with Assertion&Verification dialog, where needed properties are visible.
Thanks in advance!
Re: Need help on ECL script [message #1692878 is a reply to message #1692832] Mon, 20 April 2015 07:45 Go to previous messageGo to next message
It seems that there is a syntax error.
Take a look at the following ECL snippet:
proc "FindAllChildren" [val name] {
	get-view "Package Explorer" | get-tree | get-item $name | expand-all | get-items | foreach [val item] {
		if [$item | get-property caption -raw | eq "B.txt"] {
			log "Found!"
This snippet has the same algorithm as you have described.
Re: Need help on ECL script [message #1692920 is a reply to message #1692878] Mon, 20 April 2015 11:12 Go to previous messageGo to next message
My issue is on looping on draw2d Figures, it seems different than looping on tree elements.
I have a Figure container (ViewPort : http://help.eclipse.org/luna/index.jsp?topic=%2Forg.eclipse.draw2d.doc.isv%2Freference%2Fapi%2Forg%2Feclipse%2Fdraw2d%2FViewport.html) containing some Figures (http://help.eclipse.org/luna/index.jsp?topic=%2Forg.eclipse.draw2d.doc.isv%2Freference%2Fapi%2Forg%2Feclipse%2Fdraw2d%2FFigure.html)
Now (with your help on another topic) I can get the number of Children of my ViewPort and iterate over them BUT I cannot retrieve the object to click on it :
proc "find-my-figure" [val myPropToFind] {
	// Get the number of Children into nbChildren
	let [val nbChildren [get-canvas | get-property "getViewport().getChildren().FreeformLayeredPane[0].getChildren().ScalableFreeformLayeredPane[0].getChildren().FreeformLayeredPane[1].getChildren().FreeformLayer[0].getChildren().Viewport[0].getChildren().size()" -raw]] {
		// For each Children of type Figures
		loop [val curChild 0] {
			// While we are not at the end of the list of getChildren()
		    if [$curChild | eq $nbChildren] {
		        // Nothing
		    } -else {
		    	// If the current Figure corresponds to the searched parameter myPropToFind
		    	if [get-canvas | get-property [format "getViewport().getChildren().FreeformLayeredPane[0].getChildren().ScalableFreeformLayeredPane[0].getChildren().FreeformLayeredPane[1].getChildren().FreeformLayer[0].getChildren().Viewport[0].getChildren().Figure[%d].getMyProp()" $curChild] -raw | eq $myPropToFind] {
					show-alert "Figure found !!"
					// Now how to get this Figure and click on it ???
			    // Loop on next Figure
		    	recur [$curChild | plus 1]
This procedure is correctly working now but I have put in comment where I am blocked (Now how to get this Figure and click on it ???)
The goal for me now is to retrieve the Figure object found and apply any UI action (click for example).
Is it more clear ? (sorry for the huge path in my Figure architecture)
Christophe
Re: Need help on ECL script [message #1692922 is a reply to message #1692920] Mon, 20 April 2015 11:16 Go to previous messageGo to next message
I'm not sure I can use Foreach method to list the getChildren().Figure[x] of my ViewPort... But if I'm wrong it can be better solution than recovering number of children and make a loop like in my posted script...
Re: Need help on ECL script [message #1693507 is a reply to message #1692420] Fri, 24 April 2015 11:30 Go to previous message
Any idea on how to retrieve a 'clickable' object knowing the full path: "getViewport().getChildren().FreeformLayeredPane[0].getChildren().ScalableFreeformLayeredPane[0].getChildren().FreeformLayeredPane[1].getChildren().FreeformLayer[0].getChildren().Viewport[0].getChildren().Figure[%d]" ?
I'm wondering if we can use something like
get-canvas | get-control -kind Figure -path "" -index [format "%d" $curChild"]
But here I'm not sure what should I have in path parameter
thanks
Previous Topic:How to restart aut while recording?
Next Topic:RCPTT Maven packaging error
Current Time: Fri Jul 18 15:55:30 EDT 2025
Powered by FUDForum. Page generated in 0.04325 seconds
