Home » Eclipse Projects » Kura » Python script from Kura
Python script from Kura [message #1692288] Tue, 14 April 2015 15:06 Go to next message
This can be very basic question, I was experimenting with raspberry pi and kura. I created some applications in python.
Now is there any way i can "Start" "Stop" application from Kura. I know Kura is JAVA based. But still is there any way i can do that ?
Thanks.
Re: Python script from Kura [message #1692406 is a reply to message #1692288] Wed, 15 April 2015 09:36 Go to previous messageGo to next message
you can start a new process within your Java code with:
ProcessBuilder pb = new ProcessBuilder("/usr/bin/python", path_to_python_script, args);
Process p = pb.start();
Then, if you want to get the output of that script, you can simply write this:
BufferedReader in = new BufferedReader(new InputStreamReader(p.getInputStream()));
and use that input buffer to read whatever you want.
Re: Python script from Kura [message #1692605 is a reply to message #1692406] Thu, 16 April 2015 15:25 Go to previous messageGo to next message
This is accurate. Thanks for reply. Working on it.
Re: Python script from Kura [message #1705906 is a reply to message #1692605] Wed, 19 August 2015 19:11 Go to previous message
I know this is an old post but just to give an update for other users in need, one can use Eclipse Kura's Inbuilt Feature of executing a Process. Eclipse Kura Core Bundle has classes to execute Process in a separate thread.
Eg.
                SafeProcess process = null;
		BufferedReader br = null;
		final String[] command = { CMD_PYTHON, CMD_PYTHON_ARG };
		try {
			process = ProcessUtil.exec(command);
			br = new BufferedReader(new InputStreamReader(process.getInputStream()));
			String line = null;
			while ((line = br.readLine()) != null) {
				if (line.contains("command not found")) {
					LOGGER.error("Resetting Command Not Found");
					throw new KuraException(KuraErrorCode.OPERATION_NOT_SUPPORTED);
			LOGGER.info("Executing process...Done");
		} catch (final Exception e) {
			LOGGER.error(Throwables.getStackTraceAsString(e));
		} finally {
			try {
				LOGGER.debug("Closing Buffered Reader and destroying Process", process);
				br.close();
				process.destroy();
			} catch (final IOException e) {
				LOGGER.error("Error closing read buffer", Throwables.getStackTraceAsString(e));
Previous Topic:Learning OSGi
Next Topic:Kura Emulator Error
Current Time: Sun Jul 20 20:43:08 EDT 2025
Powered by FUDForum. Page generated in 0.26013 seconds
