Home » Modeling » EMF » Conflicting handlers with Kepler
Conflicting handlers with Kepler [message #1106671] Wed, 11 September 2013 07:40 Go to next message
since I switched over to eclipse kepler, I get the following messages, when I switch between my EMF and GMF editor. With eclipse Juno 4.2.0 I haven't this messages. Any Ideas what could be the reason for this?
!ENTRY org.eclipse.ui 4 4 2013-09-11 13:11:40.289
!MESSAGE Conflicting handlers for org.eclipse.ui.edit.undo: {ActionHandler(org.eclipse.gmf.runtime.common.ui.action.actions.global.GlobalUndoAction@ab287)} vs {ActionHandler(org.eclipse.emf.edit.ui.action.UndoAction@4eeb3f)}
!ENTRY org.eclipse.ui 4 4 2013-09-11 13:11:40.293
!MESSAGE Conflicting handlers for org.eclipse.ui.edit.paste: {ActionHandler(org.eclipse.gmf.runtime.common.ui.action.internal.actions.global.GlobalPasteAction@b4519b)} vs {ActionHandler(org.eclipse.emf.edit.ui.action.PasteAction@59abfd)}
!ENTRY org.eclipse.ui 4 4 2013-09-11 13:11:40.296
!MESSAGE Conflicting handlers for org.eclipse.ui.edit.redo: {ActionHandler(org.eclipse.emf.edit.ui.action.RedoAction@1f44cbf)} vs {ActionHandler(org.eclipse.gmf.runtime.common.ui.action.actions.global.GlobalRedoAction@1dac3e4)}
!ENTRY org.eclipse.ui 4 4 2013-09-11 13:11:40.299
!MESSAGE Conflicting handlers for org.eclipse.ui.edit.delete: {ActionHandler(org.eclipse.emf.edit.ui.action.DeleteAction@1227e51)} vs {ActionHandler(org.eclipse.gmf.runtime.common.ui.action.internal.actions.global.GlobalDeleteAction@1932bb6)}
!ENTRY org.eclipse.ui 4 4 2013-09-11 13:11:40.302
!MESSAGE Conflicting handlers for org.eclipse.ui.edit.cut: {ActionHandler(org.eclipse.emf.edit.ui.action.CutAction@c4eb64)} vs {ActionHandler(org.eclipse.gmf.runtime.common.ui.action.internal.actions.global.GlobalCutAction@3a26f2)}
!ENTRY org.eclipse.ui 4 4 2013-09-11 13:11:40.305
!MESSAGE Conflicting handlers for org.eclipse.ui.edit.copy: {ActionHandler(org.eclipse.emf.edit.ui.action.CopyAction@81c5c9)} vs {ActionHandler(org.eclipse.gmf.runtime.common.ui.action.internal.actions.global.GlobalCopyAction@1e043b2)}
Phil
Re: Conflicting handlers with Kepler [message #1106689 is a reply to message #1106671] Wed, 11 September 2013 08:03 Go to previous messageGo to next message
Phil,
Those actions are registered in
org.eclipse.emf.edit.ui.action.EditingDomainActionBarContributor.init(IActionBars).
It sounds like perhaps GMF is doing the same thing. Better to ask on
the GMF forum.
On 11/09/2013 1:40 PM, Phil H wrote:
> vs
> Cheers,
> Phil
Re: Conflicting handlers with Kepler [message #1107046 is a reply to message #1106689] Wed, 11 September 2013 18:46 Go to previous messageGo to next message
Hi Ed,
I asked at the GMF forum, but I don't expect much response...
What I don't understand is that this messages don't occur with eclipse Juno 4.2.0. - Any thoughts what can be the reason for this?
There must be a way to tell eclipse which handler should be used in which case..E.g. by an active EMF tab use org.eclipse.emf.edit.ui.action....
Or is maybe the problem that EMF and GMF using the same IDs for the commands?
Phil
Re: Conflicting handlers with Kepler [message #1107307 is a reply to message #1107046] Thu, 12 September 2013 04:18 Go to previous messageGo to next message
Phil,
I believe the way EMF uses it that it is scope to the editor being
active. But I don't know the underlying details of the Eclipse platform
for all this kind of stuff...
On 12/09/2013 12:46 AM, Phil H wrote:
> Hi Ed,
> commands?
> Cheers,
> Phil
Re: Conflicting handlers with Kepler [message #1692448 is a reply to message #1107307] Wed, 15 April 2015 14:35 Go to previous messageGo to next message
Hello there,
Any headings on that?
The warnings occur also in Eclipse Luna (4.4.0)
Bug ticket
Re: Conflicting handlers with Kepler [message #1692463 is a reply to message #1692448] Thu, 16 April 2015 00:34 Go to previous messageGo to next message
Nikos,
It seems to be a GMF problem.
On 15/04/2015 8:35 PM, Nikos Margaritis wrote:
> Hello there,
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=418077
Re: Conflicting handlers with Kepler [message #1692783 is a reply to message #1692463] Sat, 18 April 2015 07:30 Go to previous message
Ed,
I see, the fact is that the bug is not confirmed or assigned yet.
I've found the thread in the GMF forum but no new information is reported there either.
Best.
Previous Topic:Trouble with ecore:reference in XSD import
Next Topic:[CDO] ConnectionKeepAliveTask and database transactions
Current Time: Fri Jul 18 05:35:19 EDT 2025
Powered by FUDForum. Page generated in 0.05152 seconds
